Question about Konica Minolta magicolor 2300DL Laser Printer
Bad smell from printer
My 2300dl is putting off a very strong odor (not smoke) when it prints. What do you think this could be?
    Champion:
  • 214 Answers
Check fusing unit and also some elements from main board can do that
Posted on Jul 02, 2008
Call sumary lock
  • TSP or Trisodium Phosphate cleaner (1 tbsp.)
  • Rubber gloves for cleaning
  • A Large sponge or the sponge used while washing your car. A lot of cleaning needs to be done, and the sponge should be large enough to soak up a lot of water in one go
  • 2 large buckets
  • Warm water
  • Goggles and a mask to protect eyes and face
  • Rags to clean
After you put on your heavy-duty gloves, use the sponge and soak it into the TSP solution. The TSP solution contains a gallon of water and a tablespoonful of TSP. Work section-by-section, focusing on one segment and wall at a time.
First, wipe the surface of the wall or ceiling with the sponge and use hard and firm strokes. After that, dip the rags in clean warm water and rinse the ceiling and walls. Do the same with the other segments until everything has been cleaned properly.
The frequency of the above step may be more than one. It depends on the condition of the house after the fire and how much charring and soot buildup has occurred. You must be careful not to over-wash your ceilings and walls because seepage of water might occur into the drywall or baseboard. Don't saturate your walls with TSP and warm water.
This step is often followed by priming all the walls damaged by the fire and then adding a fresh coat of paint. There might be a lot of soot buildup in the AC filters, and they should be removed. All appliances should be thoroughly cleaned using a disinfectant. A fresh sealing layer needs to be applied on all the surfaces affected by the soot.
A simple deodorant or room freshener doesn't have a smell strong enough to counteract the bad odor from smoke. To deal with smoke, something stronger has to be used to disable odor causing smoke molecules in the air. Below are some items that can help you kill the odor from smoke damage:
Tony
May 30, 2014 | Nokia 1100
Why won't my minolta 2300DL print on any kind of vellum? So strange.
well..some printers can't grab that slick of a paper medium..let me show you an old trick we used to use
May 27, 2008 | Konica Minolta magicolor 2300DL Laser...
Clk 430 convert smelling a fuel smell & lots of smoke from exhaust (its either white ,grey)
Do me a favor check the fuel injector maybe they are bad that why the odor of gaz snd the smok
Dec 01, 2013 | Mercedes-Benz Cars & Trucks
How do I get a bad smell out of plastic beads?
naturally, plastic beads has a bad smell. But, you may also try to soak that on a water with soap :) hope this helps
Dec 07, 2012 | Refrigerators
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
A strong gasFuel smellcoming from the rear of the
THE CARBON CANISTER IS MOST LIKELY OVERLOADED, REPLACE THE CARBON CANISTER VAPOR TRAP, IT IS NEAR THE FUEL TANK.
Jun 29, 2009 | 2000 Volkswagen Beetle
Gas smell
your brand new 1972 VW beetle may have as simple hole in the fuel line..when the car is not running you will not see any gas leaks becuase there is no call for gas to be fed to the motor.
have someone, or yourself crawl under the vehicle and look fort a small dripping or small stream of fuel.....REMEMBER!!!!!!!!!...gas is HIGHLY explosive and flammable...no smoking while checking/working on the rpoblem...and fuel's smell comes from Naptha, a chemical added to oil to make gasoline, it is a very strong ordor..a small amount can smell like a gallon.
hope this helps you
Dec 29, 2008 | Volkswagen Beetle Cars & Trucks
Backfiring, rough idel
I would check the exhaust pipe a little closewr. White smoke can also mean a blown head gasket. Check the tail pipe to see if moisture is present. Also check coolant level. A blown head gasket can also cause related problems.
Bill
Nov 19, 2008 | 1999 Pontiac Grand Am GT
Poor print quality 2300dl
first did you try to clean laser glass ? and maybe you need a new 2'nd transfer roller.
open front cover and under the pc drum there is a blue knob, pull it out and clean the glass
May 28, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
202 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
