Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have my IP address and am trying to set up a wireless connection. However, I need the password. Any way to get this? I went to the IP address and get tech info, but no place to change password
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless->wireless security ->WEP security note down the password it is your password to connect wireless. . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Nov 13, 2010
  • aaron Cutforth Oct 24, 2011
    I have the same issue, i can access the Thompson cable modem diagnostics page but there is nowhere there to access a password change. only events log, diagnosis and adminstration main page with no links on it.. can anyone help?
  • You need to login into router configuration page as "admin' other wise press RESET button for 10 seconds it is in the back side of router then all settings defaults.
    then follow my above solution to access router configuration.
I am trying to find my password for my d-link di-624 router-i have wireless setup but i have lost my password to load on my laptop to connect to the internet. I have a qwest dsl modem with wireless...
First connect your router to computer with ehternet lan cable then go to network adapter property.For that press windows key +R so you can see run type in run "ncpa.cpl" then press enter then you can see network adapter property. go to your network adapter tcp ip property and enable "ip get automatic" then it will get ip from router if dhcp enabled.Then go to command prompt type "cmd" in run so you can see command prompt.Type in prompt "ipconfig" then press enter then you can see all ip address gateway ip is your router ip address .Note that ip then type that ip in address bar of internet browser then you can see your router page.Also the default ip address to access router is http://192.168.1.1 or http://192.168.0.1 Try these ip hen you can see router page .But if you are still not able to see router page with above ip then need to reset it.press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . After seeing router page type user as "admin" and password as "admin" or blank or "1234" or password. then you can see configuration page of routerThen click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password.If you have to reset router for access it then also need to configure WAN ,wireless,DHCP on router . Let me know if you need further assistance. Thanks for using FixYa
Oct 19, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
My router seems to be destroyed. i tried to setup access point but right after that the light went red.. but i connect wirelessly. and my fone and my sisters' laptop can't connect to the internet...
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
May 16, 2011 | Belkin Surf N300 Wireless N Router
Need help setting up the Sudenlink Modem to Linksys Router
Connect lan cable from modem to linksys router's WAN port.
Then configure linksys router with below method.
Yes you need wireless router to use wifi in ipod touch or on laptop.
Then click on WAN settings set as your internet service provider settings like static ip address.If service provider give you user and password for connect internet then set router in pppoe mode.
Enable DHCP.
Mar 18, 2011 | Linksys WRT160N Wireless Router
How can I change my routers IP address?
You can assign Different Ip-address manually,Or use the Proxy to change the ip-address,by hiding the Original Ip-address or contact the ISP get the Dynamic Ip-address and Change the Ip-address,You can check the Ip-address at here
http://www.ip-details.com/
Jan 23, 2011 | D-Link AirPlus DI-524 Wireless Router
I want to change the channel my Linksys is using. So I went to Internet Browser and typed in my IP address. It said I need a Username and Password. Where would I find that.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . If you are not able to access router with above user and password then yo need to reset it. For that press RESET button for 10 seconds it is in back side of router.Then configure it again with above method.
Dec 05, 2010 | Linksys Wireless-G WRT54G Router
Pressed the "reserve" button lights went dim what hapopened can this be fixed thanks lp@morg.com
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Sep 21, 2010 | Linksys WRT300N Wireless Router
I am having trouble setting up the IP address to communicate with my router. I have followed the instructions in the manual provided with the router but when I test the IP address and error message appears...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Type user as "admin" and password as "admin" or "password" or "1234" or blank.
IF you are not able to access router still the press RESET button for 10 seconds it is in back side of router then try again with above..
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Mar 23, 2010 | Zyxel Prestige P-330W Wireless Router...
Well i recently put widnows 7 on my laptop and because i forgot the password of my wireless i reset the router, When i went to turn it back on everything seemed fine i connected to it with the defualt...
Be sure your laptop is on the same network as the router (192.168.1.x) X being different from the routers address. Connect via the Ethernet cable to the routers IP address. Enter the default user/password to configure.
Mar 05, 2010 | NetGear WGR614 Wireless Router
When trying to connect to my wireless modem it can't get an ip ad
Is it a modem or a router ?
If it is only modem then only 1 computer will go online at a time. If you have any other computer online already then the second computer will not go online and it will not get IP address.
If it is a combination of modem and router OR if it router then you can open the set up page of the device and find out the password.
For this you will need a computer connected to the device.
Check the IP address and open the set up.
Click Here for more info
Nov 30, 2009 | D-Link 802.11g Wireless Router WBR-1310...
How do you repair an IP address conflict? I have a wireless network system in my house along with a wireless printer. The IP address on the printer keeps changing and we're either loosing our connection to...
You can assign the xxx number as you wanted if your printer is wireless. For example your Lap top wireless is 10.0.0.3 then set your IP address for your printer is 10.0.0.xxx ( 10.0.0.9) The xxx number can't be the same with any number for any other lap top you have around the house. You can right click on Printer property to go to add Port and put this number in.
Sep 07, 2009 | Averatec 6200H Notebook
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
420 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
Jose Velazquez
Jose Velazquez
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
