Question about Samsung Televison & Video
I have a Samsung CT5038VC CRT TV, it was showing very well , then suddenly, the entire screen went green! you can still see, but everything is green. Please assist me in finding the solution to this problem.
    Top Expert:
  • Samsung Master
  • 74,383 Answers
Hello
Since picture is there, sound also mut be. The screen colour went green is your complaint. It is due to the video output stage of your TV. The fault mainly occur in the picture tube base board card. Loose or bad solderings ara always noted. There are three video output trnsistors there in the base board In some models of Samsung sets, either three individual Ics or one single Ic is used. Anyway the fault lies around this card.
You jsut open your TV, pull out the base card from the picture tube neck, care must be taken when you do, not to shake sideways or up down. Just pull it straight back, otherwise picture tube base pins or picture tube neck wiil get damaged. Before doing this check the vlotages of the three cathode pins of picture tube base. It can be done withoug detaching it out from the neck. There are three cathodes. Blue, Green and Red. In most Tvs these voltage will come near to 130 vdc or so. In your TVs case, now the green cathode voltage will be low with respect to the other two cathodes.
This may be due to a loose soldering or fault related to green cathode itsef. If transistors are used, check the green output transistors collector voltage,and compare it with the other two voltages. If Ics are used, do the same. If one Ic is used the checkings are the same.
Just resolder all the loose suspected points before replacing anything first. If it does't help, you just desolder out the green bias drive, whether it is a transitor, or Ic, whatever may be. If it is transitor, just plug it to the picturetube and switch it on without the green drive. Now you must see a different colour, a mingle of red and blue, a type of cyan. If so you can make sure that green output, whatever type it may be, is faulty. Just replace it with same type and number. Check the 2W resistors, if any used, for open, especially to the green drive transistor load resistor. Ok.
Posted on Nov 13, 2010
Testimonial: "Wow, right on the nail man, Thanks! that is exactly what i will do. This is excellent information, again, thanks a million!!!"
  • 1 more comment
  • Todd Hill
    Todd Hill Nov 17, 2010
    also ck r,g,b out of your y/c chroma ic
  • The Knight
    The Knight Nov 18, 2010
    There will be no problem to the voltage supplied to the output Ic. It is a stablised voltage thet will be given either from SMPS supply, or a transformer used extra supply. If there is a problem a resistor of low Ohm value opend. It will happen only when the audio output Ic is get direct shorted. Here there is no such problem as sound in distorted form is available. It should be due to fault around the audio output ic, or sorroundin capacitors onlt. There is no doubt about it.
  • ruthb22 Dec 27, 2010
    I read your suggestions to "doctech's" green tv problem. I have had the same issue with my 56" Samsung (HLN567wx/xaa) for a long time. It is 6 years old and we do not use it very much, but it is green most of the time when it is on, although there are occasions where it has a perfect picture. We sent this to a so-called tv repair shop (3x) and we paid them several hundred $ but they never fixed. If this is the solution, do you have any idea what it might cost to fix? Also, I am in the Dallas Tx area, would you have any tv repairmen in this area you would recommend?
    Thanks in advance
People on tv have green faces. Everything has green cast to it. Happened suddenly. What is going on? Jo
All depends on the type of tv. Is it one with a crt screen or a digital one? If it's a crt type, one of the color guns has gone out usually caused by a blown capacitor.
Jul 19, 2017 | Televison & Video
Panasonic Plasma 50 TH-P50U30A blacked out with no sound
Appears to be a power supply issue with everything being so dead.
Jan 22, 2017 | Panasonic Televison & Video
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Is the tv shot or just a bulb? it went out suddenly
Standard CRT televisions as in your category don't have a 'bulb' they have a CRT, a Cathode Ray Tube. If there was sound and no picture, something was defective in the video part of the circuitry, now no sound, so something else has blown. 2004, 11 years old, old technology, and HEAVY and bulky. Technology has moved on, and you will be surprised how much. We went from 36" CRT to Samsung 50" Smart TV. HUGE difference! Treat yourself :>)
Sep 13, 2015 | Televison & Video
Green screen
It depends on how green it went----the set has a block with screen and focus controls---you do not want to touch the focus controls but you could try to lower the GREEN screen until you have a normal picture.
Let me know and I will tell you how to access and adjust for this issue.
Jan 16, 2012 | JVC AV48P776 48" CRT TV
TV Turns off after a few seconds
Most likely your green crt has a short in it
open up the front and locate the focus block
Very carefully turn down the screen controls Be sure they are the ones that say screen
If you can get the tv to come back on slightly tap the green crt
That is the one in the middle
If you get green flashing on the screen it id the green crt and it is shorted
It may not be economical to repair
I would not tackle this unless you had a tv guy with you
The crts have a 12000v charge on them
The cant kill you but you hair will stand on end
Be careful and good luck
Jan 26, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Samsung txh1970 tv screen has green tint
I encountered the same problem with a color computer monitor several years ago. Everything went green. The repair techies told me that's a sign that the power supply is going bad. You will not be able to adjust the color. You will have to either fix it or replace it. Hope this isn't a common problem with this model Samsung TV.
Dec 01, 2008 | Samsung TXH1970 TV
Sony Trinitron Blinking Chanel 3
I have a 36 Trinitron, the sound and picture went but the red light just keeps blinking, any ideas? Please ....
Feb 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Green picture
I have the same problem, the service people indicated this a manufacturer problem, they are not calling it a recall, but requires up graded parts which could take 30 days or more to receive. He said if they do not receive the parts in 30 days they might replace the TV. My TV is a Samsung DLP 61 inch
Oct 29, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
427 people viewed this question
Henry  Thomas
Henry Thomas
