Question about Electrolux Washing Machines
Tricity bendix washer dryer model wdr 1041 water not draining and displays e20
  • 116 Answers
SOURCE: Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
Posted on Mar 11, 2007
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
  • 1462 Answers
SOURCE: Tricity Bendix W/D 1000 fills and drains but drum doesn't turn
check brushes in motor
Posted on Aug 09, 2008
SOURCE: dryer
We found that we needed to turn down the water inlet to almost off and then the dryer worked when we had the same problem.
Remember to turn it back up again before the next wash
Posted on Jan 27, 2009
SOURCE: Tricity bendix aw 1001 w is not draining,pump and
If you have checked all of these then the only other explanation is that the pump motor is faulty and needs replacing or there is a fault with the wiring or Programmer.
Posted on May 03, 2010
Blocked drain pump
get a air compressor at the drain end and blow air up the hose to try unblock what ever could be over the sensor. OR get your garden hose and force water the other way to try unblock
Jan 05, 2013 | Tricity Bendix Washing Machines
Tricity bendix wdr 1241 emergency drain hose leak
Pull the machine out, if the back is removable, take it off. the connection should be close enough to reconnect...next time? don't pull so hard. if this doesn't work, take it to a reputable Repair Shop/Dealer
Oct 15, 2012 | Tricity Bendix WDR1240W Front Load Washer...
I have lost my manual need a replacement
Hi.
Please click on the link below to open the manual in PDF format.
WDR 1040 W WDR 1240 W
Regards.
Ginko
Aug 31, 2011 | Tricity Bendix WDR1240W Front Load Washer...
E20 error msg flashing what does this mean?
Sounds like your drain is blocked. You may have access to it through the front at the bottom but If you cant access it from the front You will have to tilt the machine back as far as safely possible to access the bottom of the machine. Locate the drain pump which will be at the bottom font or back corner and remove the hose that connects the pump to the tub, you will need to have a basin ready to catch any water. You most likely have a sock or something stuck. Hope this helps
Mar 02, 2011 | Tricity Bendix WDR1040W Front Load Washer...
Machine stopped in middle of cycle model no wdr 1041 it has come up error 20
Means the appliance is not draining. Remove the filter from the drain pump, this should be located at the bottom front, remove it and check for blockages and remove. hope this helps
Feb 23, 2011 | Tricity Bendix Washing Machines
Dryer
Mar 13, 2008 | Tricity Bendix WDR1240W Front Load Washer...
Washing Machines Logo
67 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
