Question about HP OfficeJet 6210 All-In-One InkJet Printer
Scanner will not work since I had computer repaired
  • HP Expert
  • 231 Answers
Check if the driver is installed, if not reinstall it from the CD or from downloading it from the producers site.
Posted on Nov 13, 2010
R33001 photosmart scanner
Any repair cost outside a warranty period is the owner's responsibility. Most printers and scanner, in fact just about everything to do with computers,are not built for repair but replacement. The cost associated with repairing computer devices and peripherals makes the task impractical. Get a free quote first but I would confidently say the answer would be "Not worth repairing. Buy a new one"
May 20, 2014 | Computers & Internet
Tip
ALLIN ONE 7410 SCANNER PROBLEM
Flat bed glass top scanner works perfectly fine.
ADF Feeding scanner puts red lines on document shown on preview computer screen and will print same if I save or print the document.
HP troubleshooting tips only covers the flat screen scanner gass top.
Called HP and they suggested I either buy a replacement printer for $250.00 or it would cost $400+ to repair this one.
I removed the ADF (three small screws) and cleaned the small section of glass underneath and reinstalled the ADF component.
WORKS FINE NOW !!!
HP REPAIR PEOPLE ARE A RIP OFF ! DO IT YOURSELF AND LEARN MORE ABOUT YOUR MACHINE BEFORE WASTING ANY MONEY !!!!!
on Mar 29, 2008 | HP OfficeJet 7410 All-In-One InkJet...
It does not work in my new computer with Win 7
I have many years of repairing Canon scanners and here is my suggestion to you.
First disconnect the cable that goes from your scanner to your computer. Next google Canon CanoScan 4200f Drivers just as I have written it to you. A page will come up look for Canon's official website and download the drivers from them. The drivers are free from Canon. Once the download is complete and you have installed the drivers on your computer. Power your scanner back on and connect the cable from your scanner to your computer. a window should pop up saying a new device or drivers are being installed. Once this completes I would reboot (restart) your computer and you should be ready to scan now.
I hope this helps you out.
Apr 01, 2011 | Canon CanoScan 4200F Flatbed Scanner
The printer works fine but the scanner doesnt.....Please help....
I have many years experience repairing Canon scanners so here is my suggestion for you.
You dont mention what type of scanner you have. What I would do if I were you would be to find the make and model of the scanner you have (there should be a tag on the scanner somewhere, on the back, top or underneath it). I would then google the make and model and add the word drivers to your search. Go to the manufacturers website of the scanner and download the latest drivers from them. Once you have the drivers disconnect the cable from the scanner to the computer first, then install the new drivers you have. Then with the power on to your scanner connect the cable from the scanner to your computer again. A pop up window should come up saying a new device or drivers are being installed. Once that completes I would then reboot (restart) your computer and you should be able to scan now.
Mar 22, 2011 | Office Equipment & Supplies
My printer is working but not scanner, what should I do.
Hi, you can use this link
computer-printer-repair.blogspot.com/2009/04/fix-scanner-not-working.html
Hope it helps..
Thanks for using fixya.....
Nov 16, 2010 | Office Equipment & Supplies
SCANNER BULB IS ALWAYS WARMING UP
The "scanner warming up" error is caused by dirty optics in the scanner assembly. You will need to dis-assemble the scanner and clean the mirrors with window cleaner and lint free towels and Q-tips. We have a stap by step walk thru article on our web site at: http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/ The repair should take about 30-45 minutes to perform. The repair will require you to dis-assemble the scanner unit so be prepared to do a little work but when finished your printer will work just like new.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 01, 2010 | HP LaserJet 3380 All-In-One Printer
Scanner Bar won't move
Try first unplugging the power cables for ten minutes, also restart the computer.
Check if this model has a lock button to secure the scan, this is usually indicated with a lockpad, and is a small tab, if there is one is indicated on the manual.
Plug it back and do the following:
This sounds like an hardware fault, since the scanner starts, but just in case , ensure the drivers are working fine by reinstalling software from scanner disk. And eventually test the scanner on a different computer, for example a laptop. Use the scanner CD to do intall scanner drivers before connecting the scanner.
If it still does not work.
Check if the scanner lamp goes on when you send a scan, if not the lamp must be replaced.
The most likely is that the traction belt had slipped out, one of the mechanichs are stuck, or the motor is faulty.
In this case the scanner must be taken apart, the job can be done at any local repair shop.
Dec 14, 2008 | Sharp AL 1631 Copier
Problem with a canon 5000f scanner. Scan light does not move and I get an error message 2,150,0 which tells me to turn off the scanner and refer to the manual. The manual is not helpful
First, disconnect the scanner and power it down. Next, remove the scanner software from the computer through the control panel and remove software function. Shut down and restart the computer. Next, reinstall the software. If Canon has a new version of the software on its site, use that. Follow the manual during the install procedure. If this doesn't work, your next decision is economic...new or repair.
Dec 02, 2008 | Canon Office Equipment & Supplies
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
