Error code SC305 for copier ricoh aficio 1224c
I have a ricoh aficio 1224c photocopier but it keeps displaying error code SC305. How do I correct it?
Thanks
Billboards
  • 1 more comment
  • mizerman Mar 11, 2009
    i have a ricoh aficio 1224c paper jam error keeps comming up but there is no paper jamed in ithow do i fix this
  • lisamarie414 May 11, 2009
    I have the paper jam thing going on also. Not sure what to do, short of throwing it out the window.
  • adwan
    adwan Dec 01, 2013
    Hi, This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air.
  • 14 Answers
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Posted on Jun 22, 2008
Problem with Copiers
I have a ricoh aficio 1224c photocopier but it keeps displaying error code SC305. How do I correct it? Thanks Billboards
Posted by avatar9.jpgbillboards on Jun 18, 2008
    • By Error code SC305 for copier ricoh aficio 1224c - avatar4.jpg"/../users/lisamarie414">avatar4.jpglisamarie414 May 11, 2009
    • I have the paper jam thing going on also. Not sure what to do, short of throwing it out the window.
    • By avatar5.jpgmizerman Mar 11, 2009
    • i have a ricoh aficio 1224c paper jam error keeps comming up but there is no paper jamed in ithow do i fix this
AdChoicesSharp Used Copiers.www.SharpExport.com Tested - Parts Complete Full service exporter - ISPM15
T9 LED Tubewww.ZTlights.com No Flickering, No Mercury and Other Hazardous Mate
Solutions (1) Hi,
Posted on Feb 25, 2012
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
Mar 01, 2013 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
Hello i have ricoh aficio 1224c color . but the is have problem error sc792 . please help me best regards Salar
SC 792 :Finisher error .
The machine does not recognize the finisher , but recognizes the relay unit .
Possible causes :Defective connector
defective cable
incorrect installation
Aug 10, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh (Aficio) 1224c. code sc670 we want to decode this codesc670
Hi, it looks like a bad controller board. Try resetting it from in service mode with 7807. Also if you can view or printout the error history with 5990-004 for further trouble shooting. Hope this helps
Aug 03, 2011 | Ricoh Aficio 1224C Black and White Copier
I have some ricoh aficio 1224c with errors c481
SC481
Transfer belt mark detection error
• The main motor is operating; and
the lock signal is detected. → The
belt mark sensor signal does not
change for 120 milliseconds.
• Defective main motor
• Image transfer belt out of position
• Belt mark blurred or absent
I would remove the pcu unit (3 screws)and check the transfer assy belt mark and clean the sensor that reads the belt mark. Worst case senerio is replaceing the entire pcu unit.
Mar 07, 2010 | Ricoh Aficio 450 Copier
Please show me how can I unlock the error code SC305 for Photocopier Ricoh Aficio 1224c
This is a Corona cleaning unit error. You either need to get the issue with the corona cleaning unit fixed or have a service technician turn off the automatic cleaning function. SP Mode 2 801 3 (technican will know what this code means) I can not tell you how to do this as you can total mess up the machine if the service mode is not used properly.
Turning off the cleaning will solve the error code. Technician can clean the coronas himself on service calls so automatic cleaning is not required.
Good Luck
Dec 07, 2009 | Ricoh Aficio 2015 Copier
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
The 1224C Ricoh Photocopier keeps on displaying SC571 error message.
Try 'clear', '107', 'start' buttons. If that does not work, try different combinations, but '107 should be correct.
Jul 04, 2008 | Ricoh Aficio 450 Copier
Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Jun 18, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio 1018 photocopier
Hi it is the polygon motor failure error
2nd motor down on this link is what you need.
Nov 30, 2007 | Office Equipment & Supplies
3,536 people viewed this question
k24674
