Question about GE Kitchen Ranges
Convection oven fan continues to run even with door open and there is an electrical odor.
  • kwalves Nov 22, 2008
    I have the same problem. No problem or odor when operating in non-convection or broil modes.
  • 4 Answers
My JBP90 GE Profile convection oven had the same problem. The problem, in my case was caused by the door switch that controls the interior oven light. It also controls the convection fan and possibly the convection heating element.
1. DISCONNECT THE UNIT FROM ITS ELECTRICAL POWER SOURCE!
CONFIRM POWER IS DISCONNECTED BY OBSERVING DISPLAY GOING DARK
In your case this may mean turning off the 220V double circuit breaker or unplugging the unit cord from its power outlet.
2. Open the oven door
3. Remove the two screws under the front edge of the stove cooktop on the far left and right
4. Gently raise the cooktop 4 or 5 inches and prop it open with a small cardboard box
5. Find the door switch wire and gently pull the switch connector off
6. Remove the switch by squeezing the two metal spring tabs toward the switch and pushing the switch out toward the front
7. Inspect the switch. If its like mine, it may look a little melted and smell burnt.
8. Find a new switch online or at your nearest parts distributer
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=212235
9. Installation is the reverse of above steps.
Good Luck!
Posted on Nov 22, 2008
Convection fan runs from start up , but when temp ia achieved , fan stops working and shows con on the display
Search Results
    Frustrated with new Samsung stove! - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWe purchased a smooth top, convection Samsung range , with delivery on ... I seem to have the same problem with my new samsung range FER700WX. ... That ovenwould not reach temperature and if it did, it would not keep the temperature. ..... 3) as the oven restart the convection fan or fans blow such hot air the food in ...
    Convection 101: A Guide to Cooking With Fans - Oven ...
    ovens.reviewed.com/.../convection-cooking-101-a-guide-to-cooking-ba...
    Apr 4, 2015 - Problem is, it uses a ton of water. 6.2 ..... Convection ovens use a fanand an extra heating element to correct ... it's best to reduce oven temperature first, before adjusting cook time. ... range or wall oven, there's simply no reason not to ponyup. ... From futuristic to freaky, these fixtures run the entire spectrum.
    New Bosch range convection fan not moving? - Home Forums
    ths.gardenweb.com > Home Forums > Appliances
    Oct 8, 2007 - On my range (the slide-in version) the cooling fan runs even when in ... I was the one with the Bosch fan problem and if there is a problem with ... Mine does stop turning when I open the door and starts again when I ... convection roast feature, and once the oven reached temperature, ... Sign Up to Comment.
    Troubleshooting Gas Range and Oven Problems ' Back ...
    blog.etundra.com > Tundra's Tech Talk
Jan 17, 2016 | Kitchen Ranges
Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Aug 14, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Fes367dsa fan runs while baking but it is not a convection oven
Chris Lindstrom,
I understand that you have a fan running while you are baking. This is a totally normal function of your applliance. A cooling fan may automatically turn on and off to cool internal parts. It is normal, and the fan may continue to run even after oven is turned off.
-Best Regards-
Jan 15, 2014 | Frigidaire FES367 Electric Kitchen Range
Frigidaire Gallery convection oven fan won't stop when door opens
Sounds like one or more microswithes have either gone bad or the plunger that actuates them is broken or mis alligned. You should be able to atleast the plunger on the cavity of the oven where the door would press it in. After locating the switches get a multimeter and check each one for continuity. You can go to www.apdepot.com for an illistrated breakdown. Make sure you write your brand and model number down because you'll need them.
Apr 24, 2012 | Frigidaire Kitchen Ranges
I have the Legacy model 3530-3630 gas/electric stove.....my problem is this: for the past few days there is what sounds like a fan running in the oven. This runs constantly whether I am using the oven...
This is the convection fan. My hearland range does this too, after power loss in the house. I cancel it by starting and then stopping convection mode. ie. hit convection (fan icon) start (running man) and then cancel (X).
Dec 27, 2010 | Heartland 3530 Dual Fuel (Electric and...
The fan has stopped orking on my new world oven
I have no worked on a new world oven, but i will assume you speak of a convection oven.
Typically convection ovens have a door switch a motor and a run/start capacitor which helps the motor "turn over". I suggest, you have the oven cool, remove anything blocking the convection motor. Take your hand and spin the wheel, then while its spinning turn it on. You may have to try counter or clockwise. If you cant spin it at all, you have a bad motor, if the motor starts up with your manual assistance, the capacitor is bad. If there is not even a hum, a door switch is faulty, that or the motor has a thermal overload (usually a red button on the motor that needs resetting).
Dec 19, 2009 | Rangemaster Classic 110 (Dual Fuel) Dual...
Convection oven fan is making noise as if hitting fan shroud on start-up and when door is opened.
Either the blades have moved out on the shaft or there is excessive shaft play allowing it to hit when there is not much pressure as during start up and when the door is opened.
Eric
Jul 16, 2009 | KitchenAid KERA205P Electric Kitchen Range
My Electric Frigidaire Convection Oven just locked it's own door! I heard a continual beep..then "Err" "F9" flashed, then beeping stopped and the illuminated "padlock" symbol lit up and the door locked...
I have a similar problem with my electric Frigidaire convection oven, which flashes ERR F9 and beeps after finishing a cleaning cycle; if you haven't had to have it repaired professionally by now you might try cutting the circuit breaker to the oven for a few seconds and then turning it back on. My oven takes a few minutes to reset, after the circuit is turned back on, but then will unlock the door and let me reset the clock and continue cooking as normal. . . until the next time I set the clean cycle.
FW
Seattle WA
Dec 15, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
Jenn-Air Gas-Electric Grill Ranfe with Convection Oven M# SVD48600
if possible, squat down in front of the range and put your ear as close to the bottom of the control panel/top of the door when you close it. there is a small motor that pulls the door in when you use the self-cleaning function. perhaps that motor is running all the time? its quite, more of a humm. this could explain why its locking itself. other than that, my convection oven JennAir has a small fan in the back that runs when the oven is on, regular or convections mode. you can see this fan squirel cage in the back wall of the oven. if you were to pull the range out, you will notice (atleast on mine) that there is another much smaller fan on the backside of the range behind the removable metal panel. what the smaller fan is for, i have no idea. so there are two fans, plus if you have the down draft feature, thats 3 total. hope this helps somehow.
Jun 21, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Convection fan does not turn off when door opens
fan is operated by a door switch which has jammed. as i recall, this is located inside the rhs side panel
Jun 16, 2007 | Frigidaire GLEF378 Electric Kitchen Range
Kitchen Ranges Logo
242 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
