Question about Panasonic Vacuums
My panasonic MC-E4103 bagless vaccum cleaner stops after 20 seconds instantly have to wait for few hours to start again
reddevil6
  • 1673 Answers
SOURCE: How to change belt on Panasonic MC-E464 vacuum cleaner
Remove the bottom plate, the belt goes fron the brush rol to the motor shaft or pulley.
Posted on Feb 23, 2008
  • 389 Answers
SOURCE: Filters for panasonic vacuum cleaner MC-E468
Hi! Sometimes really hard to remember which of these models is which, so please forgive me if this is not a complete solution.  I'm pretty sure you will find there are two filters.  The first is a foam filter, and is located at the bottom of the bag compartment.  It pulls out to the front, and is washable (of course it must be completely dry before re-use).  The second (and here I'm on less secure ground) is a HEPA filter, and is located behind a removable panel on the front of the bag compartment door.  The HEPA filter is not washable, but rarely if ever needs to be changed unless the machine has been used for vacuuming a lot of extremely fine dust. I hope this helps, and I value your feedback. Please remember to rate my response.  Good luck!
Posted on Feb 24, 2009
ukvacfan
  • 328 Answers
SOURCE: my bissell bagless vac has no vaccum. ihave
Have you checked the main dust channels from the hose leading into the bin? Have you brushed clean the main filter cones? Make sure all the filters have been properly cleaned *(and if washed make sure its completely dry before puttng back into the machine.) Also please check the beater bar, especially the dust channel behind it as it can get clogged badly.
Posted on Mar 06, 2009
  • 8 Answers
SOURCE: My Bissel Vaccum cleaner is making strange noise!!
call the 1-800 number on the back
Posted on Jun 11, 2009
  • 6 Answers
SOURCE: I am looking for the filter for the Eureka bagless
There should be an toll free # to call for eureka and they can direct you to the nearest authorized eureka service center in you area. If its a new model places like wallmart wont stock it. There are so many vacuum makes and models its impossible for any one business to stock every single bag, belt, filter etc. for them all. But a decent vacuum repair shop should be able to get it for you.
Posted on Oct 26, 2009
How do I improve suction of the Panasonic mc cl310 vacuum
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try. You can check the hose and canister to make sure nothing is lodged in them. If nothing is there and it does not fix the problem, your issue could be related to your brush-roll. Check your brush-roll to make sure that nothing is interfering with it. If that does not solve the issue, the next area that should be checked is your vacuums filters. Filters should be replaced every 3 to 6 months for optimal performance.
You can purchase direct your replacement Panasonic vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Panasonic MCCL310 MC-CL310 MC CL310...
Panasonic optiflow upright vaccum
Hello, Put the vac on its side and remove the screws holding the cover plate on. This exposes the beater bar and belt on the side. Pull the beater bar out and take the belt off. Reverse this to put the belt back in place.
May 30, 2014 | Panasonic MC-UG323 OptiFlow Upright Vacuum...
Upon turning on vaccum it starts ok, but a second later it spits out some dust dirt out and does not vaccum. We hear like a poof suction when this happens. Cleaned all the tubes around it, but thinking...
The poof suction sound you hear is most likely the suction release valve opening up because there is a clog or restriction somewhere. If you don't feel qualified it is usually a better idea to take it to a qualified repair facility.
Oct 26, 2013 | Panasonic Bagless Upright Vacuum Cleaner ...
Hi, i have a panasonic eco max, the brush has stopped going round, the belt is as new and brushes clean.suction good from hose. Any ideas please? thank you
The brush on this model is controlled by the on/carpet/floor switch and will only work in the carpet position. If the suction motor is running then it could be the roller brush motor, but it's more likely to be the microswitch which stops the brush motor when the handle is returned to the upright position.
Dec 03, 2012 | Panasonic Mc-Ul594 Eco Max - Bagless...
Panasonic vacuum cleaner MC-5030 stopped and don't work
Unplug, check if brush has cord wrapped. Check for fuse, if applicable.
Check power lead in another supply socket. Check for reset button, if applicable. Contact Panasonic technical support for suggestions before heading to service centre.
Jun 17, 2012 | Vacuums
When the switch is turned on the vaccum cleaner starts running instead of,when the hose is connected. removed the earth lines from the unit and truned on the vaccum cleaner. It did the same. What might...
Dirty switch at vac where hose connects go to radio shack get some tuner cleaner spray. spray this switch and plug hose in and out a few times spray again see if this works
Feb 26, 2011 | Broan-NuTone CV554 Cyclonic Bagless...
Vaccum problem
No sound at all? or the motor runs but no vaccuum?
did it stop while using it? might have overheated due to dirty filters... strange that the light comes on but no motor at all... that would suggest to me that the motor is shot...
Here is a link the the manual.. there is no reference to any user accessable fuse or breaker...
Peace,
Mar 07, 2010 | Bissell 6594 PowerForce Bagless Upright...
Bissell vaccum cleaner just turned off why
Ive had this problem before. I have never figured out what caused it. I let it be for a few minutes and it started working again.. weird.. I'd just let it sit for a few then try it again.
Mar 02, 2010 | Bissell 6594 PowerForce Bagless Upright...
My vaccum cleaner doesnt show the gathering dirt in the transparent section while vaccuming
my vacuum was working for a few minutes and just stop in middle of doing its job and no problem with electricity
Feb 09, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Vacuums Logo
41 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
