Question about Canon imageCLASS MF6530 All-In-One Printer
Canon MF6530 copier
I am having a problem with my copier it gives a black line down the page and the message on the copier states clean glass we tried that and still the message is there.....HELP please
  • 2,016 Answers
If your copies are clean when you scan them by opening the top and laying the original on the platen, you need to check the scanner for the ADF (automatic document feeder). It's a narrow strip of glass to the left of the scanning platen glass. Clean it with a soft cloth dampened with clear water. (Look for some type of deposit that aligns with where you see the line on the page.)
Posted on Jun 18, 2008
Printer is printing to light for my needs...has a new toner
Verify the toner cartridge.Open the glass platen cover and make a copy,not used an original,if the cpy is a full black papier thr toner density is OK,Clean the polygon unit glass.Enter in program and perform a test page.
Apr 04, 2013 | Canon MF6530 Black and White Copier
Our copier says to "clean
When you open the cover you will see two glass plates. the one on the left (smaller one) is for the feeder and the larger on is for an A4 sheet. Look at the small glass plate with a torch (flashlight) and you will see some muck stuck to it. remove it and see how it copies now. Should be clear.
Apr 27, 2011 | Office Equipment & Supplies
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
paten glass is the copy board glass.try cleaning both side,if still same.it can be off in additional funtion [copy board glass sign.turn it to off ]
Mar 17, 2010 | Canon imageRUNNER 1023iF Black and White...
CANON MF6530 COPIER LEAVING STREAKS
Is this problem appears when you copy from ADF, but not from platen copy glass?-If Yes clean the ADFs copy glass
If the streaks appears horizontal or vertical?
Check the drum unit and/or fixing film
Jan 12, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Black smudge mark down 2 inches of right side of copy?
Do you see the same smudge mark if you lay the original on the platen rather than using the document feeder? If it only shows when using the document feeder, clean the scanning glass for the document feeder. It's the small glass to the left of the main glass with the cover open. Use a damp cloth and clean off any dirt or white-out.
Nov 04, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
My Canon MF6530 keeps flashing "clean platen glass" even though I've cleaned it several times. How do I correct?
You have to take out the glass platten, clean it on both sides.
Then clean the top of the contact sensor (scanner) lightly with alcohol.
Good luck
Oct 21, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Black Line on all faxes sent
Sometimes, the reason for a black line is dirt on the glass. Try cleaning the glass and rollers so there is no dirt that will stick to the glass from the rollers.
Also the original document make sure there is no dirt or creases as the creases will translate into a black line on the receiving end.
I hope this has answered your question sufficiently. If you have more questions please post a reply and i would be happy to assist. Thanks.
Oct 11, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Mf6530 always says platen glass dirty but I've even cleaned both sides
Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Aug 20, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Copier print quality
take a credit card and scrape the glass clean.  You only need to clean along the right side of the glass where the paper passes through.  Dirt that you can't even see will cause the lines.
Oct 04, 2007 | Canon imageCLASS D780 All-In-One Laser...
Canon imageCLASS  MF6530 All-In-One Printer Logo
281 people viewed this question
old marine
old marine
