Question about D-Link Xtreme N DIR-655 Wireless Router
I have bought a d-link dir-655 router. Trying to install it now. I do not have a CD-room.. Trying to enter the router by typing http://192.168.0.1 in the url-window in Firefox (also google crome), but nothing happens. Can`t get in to the router.
  • 44 Answers
You must be on the same network as the Router is your computer only connected to the Router ( with lan cable ) if so what is the IP address on your computer. If you are on the same network as the router the computer should have the IP address 192.168.0.xxx if not check if your computer has DHCP in the properties for the netcard, and change it to DHCP if it is not and then restart your computer and try again. I hope this will work.
Posted on Nov 13, 2010
There's no CD, so how do I install dlink router dir-655?
1. set u all the possible wiring between modem and the router'
2.switch it on.
3.now open the any Browser like Opera, chrome,
4. Type the default gateway address descriptive at the back of your router (generally 192.168.0.1/192.168.1.1/192..... something) ;in the address bar of your browser and press enter.
5.now the popup message will ask for username and password .
6. now the default page of the router will get opened .
7. now run the quick setup and follow the further instructions.
8. each information should be entered properly and Your WiFi router will start working .
If any help related to Dlink Router then You can Contact us at Dlink Tech Support
Dlink Tech Support Number
Feb 13, 2014 | D-Link Wireless Router 3 Antenna Xtreme N...
I have de d-link DIR-655 router but I do not have the instalation cd what can I do
The installation CD is a simple form of the router's web interface.Try this web address to get the routers internal web page:
http://192.168.0.1
Support is in the right end column.
You may need the log on password; try admin
Jun 25, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Need the driver for BIR-655
http://www.opendrivers.com/driver/239997/d-link-dir-655-wireless-router-firmware-v1.05-free-download.html
Near the middle of this page, just above the middle actually, there's a "driver download" section. Put in the code you see and hit enter and you should be directed to a download page. Everything should be pretty obvious from then on and your driver should be updated.
Dec 31, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I do not have the installation wizard CD. Can I download the installer online?
YOU DONT NEED A CD TRY THIS
Point your Explorer at http://192.168.0.1
The Router default Username is admin
the default Password is just pressing Enter
Now you can accessRouter setup.
if it's new device, default user name and password are :
user : admin
pass : [blank
Dec 27, 2009 | D-Link Xtreme N DIR-655 Wireless Router
How to instal D-link
Read the "Quick Install Guide" that came with the router.
Or, connect an Ethernet cable between your ADSL/Cable modem to the 'WAN' port on the router.
Connect another Ethernet cable between LAN port #1 on the router and your computer.
Turn the router on.
Restart your computer.
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
Look for a line like:
Default Gateway . . . . . . . . . : 124.168.136.111
Start Internet Explorer.
Type http://124.168.136.111 and press ENTER.
Login to the router's web-interface.
Run the "Wired Setup Wizard".
Run the "Wireless Setup Wizard".
Nov 16, 2009 | D-Link DIR-655 Wireless Router
Lost my d-link dir-655 quick router setup wizard CD, can i get one?
Are you trying to set up the router?
you don't require the CD.
You can change the settings of the router manually also.
Click Here for more info about the router set up
Oct 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Dir 655 will not install
You should not need to enter any of that information.
The router will find the internet on it's own, once the ethernet cable is connected and the router is turned on.
Press the reset button at the back of the modem for 20-30 seconds, this resets the router to square 1. Power down, wait 30 seconds, then power back up. You should have internet connection to the router, which can be tested by connecting another ethernet cable from the router to the ethernet connector on your computer.
Reply back what your objective is in getting to the routers setup page.
Feb 04, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D-Link Xtreme N  DIR-655 Wireless Router Logo
55 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
