Question about Krups 653 Chrome Belgian Waffle Maker
Krups 653 waffle maker no longer heats, could it be the heating element?
5 Suggested Answers
cactus bob
  • 267 Answers
SOURCE: older waffle maker is not heating up
thats a high temp fuse you can jump it out to test the rest of the waffle maker but dont leave it jumped out , its not safe that way . that fuse is hard to find try google "fuse high temp 185 c " please rate this answer , i need it to "get my wings" thanks
Posted on Jan 16, 2009
farfield
  • 462 Answers
SOURCE: Dead krups waffle iron
That is probably a thermal fuse. It is designed to open and stop heaters from working incase of over heat condition.
Meaning if you did not leave the appliance on too long with nothiung in it, the thermostat may be not opening at correct temp or the fuse was in a place where it got over heated or the fuse was weak.
You can replace it 1 time see if it worked ok but if it goes out again and you didn't see anything this time best replace it. Especially if under $50.00. Thermostat will probably run 1/2 of that. Thermal fuse 3 to 10. Try a heating AC parts store and take the old party with you.
If this helps you please help me by rating me as high as you can. Thanks for using fix ya.
Posted on May 06, 2009
  • 132 Answers
SOURCE: Waring Waffle Maker no heat
Remove 4 Black Phillips Screws 2 on the front near the handle that flips Use a Good fitting Screwdriver These screws have a thread locker on them. They will strip the heads out if proper care is not used when removing them.Then remove the two screws at the rear of the Iron Just rear of the cooking surface. This will remove the chrome cover on the bottom of the cooking surface exposing the wiring. The thermal fuse is located under a section of insulation under a clamp held in by another Phillips screw.Do not cut or Damage the insulation. Gently pull it back exposing the fuse. After replacing the fuse, insulation ,Clamp and screws check to be sure the iron heats and cycles on and off and the ready light works properly. If it does not cycle the new fuse will blow . Good luck
Posted on Sep 24, 2009
mcdevito75
  • 1970 Answers
SOURCE: I'm looking for the instructions that came with
mcdevito75 here, BEST BET, contact Krups customer service at 800-526-5377 Hope this helps.
Posted on Jul 11, 2010
My Krups xp4050 no longer makes steam or hot coffee
I assume there is a power 'On' light. If it is lit and no hot water is produced... the odds are the heating element is blown. If No 'Power On light' then change the fuse in the mains plug.... simples
May 17, 2014 | Krups XP4030 Espresso Machine
I received the Professional Belgian Waffle maker as a gift and have only used it twice. During the second use, about the third waffle, the heating element stopped working. What would cause this? I was...
I think this was caused by the premature failure of a Chinese thermal fuse; they are poorly made and while the principle is sound (opens if necessary to prevent fire), the components are really poor and most appliances that use a heating element fail without cause due to the lousy quality of those parts. Because of the high levels of heat where these are mounted, they are most often spot-welded in series with the element and cannot be soldered in repair. Try contacting the manufacturer, I'm pretty sure they know of the problem.
May 28, 2011 | VillaWare 2010 Waffle Maker
Suddenly stopped heating with a waffle half-made. There was an interruption between removal of last finished waffle and pouring new batter in. I suspect the thermostat failed. What cost for a new...
If you are savy to fixing these types of appliances you can disassemble the unit to gain access to the thermostat and upon inspecting that you should see a part number. Search for that part on google and you might get lucky. This model is no longer available and you would be saved a headache by getting a new one.
Mar 12, 2011 | Ultrex 416115 Sandwich Maker
The waffle maker has two lights. A red one which indicates te power is on and a green one which lights up when it reaches the desired heat (and the thermostat circuit opens and the device stops heating...
There seems to be a problem with your thermostat or temp cutout switch if the machine is getting exceptionally hot. This could explain the green light not coming on.
Jan 26, 2011 | Krups FDK2 Waffle Maker
I'm looking for the instructions that came with the Krups 653-73 two-waffle maker.
Jul 11, 2010 | Krups 653 Chrome Belgian Waffle Maker
How do you know when a waffle is finished cooking
It should be light brown on the outside and have a hard cover. It only takes several minutes at the correct heat setting.
hardrocko
Jan 31, 2010 | Krups 65475 WaffleChef Waffle Maker
My waffle iron no longer heats up.just a red light
Had the same problem with the WMK300 that others are reporting. Plug it in, hear the click, red light goes on but unit does not heat up. Found the thermal fuse in the white insulation on the bottom unit. Found replacement at Radio Shack (http://www.radioshack.com/product/index.jsp?productId=2102788). Works great!
Nov 10, 2009 | Waring WMK300 Professional Belgian Waffle...
My waffle maker will not hear up
Same issue with my mom's iron. Installed new $1 240C thermal fuse and it's working again.
Aug 29, 2009 | Waring WMK300 Professional Belgian Waffle...
May 06, 2009 | Krups 65475 WaffleChef Waffle Maker
KitchenAid Proline Waffle Maker doesn't cool down when turned off
You should always unplug a waffle iron because other wise there is a constant direct current to the iron element which if left unattended could cause a fire damage and/or death, any heating element that you cannot break the current(unlike a stove) needs to be unplugged because of the danger and the juice it is also pulling from the power company that you are paying more money for. That goes for all heating elements irons,toasters,fryers,curling irons, even hair dryers **** juice. Let me know if this helps and GOD bless goofballlovers
Apr 23, 2009 | KitchenAid Pro Line¿ Waffle Baker
Krups 653 Chrome Belgian Waffle Maker Logo
Top Krups Kitchen Appliances - Others Experts
Henry  Thomas
Henry Thomas
Mike
ArcFlash
Level 1 Expert
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
