SOURCE: how to install games and java apps on my sgh-l700
how to instal game & application my phone sgh-l700
SOURCE: app problem in sony f305
Sony Ericsson F305 supprots only Java softwares. Download the java apllications which you need from www.getjar.com after selecting your particular mobile model. The extension of the application should be ".Jar" Then transfer this jar file to your mobile and try installing it. The installation files transfered from other mobiles using bluetooth may not be compactible with your mobile. If your problem still exist, then activate the GRPS, go to wap.getjar.com and try downloading the application directly to your mobile. This should work fine. I hope this is helpful to you.
SOURCE: I have a samsung GT-S5233A,i can't install java applications
1) *#9998*5282#
2) *#9998*4678255#
3) *#9998*52824678255#
4) *#52828378#
SOURCE: Im getting java error, no memory availabe when I
Yes sure you can store WAP,Blue-tooth,Camera and Voice Recorder downloads into Memory Card as a Default...here is how you can do it:
Go to Menu--Settings--Memory Settings--Default Memory--Select out of the 4 options--select Memory Card--Click Save.
but
The Problem that you are facing is related to your Phone's RAM and that doesn't fit into your application's minimum memory requirement,hence the problem.
I don't want to go into details but a RAM is a primary memory and the Memory Card is Secondary...they can't be interchanged.
SOURCE: my sagem my521x won't work with 2gb micro sd card.
If the memory card doesn't work with your phone,
you can try using it with another phone that uses the
same type of memory card to confirm if the memory
card needs to be replaced or not.
