Question about GE JGRS14 Gas Single Oven
Oven won't heat
During cooking cycle oven suddenly stopped heating. No gas smell, no fault codes on control panel. Can't remove temp sensor to check. How can I troubleshoot this?
  • pegakraft Jun 18, 2008
    Because the stove might not be worth repairing, I am trying to obtain troubleshooting techniques to determine where the problem COULD be...
    Genius:
  • 1,036 Answers
Are you getting anything anymore or nothing now?
If you can only get a pilot in the main oven - and no more, There will be a thermocouple (hot wire) sitting on this. This will provide a signal to turn on the main valve. As a first step, Check the resistance of the main valve, as if the coil fails , it will shut off. In which case it will be open circuit.
If the valve is fine, the hot wire temperature sensor probably need replacement, as this gives instruction to turn the gas valve on.
Check your gas supply is still connected.
Posted on Jun 18, 2008
    Master:
    Sergeant:
  • 462 Answers
We will look into your problem and reply you soon, a your problem is complicated.
Thankyou
  • Mohamed Ismail
    Mohamed Ismail Jun 18, 2008
    It sounds like your fail safe has gone the only person who can take that job on is a gas cooker installer if you have a second hand shop that sells appliances then they could help or even take on the job less then the gas repair man try them.
    Thankyou
  • GE Master
  • 13,433 Answers
Please read this page
http://forum.doityourself.com/showthread.php?t=220859
It may solve the problem. if not please request more assistance from other experts.
  • Ekse Jun 18, 2008
    did you read the page?
    If the hot surface glow ignitor (HSI) does not glow and all control selections and settings on the front control panel are set correctly, chances are the HSI is burned out.
What does F1 mean on the display panel on my Jenn Air gas oven? It won't allow me to heat up the oven, and the igniter is fine.
F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode or
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor gotsta be within spec or it will cause the F1 code. As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode. This is equivalent to 350°F in the oven. The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit). The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms. The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness, harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad. If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously. If the F1 code is given immediately (instead of during or after a heat cycle), remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes, then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner. The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied, the surface material can break down causing shorts. If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel -don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Hope this helps.
Jun 03, 2011 | Jenn-Air Ovens
I have a Kenmore Elite Gas stove which gives me an error message F1. How much does it cost to replace that item?
Hi, the F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
Jan 20, 2011 | Ovens
F1 error?
Hi, The F1 code indicates that:
Dec 19, 2010 | Maytag CWG3100A Gas Single Oven
I have a maytag range/oven model mgs5770adb and keep getting an F1 code on the display
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (1.e., not cooking) mode or
3. If these tests all check good, then replace the ERC.
Sep 23, 2010 | Maytag Ovens
Have a kenmore double electic oven that wont stop beeping...it displays "f1" in the screen. how do i get it to stop beeping?
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 02, 2010 | Kenmore 47722 / 47724 / 47729 Electric...
How do I fix F1 error message on my Kenmore convention stove?
Aug 03, 2010 | Kenmore 33169 Gas Single Oven
Ove coming on by i self
Jul 28, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
What does the "F1" error code mean?
Y%^UTHG
Apr 02, 2009 | GE Profile JTP18 Electric Single Oven
Oven "beeping" wont stop
Sep 12, 2008 | Kenmore 47722 / 47724 / 47729 Electric...
Kenmore Oven model 790-30179400 code F11
Jul 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
GE JGRS14 Gas Single Oven Logo
151 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
