Question about GE Profile Harmony DPGT750GC Gas Dryer
Dryer won't dry clothes - GE Profile Harmony DPGT750GC Gas Dryer
    Problem Solver:
  • 12 Answers
In alot of cases, it's your dryer vent. Does it have enough airflow? Is it clogged up? If you're using the foil flex vent or worse, the plastic vent, then it may be crushed preventing the proper airflow needed. First thing first, pull your dryer out and check the venting. Take it off by removing the clamp, either it is a spring clamp that you can remove with your fingers or its an auto clamp that you will need a crewdriver for. If there is alot of buildup in the vent then it needs to be replaced. Look into the back of the dryer, is there anything in the dryer itself that is blocking airflow. I have seen may times where money, paper, even dishrags get sucked down in the venting area and constrict the airflow. If your venting does not go straight out of the wall then you may need to check the rest of the venting that runs throughout the house. There are service people that will come out and clean these for you, however not sure of the cost. Depending on your sitaution, you may be able to replace this yourself as it is quite easy. I have seen people with 30-40 ft length venting and the airflow pressure just isn't there no matter what dryer you're using. If this is the case, then your venting needs to be checked often.
If you are crushing your vent then I would suggest going to the local Home Depot, Lowes, etc.. and buy the semi rigid venting with a swivel elbow. This vent is very hard to crush and with the swivel elbow, it allows you to move the dryer back and forth without popping off the vent if you ever need to get behind of it for cleaning, etc... This vent is also top of the line and is mandated by major install companies throughout the nation. The only drawback is that it may stick your dryer out another 1-2 inches, but from a safety standpoint, it is the best on the market.
Unfortuantely, if it's not the vent then a service tech would have to be called to come and check it out. With the Harmony Profile series, I wouldn't call just any mom and pop service company. That series has very unique parts so I would get someone recommended by the manufacturer. Call GE at 1-800-GE CARES, they should be able to help you regardless if its under warranty or not. GE keeps parts for 30 years on every model product that they make, I couldn't see them not trying to help. Good luck.
Posted on Nov 30, 2010
Dryer heats but won't dry clothes completely
Inspect and clean the dryer is what I would do. most times it is a faulty blower wheel causes your symptoms.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 16, 2013 | Amana Dryers
the heating unit must have been broken. go to near by mechanic shop.
Jan 31, 2013 | Dryers
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
My dryer won't dry
This particular dryer has a blower wheel that is plastic. Over time the wheel gets wobbly and loose. If you hear a rattle that could be the loose blower wheel. This causes the dryer to overheat and take 3 times as long to dry clothes because it trips the limits. To get into the dryer and find out you need to first remove the door. Nice how to video from Angel:
Oct 13, 2012 | Maytag Neptune MDE5500AY Electric Dryer
My cloth dryer won't dry. It is not hot.
is it gas or electric, vent could be clogged. could need starting device. solonoid, or ignitor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/phillip_77d32603f8052503
May 20, 2012 | Whirlpool Dryers
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
Whirl pool duet dryer not drying clothes
Inside the door under the filter housing is 2 strips that sense wetness. If they have dryer sheet goop on them they won't sense moisture. the dryer will therefore thank them clothes is dry. Clean them sensors with windex and party on!
Nov 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Dryer not drying clothing.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 24, 2010 | GE Profile Harmony DPGT750EC Electric...
It seems like the burners are not all lighting. Maytag Epic Z gas
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
GE Profile Harmony DPGT750GC Gas Dryer Logo
77 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
