Question about Logitech QuickCam Pro 5000 Webcam
My logitech quickcam 9.5 webcam is not compatible with windows 7
sandrew
  • 2961 Answers
SOURCE: Logitech QuickCam STX vista compatibility?
when you were installing the software did a taskbar pop up appear and tell you that hardware was found, and then proceeded to install the cam and inform you that the Logitech STX is now installed and ready for use? If not then the cam may need to be tried in another usb port as of yet it has not been recognised by windows. Also if this is being used on a laptop, sometimes there is not enough power amps being sent be the usb port to recognise, again trying a different port may solve that. If all else fails re install the software again, but make sure windows is allowing the cam to work, as sometimes there is an updater programme that works in conjunction with the cam to update drivers etc, this will probably be being dissalowed by either windows or your internet security programme and any part of the software that is being blocked may be stopping your cam also.
Posted on Jun 11, 2007
  • 2851 Answers
SOURCE: quickcam 8.1.3 vs windows 7
Download the software for the OS you used the camera on before
Right click on the shortcut icon on the desktop and select 'Properties'
Select the 'Compatibility' tab
Check the box 'Run this program in compatibility mode for'
Use the drop down menu to find the OS you successfully used the cam for
Click 'Apply' and 'OK'
Trial and error the other settings on this page - I think I checked 'disable visual themes' but not sure now ( Windows 98 was a long time ago !! )
Posted on Jan 17, 2010
  • 10 Answers
SOURCE: can,t install my quickcam in windows 7
The most likely reason it isn't working is because the cd you got has older drivers which don't support windows 7, so you need to go on to the logiteck website and get the latest driver for it.
Posted on Feb 01, 2010
SOURCE: QuickCam Pro 5000 P/N 861205 is not compatible with Windows 7
You need to download the drivers (v11.1 for another OS you can reach. (http://www.nodevice.com/driver/QuickCam_Pro_5000/get65050.html) On the second computer, start the instalation, but do not proceed, just leave it open.
On Vista, go to User/[YOurname]/Appdata/Local/Temp/Logitech-????
on XP find the same folder in teporary files (I'm not sure where to look for it) and copy the Drivers folder to your WIN 7 machine.
Run the setup.exe
Posted on May 18, 2010
SOURCE: is not compatible with windows 7
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Posted on Dec 06, 2010
Not wroking on my windows 7 ultimate
Neither Logitech nor Microsoft wrote drivers for this webcam for Windows 7.
As a result, it is not supported by Windows 7 and will most likely never be supported.
It's my suspicion that Microsoft gets kick-backs for not supporting old hardware so the peripheral makers can make money selling new equipment.
Apr 04, 2011 | Logitech QuickCam Express Web Camera
Logitech Quickcam 902
If you have good experience with this cam in an earlier OS try running it in Compatibility Mode.
Download the software and right click on the webcam icon.
Select 'Properties' and then click the 'Compatibility' tab.
Check the box to run in CM and select the OS
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
Click on your cam for that model's support
May 26, 2010 | Logitech QuickCam Express Web Camera
QuickCam v11.8
I have the same model, don't think it is compatible with Windows 7 (nor with Vista 64-bit for that matter). :(
Maybe Logitech will still update the drivers, but I am not counting on it.
Apr 02, 2010 | Logitech QuickCam Communicate Deluxe...
Will the logitech quickcam stx work with windows 7
No, you can install it now. There should be no issue with upgrading later.
Only thing I would suggest is that you check if the webcam is compatible with Windows 7, but I think almost all Logitech webcams are, so no issue.
Dec 28, 2009 | Logitech QuickCam Communicate STX Personal...
I have a quickCam Pro 9000. I tried installing it
HI,
Logitech has released new cam drivers for windows 7.Please click on the below link to download it.Once you click on the below link just click on run.After it is finished downloading just follow the onscreen instructions to install the drivers for windows 7.
http://www.logitech.com/pub/techsupport/quickcam/lws110.exe
Thank You for using fixya
Nov 11, 2009 | Logitech QuickCam Pro 9000 Web Cam
Windows vista home premiun
Please click on the link mentioned below to download the drivers:
Windows Vista Multilingual 32-bit
* Title: QuickCam v11.1.0.2030
* Software Version: 11.1.0.2030
* Post Date: 8/7/2007
* Platform: Windows Vista
* File Size: Approximate download size is 30.7 megabytes.
http://www.logitech.com/pub/techsupport/quickcam/qc1110.exe
Windows Vista Multilingual 64-bit
* File Size: Approximate download size is 36.3 megabytes.
http://www.logitech.com/pub/techsupport/quickcam/qc1110_x64.exe
Also visit this website:
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/LOGITECH/Logitech-QuickCam-Pro-4000.shtml
Thanks
Aug 22, 2008 | Logitech QuickCam Messenger Web Camera
Also visit this website for other Windows driver:
Thanks
Aug 21, 2008 | Logitech QuickCam Messenger Web Camera
Logitech QuickCam Pro 5000 Webcam Logo
593 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
