Question about Schwinn 430 Elliptical Trainer
I have the Schwinn 438 elliptical trainer and need to get inside the rotating wheel for a repair. I was told I will need a crank puller to open this up, but I see different sizes available on the market. Can you tell me what size of crank puller is required to gain access on this piece of equipment?
3 Suggested Answers
  • 103 Answers
SOURCE: I am trying to remove the covers on my Schwinn 418
Hello there. Unfortunatley there is no way other than removing the crank arms. You do need to remove the nut on the axle and you will need a crank puller. The puller is available at any local bicycle shop for around 10-15 dollars.
Good Luck Tim
Posted on Feb 02, 2010
maxtreadmill
  • 832 Answers
SOURCE: tunturi elliptical cross trainer error e-2
Most E 2 code means communication problem upper and lower boards you will need to check connector. for further info go to http://accellfitnessna.com or Email a.parker@accellfitness.com they will help you they Tunturi Distributor of North America
Posted on Apr 11, 2010
Schwinn 450 turns off after 5 seconds
The symptoms seem to be either stopping or displaying the "keep striding" message after 5 seconds, depending on the program/course in play. The most likely reason is the speed sensor is not working. A call to Schwinn support suggested opening the frame by pulling the crank to get to it. In my case, I found a simpler step to try first, and in my case it resolved the problem. Note: this may not be applicable to all models - I have a 450.
Remove the two screws holding the storage bin (at the base of the console mast) in place. See if the speed sensor is properly positioned. I found that it had become detached from the bracket and was just lying on the inside. I glued it back to the bracket (using a flexible adhesive good for plastic and other materials), and lo and behold, everything is working!
If this doesn't work, then your speed sensor is probably bad and it's on to the full and more lengthy repair. You will need to get a crank puller for a tapered crank from a bicycle shop to complete the job. Talk to Schwinn support; they were really good the two times I called.
Here are a couple of pictures showing the storage bin removed and the correct position of the speed sensor.
Mar 08, 2014 | Schwinn 450 Elliptical Trainer
My Schwinn 430 elliptical makes a clunking noise when pedalling backwards but not forward. What is causing this?
I have a iron man cdt elliptical that was clunking . I found a shaft on the end of the crank was slipping in and out, inside the bearings. I shimmed it and retightened the retaining washer which prevented it from slipping . Smooth as silk now. It was very frustrating because all seemed tight at first.
Nov 10, 2012 | Schwinn 430 Elliptical Trainer
Need manual for schwinn personal trainer 405 tread mill
Hello Brend
Please download the assembly manual for Schwinn® 430 Elliptical from the link provided below :
http://download.dfxi.com/supportdocs/AM/Schwinn/SCH_430_AM_RevB_web.pdf
Please download the owners manual for Schwinn® 430 Elliptical from the link provided below :
http://download.dfxi.com/supportdocs/OM/Schwinn/SCH_430_OM_RevA_web.pdf
Oct 10, 2011 | Schwinn 430 Elliptical Trainer
While using the elliptical there is a persistent knocking noice in the fly wheel area with each rotation. It seems to be at the bottom of the rotation. How do I fix it?
I just fixed the problem on my 430. Somewhere on this forum someone suggested that the dollar size cover on each side of the flywheel cover be removed and the bolt tightened. You will need a socket wrench. It took less than 5 minuted and whamo. Problem solved. Thanks to the individual with that input. Good luck
Jan 10, 2011 | Schwinn 430 Elliptical Trainer
I am trying to remove the covers on my Schwinn 418 elliptical trainer. The covers hang up on the crank/flywheel. The repair manual says to use a crank puller. Is there another way. If not what type of...
Good Luck Tim
Jan 31, 2010 | Schwinn 430 Elliptical Trainer
Error code 1 on schwinn elliptical 418 how do I fix it. I have replace batteries and unplugged unit. Error 1 shows up as soon as I turn unit on.
E1 error seems to indicate that the servo which controls the elliptical resistance is stuck. Here is how I fixed this (without using a "crank puller", which would be quicker by far).
You will need a very short phillips screw driver (snub nose), a long phillips screw driver, an allen key set, and crescent wrench.
- Remove the batteries from the unit.
- Remove the screws from the plastic housing (with the long phillips screw driver) on the left side. Do not forget the phillips screws at the front - they are smaller screws so don't mix them with the others. This will allow the plastic housing to flex and move around, but not come entirely off.
- Using the crescent wrench, remove the nut holding the left pedal to the crank. Carefully note the order of the washers on the crank attachment.
- Using the allen key, remove the little pedal attachment piece on the left crank arm.
- Using the short phillips screw driver, carefully reach inside the plastic housing on the top and remove the four screws holding the plastic plate on the outside of the fly wheel/crank. You will need to rotate the crank wheel to reach each of the four screws in turn on the inside of the case.
- Pull off the plastic cover for the wheel.
- Reinsert batteries and gently help the revealed cable (bottom) retract the magnet plate. In my case, the servo worked fine again after helping it retract the magnet plate that was somehow stuck/wedged.
Reverse steps to re-assemble.
Jan 16, 2010 | Schwinn 430 Elliptical Trainer
The flywheel is becoming uneven on one side and making noise while rotating. I don't see any where I can adjust the bolts. Any tips?
reove the center black plug and tighten bolt. If this problem has persisted then the crank hub shaft could be worn and need to be replaced. If the plastic is seperating then a screw inside has come out or broken. They are accessed by removing the covers from the opposite side. you may be able to get to them without having to purchase a crank puller and remove crank weldment.
Apr 30, 2009 | Schwinn 430 Elliptical Trainer
Need to replace the drive belt on my Schwinn 430 Elliptical
http://download.dfxi.com/supportdocs/SM/Schwinn/SCH_430_431_450_SM_RevC_web.pdf
Follow this link for step by step instructions. Note you will need a crank puller which you can purchase at most bike shops. remove both covers then crank weldment(discs).
Jan 19, 2009 | Schwinn 430 Elliptical Trainer
Schwinn 430 Elliptical Trainer Logo
173 people viewed this question
Top Schwinn Exercise & Fitness Experts
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Bill Boyd
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
