Question about Epson Stylus CX3200 All-In-One InkJet Printer
Changed both color and black inks. Did head cleaning, nozzle cleaning, allignment. Sounds like printing, but paper comes out blank.
    Guru:
  • 1,705 Answers
At a guess your print head is blocked, it'll need a drop of head cleaning solution. They sell it fairly cheaply on ebay.
Posted on Nov 13, 2010
Fix-ya
This sounds odd. Anyway, if printer prints, there's nothing wrong with printer detection.
First and foremost, what type of paper and color of paper are you using? What text/image color do you have in your file being printed?
Aug 28, 2014 | Canon PIXMA MP495 InkJet Printer
Trying to copy and nothing printing. Ink levels are good, paper is coming out
Perform "clean print heads" in printer properties select printing preferences,service then click clean nozzles, perform twice or thrice then do the nozzle test, if print heads are recovered your will be in safe, other wise***Two print heads are in this printer each print head leads two colors, left print head leads black & yellow and other one leads cyan & magenta. You need to replace the print heads based on the color which missed.
Jan 03, 2012 | HP Officejet 6500 Wireless All-in-One...
Color differences
i apologize for the inconvinience.
the possible reason why its printing the right color, is bec. some of the nozzles might be clogged by dried inks, so when inks come out, the combination of colors are not balance. try printing a nozzle check first, if the nozzle check have gaps or breaks, try head cleaning, nozzle check after it so you can see if it improve or still w/ gaps, just do nozzle check, head cleaning, then nozzle check, head cleaning alternately until no more gaps then try to print.
Printing a nozzle check pattern
Load paper in your printer
In SelecType mode, press the Paper Feed (fontu1.gif) or Paper Feed (fontd1.gif) button until TEST PRINT is displayed on the LCD panel, and then press the SelecType button.
Press Paper Feed (fontu1.gif) or Paper Feed (fontd1.gif) button to display NOZZLE CHECK
Press SelecType button to display PRINT
Press the Enter button. The nozzle check pattern is printed as shown below. After printing, printer exits the SelecType mode and return to the READY status.
Nozzle check pattern examples:
good
yoi.gif head cleaning necessary
headcleaning: press the cleaning button for 3 seconds
Feb 10, 2010 | Epson Stylus Pro 9600 InkJet Printer
BOUGHT NEW CARTRIDGES (BLACK & COLOR) COST $70!! WILL NOT PRINT. SOUNDS LIKE PRINTING BUT BLANK PAGES COME OUT. . IS THERE A WAY TO CLEAN- UNCLOG PRINTHEADS MYSELF WITHOUT TAKING TO SERVICE MAN. CAN'T...
There are a few things you can do yourself to try and get the print heads flowing again, but they won't give you as good of results as a professional cleaning or new print head. I would say that the print head is most likely clogged if you let the machine sit for more than a few weeks without printing on it. If your last set of cartridges worked fine and then you immediately put in new cartridges and it didn't print, I would say the print heads may not be clogged but expired (no amount of cleaning will get them working again). To clean the print heads yourself first rub off any accumulated ink with a warm water soaked paper towel. As a check to see how your cleaning progress is going press the print head against a dry paper towel. You should see distinct entire lines for each color. You can then try resting the print head on a paper towel soaked in warm water to hydrate the print head. If no ink soaks into the towel at all after a few minutes the print head needs more cleaning than you can do yourself. Unless you know someone with a hand held garment steamer with a narrow nozzle on it you can steam the print head to loosen up the ink stuck in it.
Feb 03, 2010 | Brother IntelliFAX 1840C Plain Paper...
Deskjet F380 is normaly printing but it will print blank
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the Ink option in the printer driver may be set to Black instead of Color or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Feb 04, 2009 | HP DeskJet F380 All-In-One Printer
Color ink not printing
Ahhrgh! Don't use windex. It contains additives that can harm the printer head.
I suggested this site in another post and it could help you.
Sep 09, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
PRINTER CANON PIXMA IP1500
your printer maybe long period of time does not use , the head already dry , replace w/ " original canon ink" not a generic.
Dec 28, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Big Black not printing
Sounds to me your print head is plugged up. This is not usual though because the majority of people use black ink much more. So, in your printer utility, do a deep cleaning. If that does not work, there is a thing called a purge unit in it. This is a usual way of draining waste ink to a pad that soaks it up. if the hose, or other parts are clogged, it backs the ink up and causes the print head to clog. If this is the start of it, do not waste your ink cleaning, and try not to let it sit too long. Contact canon, and let them kno what you think it is.
Oct 05, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
374 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
