Question about Mitsubishi WS-55511 55" Rear Projection Television
My Mitsubishi WS-5511 TV will not receive commands from the remote. Remote is working and has new batteries but will not control power, volume channel, device or any other function. Netcommand setting is on TV as it always has been.
  • garyaustin Nov 14, 2010
    The front panel controls work somwehat. You can turn the power on and change channels but the volume will only go up so high and then it resets to a lower volume. The remote doesn't have the functionality to control other devices, as the device function does not work.
    Thanks for your help.
    -Gary
    Remote cannot control other devices as the device function will not work. Front panels controls work somewhat. Power works, chanel is able to change. Volume will go up but only so far and then it resets to a lower volume. Thanks for your help. -Gary
  • 4,889 Answers
Are the front panel controls on the tv working? If yes then either the tv's remote sensor has failed or the remote itself has. Does the remote have the functionality to control any other device, like a DVD player? If yes then is it working fine? Please answer these questions so that I can help you deal with this problem.
Posted on Nov 13, 2010
  • eagle338
    eagle338 Nov 14, 2010
    Looks like you have a bunch of problems here not just with the remote here. Since this set is about 15 years old, it might not be worth the service charge as you can get a Toshiba Regza and go HD for that price. Don't you agree?
I need a new remote for a WS-55313
If the tv was moved it may have a loose cable...you can get remotes for way less than that.
Mar 18, 2012 | Mitsubishi Televison & Video
My Mitsubishi projection TV will not produce audio or video
Two things are involved to cause that problem, tv remote control and remote sensor in tv.
Upon verification of remote working, it would be confirm that remote sensor in tv is defective and need to be replaced.
Remote control sends infra red light signal to tv and we can not see that light with naked-eye, so need digital camera or cell phone camera to see it by watching remote front through camera, press any keys on remote, if you see infra red light is blinking in remote front that means remote is working and remote sensor in tv will be replaced.
If no light blinking on pressing remote buttons confirm that this remote is defective and buy new remote.
Let me know if you have additional question.
Thanks.
May 31, 2010 | Mitsubishi WS-65511 65" Rear Projection...
The remote does not work. My satelite remote
There is usually a remote module mounted on the inside of the front of the tv that senses the remote signal. This controls all functions of the tv. If you are not comfortable in troubleshooting this, I would recommend a repair center.
Mar 07, 2009 | Mitsubishi WS-65313 65" Rear Projection...
WS-55511 55in volume turns up by itself & can't switch devices
The remote is not the problem. The switch for volume up on the control panel has become leaky. Very common problem for this generation Mitsubishi. If you don't mind not having the control panel working you can disconnect it and the set will work just fine with the remote. To disconnect the control panel pull the speaker grill, it just snaps off, and remove the front access panel. Once that is done you'll see a cable going to the switches just disconnect it.
Nov 23, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Tv ws-65511 volume stuck
Did you ever get this problem fixed? Ours just started doing the same thing. It worked fine the night before, but today it's doing what yours is doing. The remote stopped working for the TV. The remote still works for the cable box, but volume and anything related to TV function not. The screen flashes when we try to adjust volume or anything else, but resets to previous volume. TV not responding to any commands either on the front panel or remote.
Any ideas? Thanks, Patti
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS-65611 power and volume problems
when it shuts down Try pushing the input and menu buttons together on the set it self and hold them both in for 8 seconds.and see if the LED blinks a diagnostic code.
Mar 29, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Ws-5511 Mitsubishi
On these models we have found that a switch is sticking on the control panel not allowing the set to operate properly.
Disconnect the control panel.
You will be able to use the remote on it.
To find the plugs for the control panel:
Remove the speaker grill and front panel, then follow the wire to the connection.
Remember to unplug the set before putting your hands inside of it.
Dec 13, 2007 | Mitsubishi WS-65908 TV
No control of WS-65511
The following solution has been posted in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 22, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
WS-55908 remote control
Take out the batteries or simply reprogram the remote by using the manual search function on the remote. There is probably a couple of different settings in the remote for this type of TV set, Good Luck
Jul 02, 2007 | Mitsubishi WS-55908 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
117 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
