Question about Maytag SAV2655A Top Load Washer
Model #sav2655aww leaking water underneath maytag toploading washing machine
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Posted on Oct 10, 2008
SOURCE: water leaking under washing machine
Had service technician come out to inspect. Problem determined to be the bearing and seal/belt. Estimated cost $350.00. It cost $450 when new....Went out and purchased a Speed Queen. Hope to have better luck.
Posted on Dec 31, 2008
dh1200s
  • 335 Answers
SOURCE: I have a maytag 6800 toploader. Water from bottom
If you feel OK to troubleshoot the Service Manual will give you some possible leak points to check. If you want to troubleshoot you beyond basic inspection you will need to remove the front panel and observe where the leak source might be. Worse case a tub seal issue. Easier fix would be a leak in the drain line; tub to drain pump/drain pump to output drain hose, one poster recently reported a cracked drain pump housing as their leak source. Here is a link for the manual.
http://www.fixya.com/support/r1655507-found_service_manual_neptune_top_load
The one leak source I would be concerned with is a leak described around the clutch pulley on page 28. If that is your leak source it’s a big project and you may need think about a service repair (BIG$ for labor but see if you can get a no cost quote) or a replacement machine if it’s not cost effective to repair. If you go the replacement direction call the Maytag CSV phone number at the end of the manual and complain, I got them to offer up a 25% rebate by talking to a supervisor on their Whirlpool, Amana, Maytag product line (don’t shoot the messenger). I’m a DIY’er and if I can’t fix this thing for under $300 with ebay parts I would move on. But let’s go one step at a time and try to ID the leak source.
To help you remove the front panel see page 33 Pic for the putty knife insertion point to raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base.
See page 41 for front panel removal don’t poke around in there with the power on just view for a water leak with a flash light while the machine fills in a Quick Wash cycle and as the machine proceeds through the wash cycle. Safety first, please follows the safety guide lines in the SM. Post again if you have questions and I’m sure I or other forum members will chime in for support. Good Luck.
Posted on Mar 04, 2009
  • 132 Answers
SOURCE: trying to replace the motor on my maytag toploader washing machin
Hi There,
On the bottom of the front panel there should a philip head screw right above each fron adjusting leg.
Remove these 2 screws. Open the cover and lift up on the front between the drum & cover there are 2 metal clips holding the top down. Swing the top up and remove the front panel. The motor is right in front on the lower left. Let me know if this helps and thank you for using FixYa!
Posted on Mar 30, 2009
  • 6 Answers
SOURCE: top loading Maytag washing machine is overflowing
water level switch is bad
My kenmore elite topload washer is leaking underneath washing machine leaving a puddle whats causing this?
depends. first and foremost, I would fill the unit up about halfway with water, with tub being empty of any clothing. Tilt the machine back where you can look underneath it real good. see if you see any leaks with it half full of water. If you don't see any leaks, put the unit back on all fours, and put it into drain/spin. After tub empties of water, tilt unit back again and check for leaks near the drain pump and hose. If you need any further assistance, look for me on 6ya
Nov 27, 2015 | Kenmore Washing Machines
Maytag washing machine leaking
it could be coming from different sources. Most likely is the hose. You might need to replace hoses that bring water to the machine, but first check that they are not loose or have cracks that could cause these leaks to occur.
Jan 05, 2014 | Maytag Washing Machines
Leaking water Maytag Washer
If the connecting hoses is not a problem then it is probably be the pump present inside the machine.It helps in moving and draining the water.If it is not working then such problems might arise.It is best that you ask the plumber to replace it instead of you doing it
yourself.
Apr 10, 2010 | Maytag PAV2300 Top Load Washer
Trying to put belt back on magtag sav2655aww. do
Maybe this breakdown250 will help, not sure, hope so.
Nov 11, 2009 | Maytag SAV5710 Top Load Washer
How can we troubleshhot a Maytag toploader that
You probably have something stuck in the drain pump. You will have to remove the hoses from the pump to extract it.
I can not be more help without a model number. Maytag builds several styles of top load washers. They all access differently.
Aug 30, 2009 | Maytag Washing Machines
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Water leaking under washing machine
Dec 29, 2008 | Maytag SAV2655A Top Load Washer
Washer won't fill
First take off the fill hoses from the washer, make sure the screens on the washer valve are not clogged. Next heck nd make sure you have water coming from the hoses. Finally if still no water. you may ned a new fill valve. Hope this helps , Dave www.washermd.com
Dec 22, 2008 | Maytag HAV3460AWW Top Load Washer
No hot water for a Maytag topload washer
Turn the water off and disconnect the hot wat hose from the spigot and the machine. There should be a screen filter in one end. Check to see if the screen is clogged. If it is then replace it. If not then replace the water valve
Jan 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag SAV2655A Top Load Washer Logo
187 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
