Question about Kenwood KDC-216S CD Player
LCD display has died suddenly...
...and the rest of the unit seems to be operating properly.  I'm guessing some sort of fuse.  but where?  any help would be appreciated
  • 624 Answers
This radio has 2 lamps in the display to provide backlighting for the LCD, if 1 of them goes out, they both go out because they are in series.
The part number and specs are:
B30-1485-05 LAMP (5.5V 0.125A) ref # PL1 and PL2
To be sure this is the problem use this rule:
If the buttons on the display light up but the LCD does not, means the supply voltage is present, both use the same supply voltage.
The LCD does not light up, but you can see a very faint image of the display when you look close.
If either of the last 2 things mentioned are not true, you have a different problem.
If the buttons on the display do not light up as well as the LCD not lighting up, you have a bad voltage regulator IC on the main board of the radio, not a problem in the display. Or you have a bad connection for that supply voltage.
The part number for that regulator is:
BA4911-V4 ref # IC7
If the backlighting for the LCD is good, but you see no numbers or letters on the LCD, the LCD or the LCD driver IC is bad.
Both of these problems require very good soldering skills, unless you are confident with your own soldering skills I advise you to take it to an authorized Kenwood service center for repair.
Let me know if you need any more help and tell what you observe from the rules above.
Posted on Jun 18, 2008
Onkyo receiver tx-sr805 no display screen. how can i do a rest set? already unplug receiver per owens manual.
I'm sorta familiar with those kind of amps, lots have built in fuses. My guess is a fuse went
Nov 03, 2016 | Washing Machines
Acer 4320 can not switch on properly. after a few minutes turn on, suddenly black out.
The problem is most likely the DC jack in the laptop, causes are no power to intermittent operation, but if the screen blacks out it means the LCD display has issues especially if the rest of the laptop is working, could be a loose video cord from the screen to the motherboard has come loose.
Jun 10, 2012 | Acer TravelMate 4320 Notebook
Husquevarna rider mower dies & blows fuse when pto is engaged
you may need to check that your blade engage sensor is working properly, and that the one on the seat is working properly. if not that, then check the ignition fuse connections. they may seem to be connected properly, and still not be seated properly. good luck.
Nov 20, 2011 | Husqvarna Garden
What are the odds that the cruise control unit and the actuator unit would BOTH fail at the same time ?? 2002 Odyssey EX-L 172,000 with all maint from day one. Seems rather odd to me, but I'm NOT a...
Sounds like they are guessing and dont want to, or cant diagnose it properly. First make sure fuse is good (fuse 6) , make sure brake pedal switch is adjusted correctly. (if it thinks you are pushing the brakes, it wont cruise) check fuse 47 (if horn blows, fuse 47 is good) make sure cable is connected at throttle body. check these first, the rest gets complicated.
Aug 03, 2011 | 2003 Honda Odyssey
The lcd display is not displaying properly at all and the light is no longer working. But its still heating! Could it be some sort of fuse?
It will be the display driver or illumination that has packed up. A replacement display panel is required.
Consult an authorised Microwave dealer for price and advice.
Dec 23, 2010 | Microwave Ovens
Display problem in my nokia 6275
my phone display is frizz lines coming what to do
Jun 01, 2009 | Nokia Cell Phones
Two issues with this system
Hi eshort
When you press the buttons to operate the Cd drawers, do you still feel a click under your fingertip the same as the rest of the buttons. If not, the plastic piece may have broken away from behind the front panel assembly preventing the switches from operating be from the front panel. It may as you have already diagnosed be a part broken off the transport also.Only further investigation will determine this:) Can you still operate the unit from remote control?
The LCD display will use an incandescent lamp to back light it. this lamp will have failed. These are replaceable, the degree of difficulty varies from model to model. Pop the lip off and check if it is easily access. The worst cases need to have the LCD display removed to replace the lamp. Good Luck, thanks for checking with FixYa
Mar 11, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
Seems like a S/W issue...
This is a mechanic problem. The camera can't align the lents and proper focus them due to some sort of servomotors failure. Because of that, it tries to get a proper fix, but as it fails, it thinks that some object got the lents pushed or something like that and it askes you for a "reboot". You can't "hard boot" the camera, even a complete reset woun't help as this error is given by the camera's microcontroller circuitry (some sort of camera processor). The only fix can by given by an autorised service center. Even they may find out that you need the whole lens mechanism changed.
Mar 10, 2007 | Panasonic Lumix DMC-FX7 Digital Camera
Display dies suddenly
open u phone unplug the lcd cable clean it and reattach close it wil be ok.
Sep 26, 2006 | Siemens CF62
Kenwood KDC-216S CD Player Logo
243 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
