Question about Ricoh Aficio 2015 Copier
Error code SC305 for Photocopier Ricoh Aficio 1224c
I have aphotocopier ricoh aficio 1224c but keeps displaying error code SC305. How do I clear it?
  • 1 more comment
  • dorilad Jan 21, 2009
    I have a used Ricoh Aficio 450e and 1224c it keeps asking of user code and a number key how do i solve it
  • Anonymous Mar 15, 2014
    error code sc681 ricoh aficio sp c811
  • Anonymous Mar 23, 2014
    the printer still shows toner low when a new cartridge is installed
  • Ricoh Master
  • 2,794 Answers
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
Hello i have ricoh aficio 1224c color . but the is have problem error sc792 . please help me best regards Salar
SC 792 :Finisher error .
The machine does not recognize the finisher , but recognizes the relay unit .
Possible causes :Defective connector
defective cable
incorrect installation
Aug 10, 2011 | Ricoh Aficio 1224C Black and White Copier
RICOH AFICIO 5500 - SC555 ERROR HOW CAN THIS BE CLEARED?
press yellow clear then enter 107 and press and hold the orange stop key untill you enter service mode.
select copy sp
press 7807 and then the # key. select execute on the righ on the display
when it says complete turn off the machine from the red power switch. turn machine back on. if error returns repost here .. you may need parts
Aug 08, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh (Aficio) 1224c. code sc670 we want to decode this codesc670
Hi, it looks like a bad controller board. Try resetting it from in service mode with 7807. Also if you can view or printout the error history with 5990-004 for further trouble shooting. Hope this helps
Aug 03, 2011 | Ricoh Aficio 1224C Black and White Copier
Please show me how can I unlock the error code SC305 for Photocopier Ricoh Aficio 1224c
This is a Corona cleaning unit error. You either need to get the issue with the corona cleaning unit fixed or have a service technician turn off the automatic cleaning function. SP Mode 2 801 3 (technican will know what this code means) I can not tell you how to do this as you can total mess up the machine if the service mode is not used properly.
Turning off the cleaning will solve the error code. Technician can clean the coronas himself on service calls so automatic cleaning is not required.
Good Luck
Dec 07, 2009 | Ricoh Aficio 2015 Copier
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
The 1224C Ricoh Photocopier keeps on displaying SC571 error message.
Try 'clear', '107', 'start' buttons. If that does not work, try different combinations, but '107 should be correct.
Jul 04, 2008 | Ricoh Aficio 450 Copier
Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Jun 18, 2008 | Office Equipment & Supplies
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio 1018 photocopier
Hi it is the polygon motor failure error
2nd motor down on this link is what you need.
Nov 30, 2007 | Office Equipment & Supplies
Ricoh Aficio 2015 Copier Logo
1,751 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
