Question about Jenn-Air JDS8860BD Dual Fuel Range
I have a Jenn Air S136 range/oven downdraft. The self cleaning oven is not working. Would you have an idea of what part i would need to fix it?
  • kcj347 Nov 14, 2010
    The stove is a 1991. The self cleaning part of the oven quit approx 10 years ago and I just never tried to fix it. You put the oven into the self cleaning mode and everything operates as it is working fine except the heating elements do not come on.
    I tried the disconnecting the stove and restarting and get the same result as before.
    Thanks for your help
    Mat. ..
    Yes Thank you
  • 10,515 Answers
Kindly provide few more details :-
1. when did you use it last time?
2. How old is the unit?
3. Is it completely dead or shuts off?
4. Do you have any error message on the screen?
5. Have you disconnected the power supply for 5 minutes and then turn it back.If not, try and see, if that helps.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2010
  • taran_2005
    taran_2005 Nov 14, 2010
    Thanks for your response!!
    If the self cleaning is not working, it is more suggestive of an issue's with relays on the control board. f you followed the correct steps to start the self cleaning system in
    your oven and it does not start, try turning off the two breakers for
    your oven in the house breaker or fuse box for 5 minutes. This clears
    any electronic glitches in the system. If it still does not start then
    it may have a bad door switch / door latch. This sends the signal to
    the main board to start the cleaning when it detects the door is locked.
    If you get this far and it still did not work , you are now getting
    out side the realm of a home handy person fix.
    You may need a hands on tech on location to diagnose and determine which it is that needs to be replaced.
    The best option would be to clean it manually, if you could rather than spending so many bucks on an oven which is already 10 years old.
    Let me know,if needed further assistance.
    Hope i helped you.
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Having problems with self cleaning my Jenn Air model S136 can you give me step by step instructions
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
May 05, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Jenn air gas/elctric slide in range self cleaning does not work
iF THEY ALREADY REPLACED THE EXHAUST FAN , MAY WANT TO REPLACE THE HI LIMIT THERMOSTAT AT REAR OF OVEN... THE THERMOSTAT MAY RESET AFTER 20 MININUTES OF COOL DOWN..
Apr 02, 2009 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Jenn-Air S136 Grill-Range--auto clean not working
Selector to Clean
Temperature to Clean
Move lock lever to the right
Press the enter button Twice
Mar 19, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Jennair s136 drop in range
I have a Jenn-Air S136 and need instructions on how to clean the oven.  Can someone point us in the right direction?  Thank you.
Jan 19, 2008 | Ovens
Jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Nov 18, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Locking mechanism for jennair
I have Jenn Air oven S136-C with a locking bar. After cleaning cycle wait for the oven to cool down and the lock light will go out (but the oven is not yet unlocked.) Set SELECTOR knob to OFF Set TEMPERATURE knob to CLEAN Press CANCEL button (on right) twice. Slide the locking bar to the left and the oven door will open.
Dec 24, 2006 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JDS8860BD Dual Fuel  Range Logo
317 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
