No sound or volume in my computer even i had a computer speaker installed in my desktop. when i go to sound, audio device, it says that there is no audio device... how can i install one and what audio device i will install when i am using windows xp.
    Genius:
  • 1,570 Answers
You need to install sound driver for your computer. or you do have sound card hardware in your computer. check the systems manager if you have
Posted on Nov 13, 2010
Speakers check ok, sound card ok, but very low sound from speaker even at 100%
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 17, 2011 | HP Pavilion a1730n PC Desktop
No audio even i already installed the audio driver
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
Feb 02, 2011 | Asrock P4VT8+ P4 PT800 Prescott Ready...
I have lg my pc desktop and i want a particular audio driver its running on my pc desktop tell me which audio driver runing in my pc desktop
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Feb 02, 2011 | LG Computers & Internet
My laptop is a emachine and i dont know what i did and everything like my music and photos completely erased and also my audio dont work, it has a red X on the sound icon. Can you tell me what te problem...
also
hope this helps
Feb 02, 2011 | E-Machines eMachines Desktop PC
Am using hp compaq desktop , my pc sound is not wrking,wat solution?``
also
hope this helps
Jan 30, 2011 | Compaq Computers & Internet
Cannot able to create sound
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
also
Jan 28, 2011 | Creative Labs CT4870 / CT4780 Sound Card
My gateaway gt5040 computer does not have audio
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 22, 2011 | Gateway GT5040 PC Desktop
My laptop's audio has stopped working, and the audio area says that the speaker is working and the sound is on, but nothing plays, not even the test tone. I think it is a driver issue. The speakers are...
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
or
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 11, 2010 | Computers & Internet
2.1 SPEAKERS NO SOUND. CONTROL PANEL DOESN'T RECOGNIZE ANY AUDIO DEVICE & CANNOT ADJUST SPEAKER VOLUME.HAVE NEVER HAD SPEAKERS HOOKED UP BEFORE.
That's your problem. It could be:
* the audio-device integrated on your computer's motherboard is "disabled" -- Windows cannot use it
* there is *NO* audio-device integrated on your computer's motherboard -- Windows cannot use non-existent hardware.
* Windows has not installed the correct device-drivers for the integrated audio-device.
* you have an add-in PCI audio-device, and Windows has not installed the correct device-drivers for this hardware.
Do the speakers work if the output from an iPod is connected to the input-jack on the speakers?
Do the speakers work if connected to some other computer (laptop or desktop) ?
Nov 11, 2009 | Insignia 2.1 Speaker System (3-Piece)
New speakers won't work with my computer
verify whit hear phones if is correct audio the problem is not in the computer...also check instalation driver sound is sound max for your computer
Sep 16, 2009 | Dell Dimension 3100 PC Desktop
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
