Question about Whirlpool RMC275PD Microwave Oven
Need to replace the light bulb--How??? - Whirlpool RMC275PD Microwave Oven
  • 11,800 Answers
Make sure the oven is unplugged from the wall socket before starting. Turn the bulb cover counter-clockwise and pull it straight out - no bending. Remove the bulb as usual; replace it with a 40 watt special appliance bulb - not an ordinary one. Put the cover over it, push it straight down and turn it clockwise. In all cases do not force it or it might break.
Posted on Nov 13, 2010
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
How do I replace the light bulb in a NEFF H7860B1GB/01 ?
Unplug power first. You need to remve the screwa that hold the bulb cover, access the bulb and replace it, I will wee if I can find a diagram.
Oct 06, 2008 | Neff Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
I need to replace the cooktop light bulb-mmv5208ww
You should try to at least find the same wattage. The light bulbs are not dangerous safety hazards if they are made to fit microwaves.
Nov 07, 2013 | Maytag Appliances Over-the-Range Microwave...
Light bulb
follow this steps and fix it. God bless you
If your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    How do i change the bulb on ag821azh microwave x2
    follow this steps and use the VOM for fix it. God bless you
    Light Bulb
    If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
    Main Control Board
    If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
    Light Bulb Socket
    If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
    Jun 19, 2013 | Microwave Ovens
    The lamp of won't work
    follow the steps and fix it. God bless you
    ight Bulb
    Main Control Board
    Light Bulb Socket
    Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
    Frigidaire microwave oven
    Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
    To replace the light bulb to the over the range microwave you will need to follow the steps below:
    1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
    2. Remove the vent grill mounting screws.
    3. Pull the vent grill away from the unit.
    4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
    5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
    6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
    7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
    Note: DO NOT USE BULB LARGER THAN 30 WATTS.
    Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
    How to replace burned out light bulb
    You need to remove the top cover to access the bulb. That is the only way on most microwaves.
    Dec 02, 2011 | Emerson MW8107WA Microwave Oven
    Replacing light bulb in Microwave Oven.
    if this is a counter top modle this is no problum, unplug it!!!
    open door look for the light hole vents, ( that is where the bulb is )
    you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
    if is a under cabinet there my be a axes door if not will need to take down,
    hope this helps.
    p.s. 1st time i that there was all kinds of things in side but not
    Jan 23, 2009 | Danby DMW1153 Microwave Oven
    Microwave Ovens Logo
    108 people viewed this question
    Top Whirlpool Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
