Question about Gateway MT3705 Notebook
Gateway P6831fx laptop
My laptop will not see the wireless connection it says it cannot connect other computer in my home connect it worked fine until about a wk ago the power was off and since then i cant get it to see the wireless connection would this have anything to do with this problem
  • junebug3 Jun 19, 2008
    I have tried this it is not the router the other computers in my home work just not the notebook it is not seeing a wireless connection
    Novelist:
    Scholar:
  • 70 Answers
Force a restart by disconnect the power, wait 20 seconds and then replug it back in. Most of these units do not have an on-off switch. Sometimes when the power goes out the wireless devices will not restart correctly.
Another item to look for is someone else in your neighborhood who just bought a new wireless router, probably the same kind as yours and is broadcasting its availability. Your computer sees it as the "preferred" device and will try to connect. There may not be enough "bars" for it or they may have secured theirs but did not change the name advertised. You can fix this by changing your router's name and securing it and then changing the connection at your laptop. This will insure that it always picks yours. You may also want to look at the "preferred" connections list and remove any unwanted available connections.
Posted on Jun 19, 2008
  • Kim Parker
    Kim Parker Jun 23, 2008
    Are your other computer hard-wired to the router?
    If yes then the problem may still be in the router wireless portion.
    Another issue may be in your laptop. Many have a light which is lit that shows that the wireless connection is enabled. On this laptop that I'm using if you hold the blue "Fn" key and push the F2 function key then it turns off the wireless connection.
My daughter works at home as a Customer Service Rep. for Generation Networks (Ancestor.com). She has a terminal from work and it is configured for her to work from home. She has done that for over a year...
This is only a problem with the firmware of your modem/router that you need to update it, because a network device like a modem and router that is working fine for severla years and suddenly stop working you just need to update the firmware of it and it should be working fine again, to update the firmware of the modem/router just need to call the manufacturer for that....
Hope that helps.........
Oct 05, 2008 | Computers & Internet
Lenovo G550 running Windows 7 won't connect to internet. "Default gateway is not available" message displays. I have 4 Vista computers using wireless connections all functioning fine, but this...
Hello
Wow youve done almost everything here.How about the firewall? is it blocking any connections?
Next,Go to control panel,network and sharing center.Look and see if the pc or laptop in question is on the same network,meaning home or public.
Set all your machines to the same network.Either home or public.I do know this has been a win 7 problem.
Mar 11, 2011 | Lenovo G550-29583AU Notebook
I can not figure out how to get the computer to make a wireless connection.
Add the Home SSID to the Preferred Network List After you set the SSID on your home gateway, you may need to add it to your preferred network list if Windows XP Wireless Auto Configuration is enabled. (Although automatic configuration is nice to have, your IT department may have disabled it on your laptop in order to meet their needs. If they have, you'll need to use the tool provided by your laptop or wireless manufacturer to manually configure wireless settings.) To manually add your home wireless network to the list of preferred networks when Wireless Auto Configuration is enabled, follow these steps:
• In Control Panel, click Network and Internet Connections, and then click Network Connections.
• Right-click the Wireless Network Connection, and then click Properties.
• On the Wireless Networks tab, shown in Figure 3, click Add.
Figure 3
• In the Wireless network properties dialog box, shown in Figure 4, enter the SSID you configured for your wireless gateway (ExampleHome_g in this example.)
Figure 4
Note: Figure 4 assumes you've added the Windows WPA Client Update. If you haven't downloaded and installed it, you probably should. For more on the WPA Client Update, see Overview of the WPA Wireless Security Update in Window XP.
• Fill in the rest of the fields, including the necessary authentication and encryption information based on the configuration of your wireless gateway.
• Click OK and your home network will be added to the list of preferred networks.
Now, whenever you're at home, your work laptop should automatically see your home wireless network and connect to it.
Jul 05, 2010 | Acer Aspire 5100 Notebook
Can't connect work laptop to router (wireless or
Your work laptop probably has proxy settings in the browser. If yes, please remove it adn try. That should help .
Thanks
Ranjit
Jan 05, 2010 | Actiontec Electronics (GT724WGR) Retail...
My wireless laptop gateway won't connect to my router again after going out of town using it at hotel and now it wont connect at home. it will connect on my job with no problem
Hi!
It is possible that the wifi networking where you connect in the Hotel use the same name of you home wifi network!
Try deleting your wifi profiles and reconnect again.
If you don't know how to delete the wifi profiles let me know and I tell you.
Thanks!
Feb 18, 2009 | Gateway MT3705 Notebook
Laptop won't connect to wireless
Hello :-)
Try going into device manager, and uninstalling your wireless network adapter.
Reboot your PC. It will automatically reinstall your wireless network card.
Now try your wireless connection. This often solves random wireless issues.
Jul 08, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Laptop won't detect wireless connection (but does detect others)
Dearest crystal 7, you prombally need to reset your windows
wireless. go to add and remove and remove the wireless
drivers the reboot your computer and the reinstall your wireless driver ,then go to the control panel go to internet options then to connetions then scrow down to lan settings the put a check in atuomatically detect settings the apply then ok . the reboot your computer then set up your wireless for connections for your house and it should work ...... lala linda
Jun 20, 2008 | Computers & Internet
Wireless connect
Call your ISP and demand a DSL tech visit. It sounds like either you do not have the correct password in your gateway to allow for access OR you have your computers wireless connection trned off. On my dell, i use Intel pro wireless set to connect. Your ISP's csr support should be able to get this up and running for you.
Mar 14, 2008 | Westell Wirespeed VersaLink...
Gateway MT3705 Notebook Logo
85 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
