Question about Rowenta Irons
How can I demineralize my rowenta iron? I use carbon filtered water in it. The last time I used it white stuff came out of the steam ports and it sounded like there was sediment inside when I moved the iron?
Fill the resevoir with a 25% vinegar to water solution & turn on the iron until it steams. Allow to cool and empty resevoir then rinse with clean water. Fill up resevoir and & turn on the iron until it steams again. Cool, empty & rinse again. DONE!
Only use distilled or reverse osmosis water in your iron. This will reduce mineral build up.
Posted on Dec 18, 2010
My Rowenta Expert steam generation iron (seperate tank for the water type) is starting to spit ever so often brown water out. I only use filtered water. How can I clean the actual Iron, the water tank is...
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 16, 2011 | Rowenta DG-980 Iron
ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
Stuff coming out of the steam iron
heatman101
Apr 01, 2010 | Rowenta Powerglide DE013 Iron
What happens if I use CLR in my steam iron? I have an expensive European style iron which is no longer producing steam. I have bought an iron descaler/cleaner and have repeated its use. I tried the...
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Mar 12, 2010 | Rowenta DG-980 Iron
Steam iron residue on suit pants
I would send them to the drycleaners and point out the contamination. If they were mine, I would treat them with a little white vinegar; the white deposits are caused by a buildup of calcium in your iron. Don't put the vinegar directly on the trousers but use a clean cloth with some vinegar on it and gently massage the deposits.
It may stink, but it is wise to now and then run it warm (only) with some white vinegar which will dissolve the deposits. Put it on a heat-proof surface (such as a stove grate) so it can stand flat otherwise not all of the deposits will get soaked with vinegar. After letting it soak warm, run several tanksful of plain water to remove the vinegar and shake it over the sink in case there is chunks (very well could be) that have been loosened.
Mar 27, 2009 | Rowenta DG-980 Iron
Trouble with Rowenta Irons
If your Rowenta DG 920 is chucking guff from the steam jets you need to flush it as per the instructions. ( ie. Flush every 10 uses ) If you haven;t done it for somewhile, you'll next need to expel the reamining guff with lots of steam. Then no more probs.
Aug 05, 2008 | Rowenta DG-980 Iron
I have a Rowenta DG-980 steam generator. It spits little grains of something when I use my iron. It doesn't hurt my clothing, but I have to brush the stuff off my clothes when I am finished ironing them. I...
Hi, Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion. To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time). After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water that was is in the system. Hope this helps :O)
May 06, 2008 | Rowenta DG-980 Iron
Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Feb 10, 2008 | Rowenta Steam 'n Press DA75 Iron
CALCIUM BUILDUP COMING OUT OF THE STEAM HOLES...
Hi, the other two responders were correct, use clear or filtered drinking water only. Also, use your iron until it runs dry and use burst of steam or self cleaning function to clear out the last bits of water, being sure it is empty before putting it away. Several cycles of this using and purging process will clean the iron without chemicals. Standing water that evaporates is just like a tea kettle with water left in it, all the white mineral deposits settle to the bottom, and the water dissolves the mineral salts, and when dissimilar metals are wet (think of a an old flashlight battery and the corrosion that occurs if left in storage.
Dec 04, 2007 | Rowenta DX6700 Iron
Irons Logo
439 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
