Question about Toshiba e-Studio 200 All-In-One Laser Printer
Toshiba Studio 200 CP
Hi.. When I try to print labels in this machine, it gets very, very hot as if the labels will melt and the machine jams if I try to print more than one sheet. The sheet comes out almost too hot to handle. The labels are marked for "laser" printing and are clear.
Any recommendations?
Use the manual paper feeder, and set the paper type labels
Posted on Jun 18, 2008
My Toshiba e studio 352, when i copyed 200-300 pages then suddenly error occour e 010 then the machine does not copy a single page, cooling/stop machine 10 or 20 minute then i start copying again
sounds like it got a bit hot
tray holds 500 pages doesnt mean it can copy 500 in one session of copying time
Toshiba Studio 352 Copier Studio352
cant see it but
I was looking at the specs to see how many copies per hour it is rated
Jul 03, 2016 | Toshiba Office Equipment & Supplies
When I go to print Avery labels 5160 i get the error code load ssf 024-0969. I can print all other documents
Hi, Brad;
the label with the adhesive on the back when it go through the heating unit it goint melt will coming off and stick on paper path it cause paper jam, sugest print label use inkjet printer.
Oct 31, 2013 | Dell 2155cn and 2155cdn Color Laser...
My toshiba e studio 350 machine toner is very high.how could adjest devoloper and toner ratio please help.
05 turn on copier hold for 5 sec will go to test mode 200 print will start developer calabration going down in numbers adds less toner go down about 50 in numbers so it wiil stop adding then press set this is done all on touch screen except for 05 and 200 use keypad
Feb 07, 2013 | Toshiba e-Studio 350 Copier
How to replaced developer in toshiba e studio-352 will i had try with 200 but still machine value is showing error
After replaced the developer material, u need to perform auto toner adjustment 05-200 ( take out the toner )
Dec 03, 2012 | Toshiba e-STUDIO 352 Black and White...
I have Toshiba photocopier, Studio 455. i want to print one page label paper. Should i use a bypass, which i tried but did not work. Tell me how.
If you are printig labels you MUST use the bypass tray on the right side of the copier. You mst specify heavy or card stock/label paper so it will fuse properly. I can't tell you why the tray does not work? But labels must be run thru the bypass.
Good Luck and Thank You for using Fixya.
Sep 14, 2010 | Toshiba e-studio 455 Copier
Call for service
It has self-detected that it needs to be serviced.
Get it serviced, or replace it.
Apr 05, 2010 | Toshiba (GD-1010) for e-studio25S, 16S,...
Trying to print on laser photo transfer paper, but printer seems to be too hot for it - is there any way to print on this transfer paper?
i tried to print on laser paper too but fuser is too hot. its melting the paper and getting jammed right? i got tired of printing on laser paper and converted to inkjet paper. this is much easier
Jul 14, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
Labels only jam when printing from file
I cannnnoooooottt believe what I am reading! If you are going to use labels on a laserjet, you need to get thermal labels! The other cheap labels are made for inkjets, matric, or daisywheel printers. The laserjets have heat rollers that will melt plastic. It will melt the gum on the non thermal labels and get them everywhere!!
Master Rod
May 08, 2009 | HP Color LaserJet 8550dn Printer
Paper jam on my toshiba 2060 model
Exactly where in the machine does the paper jam??If it jams when you hit the print button, try cleaning the paper feed tires with WD40.spray it on a clean cloth, clean the feed and pickup tires thoroughly and make sure to get ALL of the WD40 off the tires before using the machine.If you take the paper cassette out and look with a flashight you should be able to identify the paper feed tires.
Mar 24, 2009 | Toshiba 2060 Copier
Toshiba studio 281C problems
You should be able to print on both, but I wouldn't advise it at all. The envelopes are going to jam a LOT and you WILL eventualy get a label stuck inside the machine. Possible....yes. But I don't recommend it. :)
C
Jun 02, 2008 | Toshiba Estudio 200L Copier
Toshiba e-Studio 200 All-In-One Laser Printer Logo
248 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
pkwc
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
