Question about Hotpoint Refrigerators
Hotpoint Quadrio Fridge Freezer is not working. The light is on - but the fridge is at room temperature even though thermostat is on maximum. Can you help?
  • 17 Answers
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Posted on Dec 10, 2007
murdozzz2
  • 75 Answers
SOURCE: HOTPOINT FRIDGEFREEZER
i i you will need to replace your defrost sensor and thermal fuse
this is how to do the repair and not have to defrost and leave doors open for 48hrs time after time
Posted on Dec 23, 2007
bobotfel
  • 236 Answers
SOURCE: brand new refrigerator...freezer works great, fridge does not
Try to defrost the unit, if it wont work check the air vents if air is present. Check also if some of your stuff may be obstructing the air vent.
sample of air vent location :
Posted on Apr 07, 2008
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Posted on Dec 27, 2008
woodchuck789
  • 4059 Answers
SOURCE: fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Mar 11, 2010
Testimonial: "Thanks, I have checked that, but the vent at the bottom of the fridge section is a rigid plastic grill, which doesn't, nor looks like it should move. "
Hotpoint frost free fridge freezer the fridge not working but freezer is
Hi Reginald
Most refrigerator / freezer units chill the fridge area by venting some fraction of the very cold air from the freezer into the fridge compartment through a channel that has a mechanical air valve in it. In this way, it can control the chilled air flow, and aim for the set temperature, all the way down, in some cases, to freezing, or even colder, on the fridge side.
That vent unit, depending on your model, sill be somewhere in the wall that separates the freezer from the fridge. What can happen is that moisture condenses into the louver that slides to control the airflow, it freezes, and then system is stuck, since it's cold on the freezer side, and this keeps the louver frozen stuck. If that is the case, shutting the unit off for a while may recover function, though getting it to where ice is melting in an interior wall may be more risk of food spoilage than you'd want. Otherwise, use a search engine to look for 'how to test freezer / refrigerator vent in make/model', and you'll likely come across all sorts of youtube and step-by-step tutorials.
Good Luck!
D
Nov 30, 2015 | Hotpoint Refrigerators
Hotpoint quadrio fridge isnt cooling but freezer is can i start its defrost cycle manually?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 10, 2011 | Hotpoint Refrigerators
Hotpoint RLA30s Freezing!
check the ptc overload relay it could have stuck and is supplying power to the compressor all the time even if the thermostat is off,its on the compressor body where the wires go to the compressor
May 11, 2010 | Hotpoint RLA30 Compact Refrigerator
My hotpoint quadrio amber lights at the top of the fridge door are flashing is this anything to worry about - they are indicated with the words ''super cool'' and ''super freeze'' (sorry but cant find...
my hotpoint quadrio is causing problems the fidge part is no longer cooling the light is coming on but thast is all what can cause this. can anyone help
Feb 20, 2010 | Refrigerators
Will my mothers new fridge freezer work out in the garage
This is from the hotpoint web site.
If the room temperature drops below 14°C for an
extended period of time, the ideal temperature will not
be reached in the freezer compartment and food
preservation will be reduced.
You can read the manual here if it will help you.
http://www.hotpoint.co.uk/hotpoint/_pdf/manuals/19504293107_UK.pdf
Good Luck
Jan 11, 2009 | Hotpoint Refrigerators
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Refrigerators Logo
110 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
