Installation manual for totaline star themostat p/n p474-1050 multi stage programmable thank you
  • 15 Answers
SOURCE: I just installed a P474-1100REC & P474-1100RF
Does the new stat have a rc and an rh if so you will need a jumper between them
Posted on Jul 08, 2009
raulcvalenzu
  • 11 Answers
SOURCE: ac wont work
check the input supply of voltage
Posted on May 27, 2010
hvac1960
  • 2133 Answers
SOURCE: I am a service technician
Dear friend, don't worry! I encourage you.
You can download freely from:
www.totaline.com/.../P374-0431ThermostatRemoteControlandReceiverOwner'sManual.pdf -
Plz reply, if you satisfied.
Posted on Dec 30, 2010
  • 123 Answers
SOURCE: I walked across my carpet
There are two options for this. You can try turing all the power off the the unit completely. The inside and outside unit and give it 30 seconds and turn it back on. This may reset it. Chances are you just burned it up. I hate this for you...
Hope it helps.
Posted on Jan 28, 2011
dkeven
  • 67 Answers
SOURCE: I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Posted on Jul 10, 2012
Testimonial: "It was a fuse. Thanks for your help. Greatly appreciated!"
How to I control this ridiculous thermostat (Totaline P310-0210) Just moved into this house and no manual, if I press buttons it says stage 1 or stage 2, I/m freezing...someone help!!
Hello Stephanie Sakata,
I found 2 (two) "TOTALINE" manuals...
These little beauties all work pretty much the same...
Put the slide switch in HEAT MODE...
Push the "HOLD".. (which keeps any/all
clocks/gadgets and BACK-SETS off)...
and ADJUST THE TEMPERATURE where you want it...
ELSE...
Read these manuals (
close)...
No exact matches found Try these results
Carnac the Magnificent
Dec 13, 2017 | Heating & Cooling
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
Totaline power
I don't know anything about your particular T-stat, but power comes from the transformer and there should be a 3 amp fuse next to the transformer. They're both located in the air handler (where the fan and evaporator coil Is).
Oct 06, 2013 | Heating & Cooling
Jul 10, 2012 | Heating & Cooling
I am a service technician trying to install a Totaline p474-1050 stat to work for one stage heat gas one stage cool.. I do not have the operating manual just installation... In the installation manual I...
Dec 29, 2010 | Heating & Cooling
Location of reset button on model 44110
There is a little reset button right under DAY/TIME. You will need a pencil/pen tip to press this little switch in to reset your unit.
Hope this helps.
Good luck.
Mac =)
Feb 09, 2008 | Hunter Fan Company 5/1/1 Programmable...
Wiring a Honeywell VisionPRO TH8320U1008 Thermostat
the thermostat will to any temperature but will not shut off
Nov 25, 2007 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
449 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
