Question about Schwinn Cycling
My schwinn 418 is making a nose like something is loose and hitting something when the wheels rotate. Machine works fine except nose. I need help opening the main frame to find loose part.
    Genius:
  • 1,788 Answers
Take it to a bicycle repair shop, they can tell you what is wrong. No one can diagnose it without seeing the problem. It could be loose cones in your wheel, brakes hitting the rim because it is bent, or maybe in your cranks, see what I mean? What main frame are you talking about? Never heard of it and I have been in the bicycle business for close to 40 years.
Posted on Nov 13, 2010
My Chevy surburbon 03 1500 is macking a nose coming from the front left wheel
check for a loose wheel..take the wheel and shake it(while jacked up off the ground) rotate it and look behind it for any loose hardware bad bearings or anything you can see that makes noise or dont look right..repost with findings,, thnx
Jan 19, 2013 | Cars & Trucks
Looking for manual for 418 elliptical repair and user type
Hello Mug,
Please download the Schwinn® 418 Elliptical manual from the link provided below :
http://download.dfxi.com/supportdocs/AM/Schwinn/SCH_418-428_AM_web.pdf
Oct 10, 2011 | Schwinn Exercise & Fitness
The computer on my schwin 418 eliptical does not work. Is there something I can do to fix it myself? Where can I get it serviced?
Call Schwinn customer service (actually Nautilus) at 1-800-nautilus if it is broken so you can order a new one or they will send you a new one if you are under warranty. They are very helpful. You can also check the power connection on the bottom or make sure the wire harness in the main pipe in the center is properly connected if the system is brand new and not working.
Jan 04, 2011 | Schwinn 430 Elliptical Trainer
Error code 1 on schwinn elliptical 418 how do I fix it. I have replace batteries and unplugged unit. Error 1 shows up as soon as I turn unit on.
E1 error seems to indicate that the servo which controls the elliptical resistance is stuck. Here is how I fixed this (without using a "crank puller", which would be quicker by far).
You will need a very short phillips screw driver (snub nose), a long phillips screw driver, an allen key set, and crescent wrench.
- Remove the batteries from the unit.
- Remove the screws from the plastic housing (with the long phillips screw driver) on the left side. Do not forget the phillips screws at the front - they are smaller screws so don't mix them with the others. This will allow the plastic housing to flex and move around, but not come entirely off.
- Using the crescent wrench, remove the nut holding the left pedal to the crank. Carefully note the order of the washers on the crank attachment.
- Using the allen key, remove the little pedal attachment piece on the left crank arm.
- Using the short phillips screw driver, carefully reach inside the plastic housing on the top and remove the four screws holding the plastic plate on the outside of the fly wheel/crank. You will need to rotate the crank wheel to reach each of the four screws in turn on the inside of the case.
- Pull off the plastic cover for the wheel.
- Reinsert batteries and gently help the revealed cable (bottom) retract the magnet plate. In my case, the servo worked fine again after helping it retract the magnet plate that was somehow stuck/wedged.
Reverse steps to re-assemble.
Jan 16, 2010 | Schwinn 430 Elliptical Trainer
Schwinn 418 Computer does not come on.
Did you ever fix this? I am having the same problem...
Dec 10, 2009 | Schwinn 430 Elliptical Trainer
Rattling noise
you might have something in the blower wheel. it is common to have something fall down the vent and the blower wheel is hitting it.
Oct 11, 2009 | Whirlpool Dryers
My 98 gmc jimmy 4d 4wd makes a loud humming noise as I drive it.
a front wheel beran will make a grinding nose if it is bad and when you trun one way or the other the nose will go away. i do not think that is your prolbem . if your car vibberate or make a skueaking nose it could be cv joint or a front universal joint.
Apr 05, 2009 | 1998 GMC Jimmy
Won't go: Schwinn S 180
maybe you should try to take off the wheel and see if the motor still turns over with out the chain and wheel attached to it maybe the chain is to tight...... well maybe you can help me to
Sep 28, 2006 | Transport Schwinn Rechargeable Portable ...
Cycling Logo
187 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
