Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
I have a side by side with ice maker model # GS6SHAXLS03. The ice maker has stopped making ice. The lever that keeps the ice making door from opening remains popped out. How can I fix this? thanks!
  • 1314 Answers
SOURCE: ice maker arm
you can take out the screws that hold the ice maker to the freezer wall unplug the ice maker take off the front cover remove the four screws holding the motor module which is brown take that off and reattach the shutoff bail arm and reassemble. their is a gold forked metal piece in there the bail arm has to be in that fork .or you can replace the ice maker
Posted on Jan 09, 2008
rpbuice
  • 161 Answers
SOURCE: Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Posted on Dec 21, 2008
jumptrout51
  • 3361 Answers
SOURCE: ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Posted on Mar 23, 2009
SOURCE: Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Posted on Apr 16, 2009
Sea Breeze
  • 4654 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
Ice maker is not producing ice. Water dispenser is working fine. On Whirlpool Gold Model #GS6SHAXLS03
If the ice maker is not refilling with water after its last harvest that points to the=> W10408179 Water Inlet Valve. If the ice maker just sits there with ice and does not empty into the ice bucket we will need to test the 4389102 Ice Level Control
Instructions on how to test can be found HERE If you have something else happening here please let me know, Sea Breeze
If the ice maker is not refilling with water the side of the water control valve that fills the ice maker is defective and you will still get water from the dispenser. The parts I listeed above are for your GS6SHAXLS03 refrigerator.
Oct 15, 2013 | Whirlpool GS6SHAXLS Side by Side...
The ice maker stopped working, we have checked the water hose and their is water coming from the dispenser at the front of the door.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 29, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Will not make ice
The ice maker has completely stopped producing ice.
Mar 29, 2010 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Model ED25DQXXN side by side with ice maker running.
either lift the arm up and this should stop it or u can unhook the plug for the icemaker thats about ur only 2 ptions
Feb 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator ice dispenser no longer workds
HI, the Ice maker control module will need to be replaced in your unit asap if possible. this module controls and initiates the actions when the lever is depressed.
Jun 05, 2009 | Whirlpool GS6SHAXLS Side by Side...
There is a smell from outside the frige
check drip pan for smell see if ice maker lever switch is up for noise
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Keeps making ice, i can't seem to make it stop.
You have an emitter and receiver in the freezer section...Actually when you slide the lever on the right side in the middle of the freezer section, you break the beam...and it is suppose to stop the ice maker from harvesting ice anymore. If this shut off device fails, it can fail in the on position and continue to make ice. Replace this assemlby sold in a kit and you will be fine. In the mean time, if you can remove the ice maker head and unplug it, that will stop the ice until you can replace the emitter and receiver assembly. You can also shut the water off but the ice maker will continue to operate, just not dispense ice. If extending and waiting on this repair you should disconnect the ice maker.....
Mar 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker won't stop making ice
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
Dec 23, 2006 | Kenmore 55693 Side by Side Refrigerator
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
120 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
