Question about HP Compaq 6910p Notebook
How to turn on &off blue-tooth in hp 6910p - HP Compaq 6910p Notebook
    President:
  • 1,216 Answers
I've compiled everything for you and highlighted your answer
Special instructions for the HP Compaq 6910p
BEFORE WINDOWS INSTALLATION 1) MAC addresses The MAC addresses of the Ethernet (cable) and the wireless interface (WiFi) are written on a label on the side of the box. They are also written on a label at the back of the notebook. They must be registered in the CERN network database via http://network.cern.ch (using another computer) before starting the Windows installation.
2) Wireless switch on
When you start the installation, verify that the wireless light (with an antenna symbol) above the keyboard is on (blue light) in order to install properly the wireless drivers. If not, touch that antenna symbol with your finger: it is a sensitive button.
WINDOWS XP After Windows XP installation 1) Keyboard_Filter_01 As by default users are not in the Administrators group, a window titled "Found New Hardware" may tell you: "You must be member of the Administrators group on this computer to install this hardware: Keyboard_filter_01". In that case ignore that message and first regain administrative privileges by using the NICEAdmin application to add your account in the Administrators group. For that click on the Start button, select All Programs then NiceAdmin then Change Account Status. On the popup window click on Add Me, enter your login password and click on the green button (with an arrow). Then Reboot (a logoff/login is not sufficient). This time, the installation of the Keyboard_Filter_01 driver will be done silently.
Don't forget to use NICEAdmin again to remove yourself from the Administrator group in order to improve computing security after your next login. But don't log off until you have installed all your programs (for example the Bluetooth software explained below).
2) WiFi To setup a wireless network connection, you must be within range of a wireless Access Point. Check also that the wireless interface is switched on (blue light above the keyboard).
When Windows detects a wireless network for the first time, it should prompt you with a Wireless networks detected message in the notification area of your taskbar. If so click the notification message. If you are not notified, click on the Start button, point to Connect To and click on Wireless Network Connection. In either case, you should see the dialog box Choose a wireless network. Select CERN and click connect. On the warning "You are connecting to the unsecured network ...", click on Connect Anyway. Wait until connected to close that dialog box.
3) Bluetooth
If you need to connect to Bluetooth devices, HP provides a software to manage your connections. To be allowed to install this software, you must be registered in the Administrators Group of your computer. For that you can use NICEAdmin: click on the Start button, select All Programs then NiceAdmin then Change Account Status. On the popup window click on Add Me, enter your login password and click on the green button (with an arrow). Then Log Off and login again.
Check that your notebook wireless interface is switched on (wireless button above the keyboard with blue light on). The Bluetooth installation package is located in "C:\SwSetup\HP Bluetooth software v5.1E 26Mar07". In that folder, double click on Setup.exe to start the installation.
After the installation, you can use NICEAdmin again to remove yourself from the Administrator group.
4) DVD player
If you need to play DVD videos you can install the WinDVD player provided by HP for your portable. First right click on the CERN CMF (Computer Management Framework) icon in the system tray. If the CMF icon is not present reboot your computer and wait some minutes. Choose Add/Remove CMF Packages. On the CMF page tick the install box for the package WinDVD player for HP and click on the Save button. Then a CMF balloon should appear proposing to install WinDVD. Click on the balloon (or double-click on the CMF icon). In the CMF windows select WinDVD player for HP and click on Start Now. After some minutes CMF should display a balloon telling The installation of the package *WinDVD player for HP* completed successfully.
WINDOWS VISTA After Windows Vista installation 1) WiFi To setup a wireless network connection, you must be within range of a wireless Access Point. Check also that the wireless interface is switched on (blue light above the keyboard).
Click on the Windows Start button then choose Connect To. Then select CERN, click on Connect and then on Connect Anyway. When the window announcing Successfully connected to CERN appears, put a checkmark in Save this network and in Start this connection automatically. Finally click on the Close button.
2) Bluetooth
To activate the Bluetooth, press the wireless button (antenna symbol above the keyboard) to get a blue light on that button. Then click on the HP Wireless Assistant window which appears in the bottom right corner of the screen. If the status of Bluetooth is not on, click on turn on. Close the HP Wireless Assistant.
3) DVD player
Posted on Nov 13, 2010
On my hp compaq 6910p, my wireless switch will not turn on my wireless functionality, and neither will enabling the wireless connection. It tells me that the wireless switch is off and I have no way of...
So touching the touch sensitive button to the right of the power on button dont turn it on...you just touch the icon, between the other two icons next to the power button..and it should lite up blue.
Jul 27, 2011 | HP Compaq 6910p Notebook PC PC Notebook
I have HP Pavilion DV6 model no WW146AV.How to activate bluetooth in this model
If your particular model of HP has the blue tooth installed from the factory, turning on the wireless switch on the front left edge of the laptop enables the blue tooth, as well as the wireless LAN. A blue tooth icon should appear in your task bar near the clock when blue tooth is turned on. ELSE
You have to go into start, then all programs, then look for the blue tooth connection setting. Hope this helps.
Go into start, then all programs, then look for accessories, the find blue tooth wizard. You can switch it on via that.
NOTE : BE SURE THAT YOU HAVE A BLUE TOOTH IN YOUR MODEL BECAUSE SOME OF THE MODELS DON'T HAVE IT.
Mar 21, 2011 | HEWLETT-PACKARD Hewlett Packard Hp...
I Need Help Unlocking My Hp Compaq 6910p Every Time I Turn It On A Blue Screen Pop Up And It Say POWER ON PASSWORD .... PLEASE ANYONE HELP ME UNLOCK MY LAPTOP!!!!
Unfortunately HP says: "If you forget the power-on password, the computer must be reset at an HP-certified repair center. Please contact HP to schedule a repair. The Drive Lock password cannot be reset. If you lose or forget the Drive Lock password, the hard drive must be replaced. Please contact HP to order a new hard drive. These services are not covered by the warranty."
Sep 13, 2010 | HP Compaq 6910p Notebook PC PC Notebook
Not getting sound
check your sound drivers,and the sound mixer
Apr 02, 2010 | HP Compaq 6910p Notebook PC PC Notebook
Hp2530 error xxx STOP: 0x05001411 (0x00000000) (0x00000000) (0x00000000) (0x00000000)
Please see solution to
Generic problem for all HP Laptop Accessories Hp2530 error xxx STOP: 0x05001411
Changes and Corrections in 6.3.1 HFA3
The following items were corrected in Pointsec PC 6.3.1 HFA3:
ID
About
Details
453083
HP Compaq 6910p blue screened intermittently in preboot.
An unrecoverable error occurred intermittently in preboot on HP Compaq 6910p Notebook laptops.
http://dl3.checkpoint.com/paid/26/Pointsec_PC_6.3.1_HFA6_Revision_Tracking.pdf?HashKey=1264440272_c655ada20b1069217b99da7fb5d572d5&xtn=.pdf
Jan 25, 2010 | HP Computers & Internet
Forgot power on password for hp 6910p
I forget the power on password for hp 6910p
Oct 14, 2009 | HP Business Notebook 6910p Notebook
Wireless radio adapter or card
Try:
G1S - This laptop supports multimodal switching of the wireless and Blue Tooth radios via the key command Fn+F2:
1st press: On both Blue Tooth & WiFi
2nd press: Off Blue Tooth / On WiFi
3rd press: On Blue Tooth / Off WiFi
4th press: Off both Blue Tooth & WiFi
Sep 14, 2008 | ASUS (wifibralinkuay) 802.11b Wireless...
HP Compaq 6910p Notebook Logo
952 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
