Question about Arris WR850GP Router
Can't get the router to connect to PS3. It keeps telling me to refer to the instruction manuel that I don't have. PS3 says I have a 100% connection though. What is wrong?
  • Arris Master
  • 7,733 Answers
Unable to connect PS3 to linksys wrt300n, key exchange timed out, signal 100% and key is correct?
For instructions on setting up the PS3, Xbox, or Wii, for a wireless/Internet connection. please click on this link :- http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 08, 2012 | Linksys Wireless-G WRT54G Router
How to hook up my ps3 to my toshiba pcx2500 router and keep my computer hooked up as well?
If your computer is already connected connected then connecting the PS3 will not stop the computer from connecting to the router.
Dec 03, 2011 | Toshiba PCX2500 (pcx2200) Modem
PS3 works great just won't connect to internet - have checked internet connections out, they all work, just PS3 won't connect. Is there a fix for that?
Try replacing the wi-fi antenna - only a few dollars. And also you could try replacing the bluetooth board - the antenna connects to that.They are your hardware fixes.
You could use an ethernet cable, if the problem persists, then it's probably a router problem.
Nov 30, 2011 | Sony Playstation 3 (PS3) Console
I can not connect to the internet. i keep get error message 80028E02.
ps3 error 80028e02 can be caused by different source of network blockages. If you happened to be in a filtered network, that's your most probable reason why your ps3 is unable to connect online. For example, if you're in a school campus, there's a high chance that the IT network administrator has placed some restrictions to prevent hackers and other malicious online activities. You can refer to the campus IT department to find out if you need to access their local page for some clearance in order for your ps3 to connect online.
If you have your own internet connection, the next probable cause is a router. Placing restrictions on some IP address or net services may have accidentally include your ps3 in it. You can change some settings within the router to grant your ps3 full access online, while at the same time maintaining other restrictions that are already in place.
Another possible remedy is have your pc internet connection shared, and use your ps3 to use that shared connection to go online. These solutions are sure fire methods of keeping ps3 80028e02 away from your console.
reference: http://www.dtheatre.com/read.php?sid=5603
Dec 16, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wep key
The WEP Key is the Password you used to protect your router. To fix this problem, uninstall your router from your computer and reinstall it. When setting it up, keep everything as default and when it gets to WEP Key, make one up and write it down. Finish installing your router.
***KEY THING IS TO WRITE EVERYTHING DOWN***
On your PS3, go to Network Settings and setup a wireless network. Let it search for your network, put in your custom WEP Key, and let it set up from there. When you enter your WEP Key, before hitting next, if there is an AOSS button on your router (Front/Top button on your router that allows networks to connect) you want to push it prior to moving on so your PS3 is discovered. You should be good to go from there.
Good luck! If i've helped you out please give me a good rating!
Respectfully,
Don
Jun 16, 2010 | Sony Playstation 3 (PS3) Console
Can't stay connected
Might I suggest checking out this site, http://www.ps3chat.com/playstation-3-online/1351-routers-ps3.html . I think that the Linksys router is having issues keeping the connection alive on your PS3. You should also consider setting a static IP.
Feb 22, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Can't connect wirelessly to my ps3
ps3 wireless card works with g and b mode only, sounds like your router is in n mode. you'll have to change it to mixed mode. to do that refer to your router manual or pdf manual in the cd.
Jul 30, 2008 | D-Link DGL-4500 Wireless Router
Connection for Ps3 thru netgear router
Make sure that you NAT is open to your PS3. To open it, you need to forward some ports. Call up PS3 and ask them what ports are needed to be forwarded. Then, go and do the adjustments to your router.
Mar 23, 2008 | NetGear WGR614 Wireless Router
PS3 Wireless connection
Is your error message relating to security or what exactly? Please try and post the error you are receiving.
Jan 11, 2008 | D-Link DSL-G604T Wireless Router
Ps3
Sounds like you have a network problem there. I'm guessing that you are using some kind of router to connect to the internet... within the router, is UPnP enabled? This could fix your problem. If it is, then maybe you need to port forward your PS3 to get the most out of online experience. Goto www.portforward.com in order to get detailed instructions on how to port forward your router. One thing that I can tell you is to pay attention to your primary DNS that your ISP provides you and make that your secondary DNS while putting your router as the primary DNS. Making a IP is a little different with each router, that's why I pointed you to www.portforward.com for more detailed instructions. (although the DNS was never really covered in it, that's why I said it here...) I had to do this with my xbox360 in order to get my full connection as the auto connection was making it really slow...
Apr 02, 2007 | Sony Playstation 3 (PS3) Console
Arris WR850GP Router Logo
49 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
