Question about Dell Dimension XPS 400 PC Desktop
Installing a new harddrive
Does it take a special cable, adaptor or hard drive for the dell xps 400 since it does not use a 40 pin connector?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey pnut10,
Most computers will come standard with one of two types of hard drives: IDE or SATA. IDE drives typically will use a 40-pin connector, while SATA drives will instead use a 7-pin data cable and separate 15-pin power cable. If you're not quite sure what kind of hard drive you have, you can generally determine its type by checking the hard drive’s outside casing. Many manufacturers will clearly print on a hard drive's main label its type, capacity and other important features.
Based on your description (and information provided by the manufacturer), you most likely will want to use an internal SATA hard drive. A good number of the SATA drives available today are sold with all the necessary cables to connect them to your computer included in the box, so you should not need any special tools or adaptors apart from a non-magnetized screwdriver.
Potentially the largest hurdle you may encounter when trying to replace your hard drive however, is the actual reinstallation of Windows itself. Not all manufacturers will provide recovery CD's or Windows installation discs with new computers, so you may want to make sure you have access to one or the other before disconnecting your current hard drive. In the event that you don't, you may want to make a disk image of your current Windows configuration using a third-party program like Norton's Ghost before proceeding.
If you're ever in doubt, I would suggest seeking the assistance of a computer repair technician. Remember that Geek Squad® agents are your local Best Buy™ store are generally able to install new hardware components on your behalf, as well as provide you with data back up services if necessary.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 18, 2008
  • 98 Answers
Uses a SATA cable. If you're using an IDE harddrive that uses a 40 pin connector, there are IDE to SATA adaptors available.
The power connector is also different on SATA Harddrives.
Remove hard disc from dimension 3100c
David, this is the Service Manual for the Dell Dimension 3100 Desktop PC,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
Click on Removing and Installing Parts.
Click on Harddrive
1) Pull the SATA power cable out of the back of the Harddrive,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
[ Note the L-shaped slot in the connector. Lines up with the L-shaped tab on the back if the Harddrive ]
2) Pull the SATA data cable out of the back of the Harddrive,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
[Top example is a SATA data cable. The bottom example is a SATA connector on the motherboard. Again note the L-shape in the connector.
The SATA power cable connector has 15 contact pins.
The SATA data cable connector has 7 ]
3) Now press the blue tabs (Clips) towards each other.
(Can also be said as -> Towards the middle of the harddrive )
4) Pull up, and out on the harddrive.
If I may ask, why are you removing it?
Post back in a Comment.
Regards,
joecoolvette
Jul 26, 2012 | Dell Dimension 3100 PC Desktop
Where is the hard drive power connector
A) With a desktop computer harddrive, there is a separate power cable.
1) IDE (PATA) type of harddrive uses a 4-pin standard Peripheral power cable. Connector is misnomered as a Molex connector.
(First company to make the connector is named Molex. Name stuck kind of like Crescent wrench, for an adjustable open-end wrench.
http://en.wikipedia.org/wiki/Molex_connector )
Example of 4-pin standard Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
SATA harddrives use a SATA power cable. It has 15 contact pins,
With a laptop harddrive there usually isn't a separate power cable.
The harddrive plugs into an Interface. A rectangular block with socket holes in it, which in turn is mounted to the motherboard.
SATA;
http://www.tech-forums.net/pc/f16/44-pin-idc-j1e1-hard-drive-sata-connector-231620/
IDE (PATA);
http://forum.tt-hardware.com/fichiers/uploads/upload_14_1/ide44pinout.gif
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 08, 2012 | Computers & Internet
Hello to all experts out here, i have this problem.i have an 80Gbts harddrive in my PC. and i want to add 2 harddrives of 40Gbts each. i have tried to do this by my self but i have this diffault. i...
Try these things,
Keep the main, original hard drive pin selected to "master", make sure the original hard drive is connected to the motherboard at the default connection.
IDE's it should be the last connector on the cord and not shared with the cd/dvd rom cord.
Sata's it should be the number "one" connector on the motherboard. The board is typically labeled and with numbers.
The new hard drives you should try putting them into "cable select" since you said setting them to "slave" doesnt work. It's a good idea to just go into bios to make sure those connectors are enabled. Some desktop bios are set to off or disabled.
Do you have a CD/DVD player? Sometimes I have seen they can interfere with adding hard drives. Why not remove it for the time being just to see if it works.
Aug 11, 2011 | Dell Computers & Internet
Hi . I have trouble with Dell optiplex GX280 . In the PATA I have two devices . DVD and HD . Both set with jumper . DVD as Slave and HDD as Master ....But the install os cannot detect HDD . where is...
I don't know where the trouble is without more information.
Some tips/information I will list, however,
1) The master harddrive that came with the computer, and has the operating system on it, is a SATA unit.
Therefore any harddrive installed along with it has to be installed as a Slave drive.
BIOS will look for the harddrive with the operating system on it. This harddrive has to be set as a Master drive. (Primary Drive in BIOS)
Installing a harddrive that is a PATA (IDE) unit, AND a PATA optical drive on the same flat ribbon cable, has to be done accordingly;
A) It depends on what flat ribbon cable you have.
There is a 40 wire cable with a 40 pin connector. (39 actually. One socket hole is not used)
There is an 80 wire cable with a 40 pin connector. (39 actually)
http://en.wikipedia.org/wiki/File:ATA_cables.jpg
http://en.wikipedia.org/wiki/Parallel_ATA#IDE_and_ATA-1
Proper method of connecting,
http://www.mikeshardware.com/howtos/howto_connect_ide_hd.html
2) Proper method of using jumpers on an IDE (PATA) harddrive, and connecting the flat ribbon cable,
http://www.youtube.com/watch?v=4inX3nC6M1E
Regards,
joecoolvette
Jun 05, 2011 | Dell Optiplex GX280 (99301) Motherboard
Is it possible to take my IDE harddrive from my old dell dimension 8100 running 'XP' and install it as a second harddrive in my dell studio 8100 studio xps with W7, then boot "XP" from harddrive...
If your motherboard in your new machine supports IDE and you set the jumper on the HDD to slave then I dont see any reason why you wouldnt be able to use it as a second drive
Feb 17, 2011 | Dell Studio Xps 8100 Desktop Computer
Received Dell XPS 8100. No cd player so they sent me one. Dell hell it is. Anyway, I opened it and found MANY wires unconnected. Can you tell me what connects where? I took the cd burner out of my old one...
Your old computer had IDE interface, the new computer has SATA interface.. There is a thin connector power cord and interface cords with tge same width connectors.The existing hard drive has thes cables connected to it. Connect one power cord and one data interface cable to the cd drive. Connect the audio cable to the cd drive and the Audio IN connector on the motherboard.
Unless the motherboard has a ide connector. you can not use your old hard drive or cd. You can get a external drive encloser that can convert IDE to USB
Oct 14, 2010 | Dell Studio Xps 8100 Desktop Computer
How to install a second hard drive
pmarrs177 you are quite welcome!
I suppose I better post this as a solution, instead of in a Clarification.
This way when someone looks for this type of information, it will be available in a search hit on the internet.
Your problem and my solution will be on the internet for years to come. (Also easier to read) Congratulations! You'll be known worldwide as one more person, who helped bring the mysteries of SATA to be a little bit less mysterious.
Installing it as a secondary storage Harddrive?
Did your Acer T180 model come with a SATA harddrive already installed?
There are several different models of the Acer T180.
Some examples: AST180-UA380A, AST180-U381A, AST180-UA380B
Some of these came with a PATA harddrive, and some came with a SATA harddrive. (PATA is also referred to as ATA, IDE, and EIDE)
Why the question? Because when Windows is first installed on a computer, you are asked if you wish the SATA drivers to be installed.
The model version of an ACER T180 that came with a SATA harddrive, has these drivers already installed.
If your Acer did come with a SATA harddrive, and you are installing an additional harddrive for more storage, just plug the SATA data cable into ANY available SATA header on the motherboard.
BIOS will find the harddrive. Just one of the nice features about SATA.
You can use ANY SATA header on the motherboard. {Not shouting}
(A connection on a motherboard is a Header. This is what a SATA header on a motherboard looks like, doesn't matter what color it is.
http://en.wikipedia.org/wiki/SATA
{Top right photo on page)
The SATA data cable, usually has a 90 degree elbow on one end. This end connects to the Harddrive. Doesn't always have a 90 degree elbow, but most of the time it does.
The straight end connects to the motherboard. There are 7 pins used in the connector.
The SATA power cable has 15 pins.
Scroll down the page in the above link, for photos of the end connector for a SATA data cable, and the end connector used for a SATA power cable.
NOTE*
IF, you do not have an unused SATA power cable coming out of your Power Supply, see if you have a 4-pin peripheral power cable that is not being used.
(The connector end is referred to as a 4-pin Molex connector. It is whitish in color)
This shows what a 4-pin peripheral power cable looks like,
Buy an adapter power cable that connects to the 4-pin Molex connector, and has a 15-pin SATA power cable connector on the other end.
Example: http://www.directron.com/idesatapower.html
Mar 13, 2010 | Acer Aspire™ T180 PC Desktop
How do i install a used hard drive into an eMachines T2341? The hard drive still has information on it. do i set it as master, slave, or cable select? hard drive is an IBM 10.1 gb
There are two possible solutions depending on how your desktop is setup.
#1 install the 2nd hard drive and put jumper to CABLE SELECT. When you start the computer it should now appear in the bios as a SLAVE or 2nd hard drive. If not go to #2 below
#2 Turn system off again and change jumper on 2nd hard drive to SLAVE.
Now when your computer restarts it will appear in your bios correctly as the 2nd drive/SLAVE.
Do not make it "MASTER" or you will be trying to boot up to this drive and it may not work as you planned.
FYI: "Cable Select" means the hard drive determines which one is Master and which one is Slave by where it is on the data cable.
Good Luck
Dec 30, 2009 | Computers & Internet
1 Solution for ''I have a Compaq Presario 7000 replacing the C harddrive the BIOS set up does not find harddrive''
possible causes:
1. jumper set incorrectly on hard drive itsself.
2. data or power cable not connected properly to hard drive
3. data cable backwards in hard drive or motherboard. (should always have the red stripe on the data cable towards the power connector on the hard drive and on pin number one of the motherboards' primary IDE connector)
check all off these...IF you are installing a SATA hard drive then you may need to install sata drivers on your computer.. Please post again if i misunderstood your question..
Regards......
Apr 09, 2009 | Computers & Internet
Want safe way to piggy back a power supply for XPS 210
The simplest way to solve this will be to get a power splitter. You should get one for around 2$. It will have a connector and two plugs(used to split the power supply into two.)
Jul 13, 2008 | Dell XPS 200 PC Desktop
Dell Dimension XPS 400 PC Desktop Logo
151 people viewed this question
Alun Cox
