Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
What is the Ballast - Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
  • 10,594 Answers
Ballast is power supply that generates high voltage to drive lamp to produce high bright light as source light in multimedia projector/ dlp/ lcd rear projection tv.
Thanks.
Posted on Nov 13, 2010
  • jr_951 Nov 15, 2010
    ñ´ñlk`l
Ballast uart
The ballast powers the lamp. Keep the old lamp. I think it will work once the ballast circuitry is fixed
Dec 18, 2013 | Office Equipment & Supplies
BALLAST FOR PRO 24
A trained technician should: Turn off power to bed. Remove top or bottom cover as necessary, Locate bad ballast, Insert small insulated screwdriver into slot on end of ballast and pull out wire, Remove one screw that holds ballast in place and loosen the other screw, The end of the Ballast should be slotted - so pull it out from loosened screw. Now reverse the process to install new ballast. After remounting ballast to bed, simply push the wires back into small holes in connector.
Feb 02, 2013 | Wolff Sunquest Pro 24RS 220 Volts
Changing 7 wire ballast to 6 wire ballast
its got to be the wrong one--wrong ballast.
Nov 29, 2012 | Televison & Video
''UV'' light not working!!
I`ve always used one ballast to one light.i.e if your bulb is a 400 you need a 400 ballast only and feeding no more off it. Try this
Sep 29, 2009 | Sunmaster Conversion Lamp HPS Ballast
Replacing ballast
To confirm if the ballast is bad check the ballast board to see if the spark gap (on the ballast board) lights when you first turn the set on. If it does than the ballast is ok.
Sep 20, 2009 | Televison & Video
Ballast / dimmer compatability
i believe thats a magnetic ballast couldn't find it on the net... but anyway use a magnetic type dimmer for a magnetic ballast and an electronic flourescent ballast dimmer for the same..
Jul 01, 2009 | Lightolier Ivory Galaxy Slide Dimmer...
Ballast location?
the ballast is right in the middle. you should see an electrical cord. open the 2 screws from the ballast cover. then unscrew the top and bottom screw from the ballast. the ballast should come off. cut the wires closer to the ballast, so that you can identify the wire with the new ballast, which will have the same color scheme.
Jun 17, 2008 | True GDM-41 Refrigerator
Ballast replacement
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
May 12, 2008 | LG RU-60SZ30 60" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
