Question about Dell OptiPlex GX620 PC Desktop
Flashing amber light on my optiplex gx620 have just replaced psu
  • 1,179 Answers
Your Computer is not POSTing, try going through my guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!! this will diagnose the faulty component and get your system running again.
damnor01
Posted on Nov 14, 2010
Hi, on most Dells a flashing amber light on the power button indicates a problem with the PSU or a short on the main power rail, if this is the case you should have 2 flashing lights as well, 1 & 3.
May 05, 2014 | Dell OptiPlex 3010 MT Desktop Computer
Del 320 optiplex orange lite blinks won't boot up
For the Optiplex 320, a flashing amber light with no sound indication can mean 3 things.
1) Your power supply has failed
2) Your motherboard failed, most likely from a bad capacitor.
3) The front panel board (where the power button is located) is faulty or not connected properly.
I've worked with 10's of 1000's of Dell Optiplex's over the past 8 years and the flashing amber light is well known as a tell-tail sign of one of those three failure. Always start your trouble shoot with a PSU tester, then inspect the motherboard for domed or split/leaking capacitors...then on to the front panel which would require another panel and ribbon from the same model.
Jan 25, 2014 | Dell Optiplex GX280 (99301) Motherboard
Could not power up gx620, tried replacing PS still could not turn on, thought it might be I/O panel but still not on what next
The amber light within the Power Button indicates a PSU or Motherboard fault. If you have changed the PSU and it is a known good unit, please check the plug that connects to the Motherboard again. Assuming that this is ok, it may unfortunately be that the motherboard capacitors have blown (a well documented failiure).
Sep 21, 2017 | Dell OptiPlex GX620 PC Desktop
Dell Optiplex 775 Power light, is flashing, wont turn on. I have recently replaced the PSU with a brand new dell one, as i was getting booting problems, since putting the new one in, i just get the...
could also be a ram stick that ate it. Also some of the older mother boards dont have a 12 volt supply that new cpu chips need might check that as well. Make sure the power supply is turning as well as cpu
Sep 03, 2011 | Dell Optiplex 755 Minitower Desktop...
Dell optiplex gx150 power button just flashes - help?
System seems to be in hibernate or standby mode and frozen in that state. Hold dosn power button for 5 seconds or until all signs of life shut down. Wait about 30 second and power up the system.
Jul 25, 2009 | Dell Optiplex GX270
GX620 Powre Buttion Flashing Yellow
the amber light flashing is a power issue, this is from the Dell Manual :
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
Ensure that the processor power cable is securely connected to the system board (see page 73).
I suggest you unplug the machine completely from the powersupply wait a few seconds and plug it back in, sometimes this will help with power issues.
Jan 15, 2009 | Dell OptiPlex GX620 PC Desktop
I have a dell optiplex gx620 that won't turn on?!
Dell Optiplex GX620 has a failure power supply. A some of the capacitors inside it are poor quality :( .In this case is an emergency procedure to start power supply (ie. for backup) : make a temporary shortcut between green and black wire in main mo-bo connector (24 wires) , and use normal Power On button. When main fan starts remove temporary shortcut.
Oct 31, 2008 | Dell OptiPlex GX620 PC Desktop
Powerbutton flashing yellow
If the main power button LED is flashing or solid yellow, this could indicate a hardware problem.
Was it running good before?
Are the diagnostic LED lights all green?
Here is what dell says:
If the power light is blinking amber  —
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Do you remember what the BSOD said?
Oct 22, 2007 | Dell OptiPlex GX620 PC Desktop
Dell OptiPlex GX620 PC Desktop Logo
337 people viewed this question
Alun Cox
