Question about D-Link DIR-625 (790069292637) Wireless Router
We have a D-link 625, It is located in our basement and we are trying to get a good signal in our family room, which is about 25 yards from here. Please suggest what we might do to improve our signal.
  • 4,281 Answers
If you wantt o impove wifi signal then you need to change channel type of wireless router. For that Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless then change channel type to 3 or 6 or 11 then save settings and restart router. . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Nov 13, 2010
I have a SuperScan 35 inch I have hook a RCA indoor antenna to it and run channel search but nothing comes in help me please
The problem could be with the antenna you got versus the location you live. Indoor antennas are very range limited. Non-amplified models range about 25 miles, while amplified models make about 50-60 miles. Also, you must consider where you live. If you live in an area of heavy building concentration, signal may be limited. Home construction matters as well. Frame houses pass signal better than brick or concrete block homes. Upstairs locations fare far better than basement family rooms.
Nov 01, 2015 | RCA Televison & Video
My Dir 615 is working very fine but up in one room the signal is very weak. How can I get it stronger? Thank you,
Hi - Wifi devices are very low power. Under optimal conditions, they can transmit up to 100 yards. Optimal conditions are basically an unobstructed "line of sight".
The number of and the more substantial the obstruction, they greater the impact is on the signal. An example is the devices (computer and the router) are separated by 40 feet and a single Sheet Rock or gypsum board and wooden wall; like you might find when a computer is being used in the back yard and the router is inside the house in a room next to the back yard. The signal should be relatively strong over this distance and this minimal obstruction material. Compare this to the same distance of 40 feet, but the wall is now brick or concrete, and there is a second wall like the first example - but it has a coating of aluminum; and there is a wooden floor; all between the computer and the router. That is an example is what you might find if the router were in a second floor room at a neighbor's house that has aluminum siding and the computer is in a basement of your house. The signal may be so degraded by aluminum, wood, concrete, soil and gypsum obstructions that the speed is very slow or isn't usable at all.
Now you've got an idea as to how the materials of the obstructions can wreak havoc on a wifi signal. There are also issues of interference. Most wifi "b", "g" and "n" signals operate on 2.4Ghz and and 5Ghz frequencies. These same frequencies are employed by other low power / unlicensed consumer devices - most notable are cordless telephones (not cell phones), microwave ovens, Bluetooth devices and baby monitors. If enough of these devices are in the area or between the router and computer, they can disrupt the signal significantly as well.
So, if the space between the computer and router are close, but you're still having trouble - look for these popular consumer devices. Unplug them / remove batteries and see if the signal improves. Move the router to a centrally located point in the area that it is to be served. Pay attention to the types of materials that the signal must pass through - air, paper, and wood aren't too bad. Brick, mortar, soil & metal can substantially reduce signals very quickly. It is better to have the router above the area to be served rather than below it.
Lastly, check the channel that the router is being operated on. The band of frequencies for "b" and "g" wifi consists of 11 channels (1 through 11) in the U.S. The best frequency to use is channel 5 (ch 5) or channel 6 (ch 6). This is because it is in the "middle" of the band (like the way 98 is middle of the 88 - 108 FM broadcast band). Other signals *may* be on the frequencies above ch 11 and below ch 1. Being on 5 or 6 keeps as much space between YOUR wifi signals and those that aren't wifi types. Ch 5 or Ch 6 may already be in use by a neighbor. If that is the case, you both will be on the same channel and the signal will be significantly reduced. Try to get as far away from his or her signal as possible - this may mean ch 3 or ch 9 - or maybe even ch 1 or ch 11 under the right conditions.
I hope this helps and good luck! Please rate my reply. Thank you.
Oct 03, 2011 | D-Link DIR-615 Wireless Router
My router and main computer is located iin the basement, with my laptop located in the family room 25 feet from the wii unit. I can't get the wii to read my router
Check on your router what security setting you have it on. I have found that my Wii will not connect to my router when it is set on WPA2. I have to set it to WPA, and then it will connect.
Hope this might help your issue. Good luck.
Apr 30, 2011 | Nintendo Wii Console
I have a room that my 2way radio loses signal
Is it a basement? Where is the other one located? There could be something that is jamming the signal there to. Try taking a radio (music) and see if it gets signal as well. if it does then the radio might not be strong enough to send/recieve calls through many objects
Apr 13, 2010 | Motorola Talkabout FR60 (14 Channels)...
The signal is very low, one bar, What can I do?
You might need to change the location of your router for optimal reception.
Good luck.
Jan 24, 2010 | D-Link DIR-625 (790069292637) Wireless...
Connecting to wireless from my basement!
you need to add a repeater or signal booster for reciving signal in basement from uper floor.
My expierince is that whatever roueter you buy doenst matter it will not work properly if you are using wirless on 2 diffrent floors. on a same floor it can work smoothly even having walls.
Oct 02, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Poor wifi performance
Doesn't matter,those signals can't get up to your study cause of the basement. when outside it's fine. try putting the router at a higher end, like on a stool or try the highest point in the basement. Or try getting some high gain antennas that will boost the signal.
Mar 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Low signal in the basement
maybe you should try to purchase a better wireless adapter,like dlink dwa-110
Jan 29, 2009 | D-Link AirPlus DI-524 Wireless Router
2nd remote has trouble changing channel
hook up a 6 foot peice of coax cable to the remote antenna port and then attach a barrel connector and then use a larger antenna "bunny ears" basically to extend distance of uhf signal for remote
Nov 27, 2008 | DISH Network DVR-625 DTV Receiver /...
D-Link DIR-625 (790069292637) Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
