Question about Amana NED7200TW Electric Dryer
Wont heat - Amana NED7200TW Electric Dryer
  • Amana Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Mar 04, 2011
Ducane 2hp13l24p-1a My heat wont go off please
heat wont go off? what does that mean? turn the gas off and replace the valves if they're broken.
Oct 25, 2013 | Grilling
HKR-10C FURNACE BLOWER WONT KICK ON
if you have change the thermostat it has to have the option for electric heat the thermostat has o turn the fan on in heat mode on air handlers
Jan 07, 2013 | Goodman Manufacturing Goodman HKR-10C 10kW...
My dryer wont heat
Not sure of my brand, but when my dryer would continue to run without heating, I replaced one small fuse in the back using Google to find the right part (What Causes Gas Dryer to Stop Heating) and a youtube video to walk me through the process. Instead of a $75 maintenance visit or purchasing a new dryer, I solved the problem for $2.50.
This video worked for me, but you could search for other brands.
May 06, 2012 | Whirlpool Dryers
2000 Silhouette: HEATER WONT GIVE OFF HEAT THEIR IS HEAT BUT WONT S...
Check the water level. If the water is low it will not allow water into the heater core to produce heat. If there is water keep an eye on your temperature gauge It should reach at least 140 to 170 degrees. If it is staying colder than that you have a stuck thermostat which is allowing the water to flow to much and not let the engine warm up. The only other solution is if the fan is not working properly replace the fan relay for you blower.
May 17, 2010 | 2000 Oldsmobile Silhouette
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
My bravetti dep fryer F1063B wont heat up
In the back of the unit there is a recessed reset switch(red) Depress it until it clicks.
Dec 24, 2008 | Bravetti EP4305FS Deep Fryer
Dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
Dec 19, 2008 | Whirlpool LGR5634L Gas Dryer
Amana NED7200TW Electric Dryer Logo
43 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
