Question about Microsoft Windows XP Professional
Script file "c:\Documents and Setting\Quality\boot.vbs".
When system in on windows scrit host - can not find script file "C:\Documents and Settings\Quality\boot.vbs".- massage is came.
So how can remove this defects? Can u help me?
By
Navin
  • Anonymous Dec 08, 2008
    i have compaq c300
    and there is no sound in my laptop
  • 35 Answers
I guess this is a Startup item on your computer and you can easily remove this from your computer by going in to the registry. But, before that to make sure you can try disabling it from the system configuration utility..
In order to do that, click Start -> Run -> Msconfig -> Ok
Click Startup tab and look for the entry boot.vbs..
Simply clear the check box and restart the computer..
Lemme know the result.. if it works then i can assist you in removing it permanently.
Posted on Jun 19, 2008
I always have this message
C:\Documents and settings\tazebama.dll
Posted on Dec 09, 2008
Every time I start my laptop there is always appear two massage form and this is the problem in my laptop -- Windows Script Host -- Loading script "C:\WINDOWS\:Microsoft Office Update for Windows...
Hope you had deleted some files that relate to your system files.
Try to repair your system by Inserting your Windows XP Service Pack2. in your CD/DVD ROM and boot it again.
And if it's not working than you must format your system. And installed it. Here are the procedure to repair/install for reference. Thanks for Using FixYa All the Best!
Jul 28, 2011 | Microsoft Windows XP Professional With...
Tip
How to Encode your VBS and JS files for secure website uploading
If you are still at Service Pack 2 then you can use Microsoft's own Script Encoder download it from HERE it's a command line version so after you have installed it you need to run the command prompt also make sure the Windows Scripting Host is started.
REMEMBER MAKE YOUR SCRIPTS "FOR YOUR EYES ONLY"
For both Visual Basic Scripts and JavaScript you will need to format the text in your script to look like this;
Replace your code goes here with your actual code when the encoder has been run then you will see that the <SCRIPT LANGUAGE= ********> will have changed to <SCRIPT LANGUAGE= ********.encode> and your code will be random characters.
The Syntax for the encoder from the command prompt is;
Recognized file extensions are .js and .vbs, which are changed to .jse and .vbe, respectively, after encoding, also these type of files can be decoded if you know what you are doing and therefore not totally hacker proof.
IF YOU HAVE SERVICE PACK 3 installed then this won't work at all so the best method is to use this VBS2EXE this is also a command prompt program you must make sure that the script that you want to convert is in the same root folder.
When finished there will be a new file about 10 times larger then the script with the EXE file extension if you try to edit it all the code appears random this is the best method for encoding your scripts
If you want to do it ALL online and feel secure then you can do both VBS (VIsual Basic Script) and (JS) JavaScript using this website below but it is limited to 10kb per file
http://www.f2ko.de/ov2e/ov2e.html
If you create alot of batch files then I suggest that you also check out their BAT2EXE v1.5 this will convert CMD or BAT files into EXE files for web distribution you can also password protect and add a decompiler if required
on May 30, 2010 | Microsoft Windows XP Professional SP2
Can not Find. Script File C:\WINDOWS\System32\CleanViirus.vbs
it is a virus plz follow the instruction bellow to remove this virus:
  1. Go to Task Manager –> Processes and End the following processes in order:
    1. dxdlg.exe
    2. wscript.exe
  2. Go to Start –> Run –> regedit –> Open the following key:
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionWinlogon
  3. In the right hand pane, select Userinit and delete everything except “C:windowssystem32userinit.exe”
  5. Make sure the processes wscript.exe and dxdlg.exe are not running.
  6. Delete the following files
    1. C:WindowsSystem32dxdlg.exe
    2. C:WindowsSystem32boot.vbs
    3. In your Windows drive, search for boot.vbs and delete all of them.
    4. In your Windows drive, search for kinza.exe and delete all of them.
  7. Disable System Restore and then Enable it again.
  8. Restart your computer.
Hopefully everything will be cleaner now and your computer will be free from boot.vbs virus icon_smile.gif . Please share your experiences.
Mar 31, 2010 | Microsoft Windows XP Professional With...
On startup cannot find script file 'cleanvirus.vbs'
May be you affected with a virus or missing some files...try to restore go to start /Accessories/System tools/System restore...try it
Feb 04, 2010 | Microsoft Windows XP Home Edition
Loading win xp gives message script file cleanvirus.vbs not found
Disable System Restore. Scan your computer with the free version of Malwarebytes' Anti-Malware.
http://malwarebytes.org/
If you don't have an Anti-Virus program, download Avast and scan.
http://www.avast.com/
If both scans don't detect anything, do this..
Ctrl-Alt-Del > Processes - End the following processes in order:
dxdlg.exe
wscript.exe
Start > Run > regedit - Open the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\ Microsoft\Windows NT\CurrentVersion\Winlogon
In the right hand pane, select Userinit and delete everything except C:\windows\system32\ userinit.exe
C:\Windows\System32\dxdlg.exe
C:\Windows\System32\boot.vbs
Enable System Restore.
Nov 28, 2009 | Microsoft Windows XP Professional With...
My computer is not creating Restore Points... yes it's turned on... yes I know how to do a manual... but it disappears when the next Restore Point is created... can you help?
Creating a System Restore point using a shortcut For a more elegant way to create a System Restore point using Script in Windows Vista, check out our article Create System Restore Points Quickly using Script in Windows Vista and Windows XP.
Alternately, you may use the method below:
Copy the contents below to a Notepad document, and save it to a file name with .vbs extension (Example: createrp.vbs) and close Notepad.
set SRP = getobject("winmgmts:\\.\root\default:Systemrestore")
CSRP = SRP.createrestorepoint ("Created a Restore Point now", 0, 100)
If CSRP <> 0 then
Msgbox "Error " & CSRP & ": Unable to create System Restore point"
End if
Right-click on the Desktop and select New - Shortcut
Create a shortcut with the following target:
wscript.exe c:\scripts\createrp.vbs
Note: The above assumes that the createrp.vbs script is present in the c:\scripts folder. If that's not the case, change the Path accordingly.
Name the shortcut file name as Create Restore Point
Running the script To create a System Restore point, run the script with elevated mode. To do so, right-click on the newly created shortcut (Create Restore Point.lnk) and choose Run as administrator. When you are prompted for an administrator password or confirmation, type the password or provide confirmation. A System Restore point will automatically be created.
Nov 23, 2009 | Microsoft Windows Vista Home Premium with...
Can not find script file cleanvirus vbs
Oct 22, 2009 | Microsoft Windows XP Professional With...
On online Window Vista activation I got the following error code: 0xC004F039, description: The software Licensing Service reported that the computer could not be activated. The key management service (KMS)...
When you try to use a Multiple Activation Key (MAK) or the Key Management Service (KMS) to perform Volume Activation on one or more Windows Vista-based computers, you may receive error codes.
This issue may occur if the KMS host is installed, and the KMS host is not activated.
To troubleshoot this issue, verify that the key that is used is the MAK that was provided by Microsoft.
Use online activation or telephone activation to activate the KMS host.
See Contact Microsoft.
Regards.
Jun 15, 2009 | Microsoft Computers & Internet
Error
try system restore
Jun 18, 2008 | Microsoft Windows XP Professional
Script Virus Removal particularly VBS.IE-Title.K
Eexecute regedit by typing "regedit.exe" in run command or command prompt.
Search and Remove the key value present in the reg'ed values in
HKEY_CLASSES_ROOT & HKEY_CURRENT_USER & HKEY_LOCAL_MACHINE & HKEY_USERS & HKEY_CURRENT_CONFIG , If present
this may present in /software/microsoft/windows
or drives/
Jan 18, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Professional Logo
303 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
