Question about Pride New Mobility Legend 4 Wheel Scooter
Electrics The power to tiller broke down,I have had the control box checked profesionally & it was deemed to be ok. I changed the contector from tiller harness to controller replacing some of the pins & have carrid out continuity check on this Harness.The problems are the function light not working & the wigwag not working.? plaese advise on a salution. thanks MICHAEL
  • 280 Answers
It sounds like you have tracked down your problems to the front to rear wiring harnesses since you have replaced some of the pins. In my experience, it is not cost effective to do this since there are usually hidden problems in the harness due to flexing, other corroded contacts or contacts pushed in the connector not making contact. The front to rear harness costs about $60 retail and is easily replaced.
You might also consider replacing the two intermediate harnesses from the tiller to all the components in the front console and the rear controller harness. I have had the rear controller harness melt and make poor contact at the controller board connector on the Curtis and Penny and Giles controllers. I have also had the tiller harness get pinched and flexed so much that the internal wiring made intermittent contact.
Continuity checks are only good if you go from the farthest point at the controller board pin outs to the console board pin outs. Sometimes, you can have a good continuity check on an unplugged, isolated component only to have it fail when you plug it in and the contacts are poor. Usually the intermediate molex contacts or wiring can be bad. These two additional harnesses can run an additional $200 retail. Labor should be about 2 hours if you do it yourself and if you have a hot glue gun to secure the front to rear harness under the shroud (if not use cable ties). You might still need to replace the front console circuit board and throttle potentiometer but your description indicates otherwise. Also make sure the that the front connector to the console circuit board (from the intermediate front to rear harness has not come unplugged due to gravity. You might still need to contact your professional for additional diagnosis and parts, then do the work yourself. The parts are OEM parts only, but they might be available online at a discount. Hope this helps.
Posted on Nov 13, 2010
Victory service manual
Have you checked the battery? Is the indicator saying that the unit is powered up? If so, then you have power to the tiller. (If not, then you need to check the cables that connect to the battery.) Assuming that you have power to the tiller and the unit will not do anything you may have an issue with the speed controller located on the tiller that allows you to forward and reverse. Go to Home Monsterscooterparts.com to find a part. If you can test this part and find that it is ok then you have either a electronic controller issue or your motors are fried. You would need at least a Digital multi-meter to check these out. Remember to remove the part you are testing from the circuit by disconnecting the battery. Warning! The units can have residual charges in them. If you do not know how to handle electric circuits I would suggest taking it to a professional to repair.
Mar 23, 2014 | Pride Health & Beauty
The motor runs but the tines no longer turn
Does the drive shaft turn and the tines just spin around it ? if not then on the drive shaft there is a gear box and you need to open that up (without the machine plugged in) and check to see why the gears aren't meshing properly.
Oct 12, 2013 | Snow Joe Tiller Joe - TJ601E - 9 AMP...
Greenworks 27072 user's manual
Scroll down this page a bit and to the right there will be a link to the .PDF files for the manual.
http://www.homedepot.com/p/Green-Works-10-in-8-Amp-Electric-Cultivator-27012/203240626
Mar 24, 2013 | Greenworks 27012 10-Inch 8 Amp Electric...
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
Have an old Troy Bilt Horse tiller. The shaft and wheels are moving back and forth from the gear box. The "Slow and Fast" lever is also not engaging. What can I do? The serial # is CH-1001 / 337-Y. ...
HELLO,
from your statement above two things are involve in fixing up your tiller
what you need to do from here is that get your self a set of spanner
to fix up your gear box
peak up the size of spanner that you can use in fixing up the gear
put off the engine then unscrew then remove the old grease in it and then applied some grease oil in it or you should change the gear box completely
if you can not this then for you should be able to use you tiller you have to hold the shaft manually while using it
please note what have been is that your gear box is bad it need service or replacement depending on your financial strength but it is advice to get a new and better one if you can not do the fixing your self
after all this then the level of engaing control will be very ok
Good luck
May 01, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Changinge fuel flitter and broke the plastic contector peice what do i do now and does that go to the fuel pump
Are you talking about the hose clamp? It would be the piece that clamps down on the fuel line. If so, you can get new ones at any auto parts store. Or, if you broke the actual filter itself, you could probably cut the hose a little short and get a new filter.
Aug 30, 2009 | 1999 Plymouth Grand Voyager
Craftsman tiller tines wont engage or turn
sounds like the chain or belt inside is broke i just redid one like that with the same problem it was the chain broke i had to tear it down and change the chain its a job but it can be done unless u are not mechanically incline,if you are not it would be cheaper in the long run to take it to someone.
Apr 19, 2009 | Craftsman 8.50 Torque Rating Dual...
Pride New Mobility Legend 4 Wheel Scooter Logo
217 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
