Question about Mitsubishi TS-5057 50 in. Rear Projection Television
Sound but no picture on Mitsubishi TS-5057 bi-screen TV. I've disassembled back shrouds looking for a bulb to replace. I just see 3 in-line projector units. What's next?
  • David Lowe Nov 13, 2010
    Thanks much for the quick response. Kind of what I figured after looking beneath the lenses. I'm familiar with HV so I'll most likely send it to the TV recycle graveyard. My hair is curly enough!
    Thanks again,
    Dave
    Yes. Confirmed my assumption. Not what I wanted to hear but that's the way it goes....
  • 335 Answers
There are no bulbs in rear projection TV's, there are only 3 CRT tubes which project a picture on the screen. The bulb your referring too is that from a DLP projection TV which is a very different technology than rear projection. Since you have a rear projection TV that has audio but no image this means there's a problem with the TV's HV deflection. Here's a list below of the possible faults:
Bad fly-back transformer Bad HV splitter Bad Convergence IC's Bad Horz/Vert output transistors Cold solder joins along convergence area
Its best to get a professional to resolve this for you as rear projection TV's hold a deadly charge even when unplugged. If you don't discharge the flyback / tubes, the charge can kill you in less than 1 second.
http://tvtechwork.webs.com/
Posted on Nov 13, 2010
MITSUBISHI TS 5057 WONT POWER UP
TS? Sure it is not VS or WS model?
Apr 09, 2012 | Mitsubishi Televison & Video
Replace bulb in center rear stop light
Open your tailgate. There is a plastic shroud that covers about half of the rear window opening. Tug firmly and the clips will pop free. Remove the shroud and set it aside. From there, you should be able to see the 3 sockets that hold the bulbs in place. Give a quarter turn and the socket will come out of the 3rd taillight assembly. Pull out the bad bulb and replace with new.
Reassembly is the reverse of disassembly. Just make sure the shroud clips line up with the corresponding holes before firmly thumping the shroud back into place.
Cheers!
Nov 15, 2010 | 2002 Dodge Durango
WD-52525 52 in. Rear Projection HDTV Television: my mitsubishi projection tv has a distorted pictur...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi TV Model TS-4557 Two problems: 1) The picture is very dark despite the brightness control being at the maximum. 2) The picture is fuzzy - particularly when there is text on the screen, to the...
the problem is picture tube base which connects picture tube to circuit board ..inside ur tv..take tecnical help of service men to replace the p.t.base
Mar 13, 2010 | Mitsubishi TS-4557 45" TV
TV was on and had a picture, and then nothing w/flashing power
Your lamp has blown. Time to get a new one.
the hyperlink button doesn't seem to be working, but just copy and paste this link into your browser. It is linked directly to your tv's replacement bulb.
http://www.discount-merchant.com/JVC-LCD-Projection-TV-Lamp-TS-CL110UAA-TS-CL110U-p/jvc-ts-cl110uaa-hd-56fn97.htm
Nov 11, 2009 | JVC HD-56FN97 56" Television
My 2005 WD62725 just started getting wavy lines on it. Everything works good (i have picture and sound and all functions) but the lines started first only when a non-HD signal was coming in. Now it has...
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
*Screen Looks 3-D
*Colors wont align
Oct 17, 2009 | Mitsubishi WD-62725 62" Rear Projection...
WD-52525 screen is jumping all around with wavy horizontal lines etc.
Good Day;
Keep talking to the factory, it is their product. Best Buy won't replace unless it is deemed not repairable and/or terms of the contract. You purchased the extra warranty because you most have felt that the TV might break down. Well, it did, now use the contract to repair your TV.
Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
