Question about Craftsman Garden
Can not remover edger blade which way do you turn nut seems to be frozen
    President:
  • Craftsman Master
  • 1,545 Answers
Spray that ****** with some penetrating oil like PB Blaster or Liquid Wrench and let it soak on it overnight. The locking nut probably removes counterclockwise. Maybe use the exact corresponding hex-head socket (6-Pt. not a 12-Pt.) and ratchet and give the handle a good strong rap with a hammer when it is ready.
Posted on Nov 14, 2010
Craftsman edger model 358.796480 blade not cutting. Am I doing something wrong? Seems like looks OK but still not cutting.
Assuming the obvious that the motor is turning, the only thing that would keep it from cutting is that the nut holding the blade is not tight enough or the sping washer between the nut and the blade is missing or on backwards. The correct orientation of the spring washer is so the inside surface around the hole contacts the nut, and the outside circumfrance of the washer contacts the blade. P.S. the nut is tightened very tight.
May 18, 2014 | Garden
Replacing husqvarna edger blade
Always try to use genuine parts as cheaper parts can be very poor quailiy and some times dangerous.
Jun 02, 2017 | Husqvarna Garden
Change an edger blade
Start here to find User's Manual. Sometimes the nut/bolt holding the blade on is a Left Hand thread and requires CW turning to loosen and remove. Not sure on this model.
Aug 12, 2012 | Poulan Pp1000e 7-inch Pro Lawn Edger...
Unable to get nut off of a craftsman convertible edger.
Lock on the blade with a pair of ViseGrip Pliers, then try turning the nut, they are installed quite tight, also try clockwise, maybe left hand nut.
May 25, 2010 | Craftsman Convertible 25cc. Gas Line...
Is the nut for blade removal right hand?
on blade removal it is opposite. Lefty tighty, righty loosen
Mar 29, 2010 | Mtd 25B-520D200 CA Gas Lawn Edger
Can't get the nut off.. is there a secret to blade removal
Hi these are usually the opposite way to which the blade turns but you may have to use a rattle gun to remove this. If you have a look at the thread you should be able to determine which way it comes off. Just remember to fix the blade so it wont turn and take your fingers off.
Aug 03, 2009 | Garden
I have the Toro edger/trimmer combo - which way does the edger blade bolt turn - I tried counter-clock-wise it won't budge. Also how to the LOCK the blade from turning??
on blad removal the nut goes opposite to tighten, lefty tighty, righty loosen. Put a metal wrench or rod in between the blade and the guard to keep the blade from moving.
Jul 14, 2009 | Toro Lawn Mower With Toro Power Tools
Can't remove the nut holding blade on. Which way do I remove
Get some WD-40 and spray the area around the nut then let it sit for a few hours. This will get into the threads and loosen any rust that is compounding your problem. Now get a good wrench and look directly at the nut. Left is loose and Right is tight.
May 21, 2009 | Craftsman Gas Mini - Tiller/Edger
How to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Apr 09, 2009 | Garden
Garden Logo
165 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
