Question about Samsung V20 XVC 2400 Notebook
I have a Samsung V20 notebook. I have fitted a new hard disc and when I try to load Windows Xp it switches off after the message "searching computer configuration" appears.
  • 1,179 Answers
It used to work and now it doesn't. The problem therefore lies either with your new hard drive or your laptop is unable to recognize it. However as the hard drive was installed recently I would put this down to a loose connection. Also see the BIOS, by pressing the Delete key during POST and ensure that the hard drive is detected. If not then navigate to the auto detect option, take your time in the BIOS as a mistake can be costly and only save when you are 100% sure that the selected option is correct. So go back to the beginning. Uninstall your hard drive and then reinstall it slowly and clean any-thing that looks dirty. Ensure that the placement screws are in place, also check to see that your hard drive is compatible with your Laptop, with regards to capacity and the RPM of the hard drive as 5200RPM and 7200RPM models are available. There is also the chance that your Windows disc is damaged and your DVD drive can't read the neccessary information. Try do as much as you can yourself before handing the problem to a computer technician. If all fails then if it is possible try and use your original hard drive, if it works that is.
Thanking you
damnor01
Posted on Nov 13, 2010
Trying to reload Windows OS. Run into
From another computer build a msdos floppy disc, yes floppy disc.
I believe you computer accepts floppys does it not? and i also asume you are running xp, you can try running the startup disc and trying to check disc, but if you cannont procede, i would opt into downloading another copy of the windows and try installing through that method. If the disc dosent load, and you get that error message of the bat, another step will be waiting for you.
May 26, 2012 | Dell Dimension 8400 PC Desktop
Hello, I have aSamsung X15 lop top with "No operating system", After trying to install windows XP. XP appeared to be loading but then I got a message that the hard disk is not connected....
Could be a defective hard drive. Another option is to download a "live CD" version of linux and attempt to run the system from that to verify if the hard drive is good. If the hard drive is good then do a low level format and then re-attempt your XP install.
Jan 05, 2018 | Samsung X15 Notebook
I am trying to load Kies software on my PC , when I load with Disc , message comes up " install.net framewirk 3.5. I have already installed this however the set up guide will not go ay further. it...
*Please check if your mobile device is supported by Kies before download.
http://www.samsungapps.com/about/onPc.as (Not all Samsung Phones are support)
System Requirements to install Kries
System requirements Description
OS: Windows XP(service pack2), Windows Vista, Windows 7
CPU: Intel® Pentium 1.8 GHz processor or higher (recommended)
Minimum memory (RAM): size 1.00 GB (recommended)
Free hard drive space: At least 500 MB
Screen resolution: 1024 X 768 (600), 32 bit or above
Required software: Net Framework 3.5 SP1*
Windows Media Player 10 or later
ActiveSync(Windows XP), Device Center (Windows Vista)
DirectX 9.0C
Since you have not mention your PC OS, try updating your system files via Microsoft Update & reinstall Kries.
Hope it helps.
May 07, 2011 | Computers & Internet
I was looking for step-by-step install guide to putting new hard drive and loading Windows XP on my Dell Inspiron E1505?? I purchased a WD 320GB SATA hard drive to replace my dead 80gb hard drive....Dell...
All you've got to do is:
1) Insert the new hard drive.
2) Press the F8 key as the laptop boots. This will take you into the BIOS.
3) Locate the disk drive priority setting in the bios.
4) Set Priority 1 to your CD/DVD drive and priority 2 to the 320GB hard drive.
5) Save settings and exit the BIOS. This should reboot your laptop.
6) Insert the Windows XP CD.
7) It should not start the setup as it recognises the CD.
8) I will recommend that you format the drive before you install, go along with the format (make sure it does a full format).
9) After the format it will reboot your system.
10) You will be prompted with a message like "Press any key to boot form CD", DON'T press anything otherwise it will start all over again.
11) Now it should start the install. Follow the on-screen instructions.
Mar 15, 2011 | Dell Inspiron E1505 Notebook
Hi, my daughter as a samsung x10, started having problems so i tried bleaching the hard drive , that would not finish it just crashed at the end, so i found the windows xp rescue disc after plenty of...
When you boot up your computer, there are usually tips like "for set up bios press F2, for recovery push F10" and so on. You need to enter the BIOS and see if there is Hard drive recognized. If not, then you need new Hard drive. Good luck!
Feb 19, 2011 | Samsung X10 XTC 1300 Notebook
I wiped my hard drive using kill disk. I have a Windows XP home disc to install the operating system, but when I boot the computer, I get the "Error loading operating system" message and it won't...
when you boot the laptop, if you don't see a message that says press any key to boot from CD, your boot order is wrong.
Check your boot order, when you see the splash screen (logo) look for a message that says press a F1-F12 key to change boot order or if that message is not displayed, press the key to enter setup.
Look for an option that list boot order and shows your hard drive, CD/DVD and USB options.
Move the CD/DVD item to the top of the list and try again.
Feb 11, 2011 | Gateway Computers & Internet
How to reformat back to windows vista ?
You need a windows Vista disc. Insert the disc and follow the prompts. I would format the hard drive instead of upgrading do a new install. The best way would be to go into your bios and make sure the boot device order has the cd-rom booting before the hard drive. Then put the disc in and start the computer, when it says press any key to boot from cd hit any key and let it load and then follow the prompts to install.
Nov 27, 2009 | NEC Versa VX Notebook
How do i enable wireless function on samsung v20 laptop?
you can try pressing fn+f10 to switch on and switch off wireless
Aug 11, 2009 | Samsung V20 XVC 2400 Notebook
New hard drive required for v20
The hard drive that is installed in the V20 laptop is a 30 Gb IDE capacity hard drive.
The smallest IDE hard drive that you can purchase today is in the order of 80 to 100 Gb capacity. The BIOS in the V20 may not be able to support a hard drive this large.
If you install a hard drive of this capacity the BIOS may not detect it or it won't allow you to access the full capacity of the hard drive.
Jan 21, 2009 | Samsung V20 XVC 2400 Notebook
Samsung V20 XVC 2400 Notebook Logo
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
