Question about Ricoh Aficio CL3500N Laser Printer
Error code 92
While I am trying to print, it comes up load form fed or press enter; and a red light flashes on the panel between power and data in. This happens after it says processing and then the alert comes up.
gboza@utpa.edu
  • brjoshua Jun 27, 2008
    I'm having the same problem with our RICOH Aficio 3500 Laser.  I'll click in the print window, the printer pretends it's beginning to print, the print application on my computer (an iMac, running OS X - although it's the same on all the other XP computers down here) loads and believes it has finished printing, and closes as usual, but as the fellow above mentions, a red error light appears, and the line, "8 1/2 x 11 Plain Paper" alternates with "Load Paper or Form Feed".  Pressing the Form Feed button on the printer seems to do the trick as far as getting it to cooperate, but it seems it really should not be working that way.  I've tried reloading the print driver from the CD, to no avail - don't know if there's a special process to it on a Mac, but I just inserted the CD, ran the install program, and it assured me that drivers were loaded.  My suspicion is a setting on the printer itself (since it seems unlikely that drivers on multiple computers across multiple OS platforms would simultaneously corrupt), but any suggestions are welcome.
  • Ricoh Master
  • 691 Answers
It sounds like the print job you are sending is probably on A4 and the machine is set to A4 or has A4 in the tray.
Try changing the page size that you send to the printer and ensure the paper size in the tray is the same as the print job AND that the tray sizes are set correctly.
Posted on Jul 06, 2008
Epson Printer Problem
HI,
Press the fonts.gif load/ejectbutton. The printer ejects the jammed paper and then resumes printing.If the error is not cleared, open the printer cover and remove thejammed paper. Then reload paper in the sheet feeder and press the fonts.gif load/eject button. The printer resumes printing.
Jul 24, 2008 | Epson Office Equipment & Supplies
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
It begins to print then stops half way
Having the same problem here... very random... send a print job of labels and it will print the whole lot, or freeze at random points but always halfway through a label... no error message... unplug usb and replug doesnt do anything, but unplug and replug power and off it goes printing more lables but may even freeze again after only a few more have come out... also, every day the first print job of the day prints half the label and pauses for about 10 seconds then keeps going...
- Windows XP Pro SP3
- LabelWriter 400 as supplied out of the box
- Genuine DYMO labels
Jan 28, 2011 | Dymo LabelWriter 400 Thermal Printer
Why doesn't paper feed after "print" instruction? Printer merely makes a mechanical noise and states "paper out" condition.
Hello.
There are lots of reasons why this would happen:
Foreign object (could be very tiny)
Any power lights flashing ?
Paper feed rollers may need cleaning - try (from Canon Support):
1. Ensure that the printer is turned on. If any paper is loaded in the printer, remove it.
2. Select which roller to clean, the auto sheet feeder's or cassette's, by pressing the <Paper Feed> switch on the printer.
3. Hold down the <Resume/Cancel> button; when the Power lamp flashes green three times, release the button. The paper feed roller will rotate as it cleans itself.
4.. Repeat step 3 twice.
5. Load three or more of A4 or letter sized plain paper in the auto sheet feeder or cassette, as selected in step 2.
6. Repeat step 3. The paper that is loaded in the printer will be fed through the printer and ejected.
7. If printing problems persist, repeat step 6 up to three times.
Could be a hardware error and the printer would need servicing - still under warranty ?? If so, return to Canon for repair or replacement.
Hope this helps.
Jul 05, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
Blank labels being fed
Re-calibrate the printer by switching the printer off, press and hold the feed button whilst turning the power on. Release the button when the light flashes red. Once calibrated try again, if no joy then try a different driver
Oct 08, 2009 | Zebra LP 2844 Thermal Printer
Error code 92
the paper size selected on your pc does not match the paper size in your copier.check to see if the sizes match.
May 11, 2009 | Gestetner Office Equipment & Supplies
Epson R260. Brand new. Green light blinks, red stays on.
https://www.manualslib.com/manual/357821/Epson-Stylus-Photo-R260.html?page=55#manual says Epson's manual thinks Red
paper out light ) is on and green P power light flashes means
If you're printing on paper, your paper ran out or multiple
pages have fed at once. Make sure you push the tray lever
up to set the front tray to the paper (lower) position. Then,
load more paper and press the ) paper button to resume printing.
If you're printing on a CD or DVD, the CD/DVD tray is not
inserted. Follow the instructions beginning on page 27 to
insert the tray, then press the ) paper button.
Nov 06, 2017 | Epson Stylus Photo R260 InkJet Printer
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
Ricoh Aficio CL3500N Laser Printer Logo
2,287 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
