Question about Biostar Mainboard M7VIGD-A02 VER:6.0 (BIOSTARM7VIGDA02VER60) Motherboard
Memory Modules Can this board M7VIGD-A02 support memory modules DDR1 working at 400 MHz?
    President:
  • 2,351 Answers
Short answer is no. You can not run PC3200 DDR 400MHz memory. The fastest memory the motherboard can run in the,
(Biostar M7VIG 400) is PC2700 DDR 333MHz.
If you do not have you're manual, you can download it by clicking on this link: ftp://ftp.biostar-usa.com/manuals/M7VIG%20400/M7VIG400manual.pdf
Biostar M7VIG 400 main web site, click this link:
http://www.biostar-usa.com/mbdetails.asp?model=M7VIG+400
Good Luck!
Mike
Posted on Jun 20, 2008
Install ram
This model comes with 2 x 512 M od ram on 400 (3200 mb on sec ) DDR1
and it has 4 slots for ram memory and by the manufacturer's specs supports up to 1 G of ddr1 on 400 or smaller in each one ...If you inserted a 2 G module in one of the slots , it will not work ....You need 1 G ddr1 on 400 (or 333) in each slot ..
The procedure is to remove the old one or keep it if you have free slots ..and insert the new one ..Avoid to touch the modules directly and handle them by the ends ..After you insert them it is recommended to remove the BIOS battery or at least use the jumper to clr .cmos on the board...and this way you will forve teh bios settings to recognize and select the configuration ..It will ask to press f1 and go to bios and confirm the settings and also set the time and date again ..
It may work without doing all that ..but it may also make problems ..
I would also reinstall the operation system after upgrading the ram memory and so make it work on full capacity .
Dec 18, 2011 | HP Compaq Presario SR1750NX PC Desktop
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    Type of memores for asus P5S880-VM MOTHERBOARD Q=? FROM==miko hozer
    Your motherboard can take DDR1 pc2100, pc2700, or pc3200 memory modules up to 2.0 gb maximum. If you upgrade your memory you must do the following. If you are only adding 1 module it must match the other module that is already installed. If you are installing both modules you can use whichever speed you want. The higher the number the high the Mhz or speed BUT it will only run as fast in Mhz as your front side bus speed which I think is 800Mhz (pc3200).
    Apr 14, 2011 | Computers & Internet
    I bought P3200 ddr 400 1gb memory and when i install it , it does not show up. any ideas why and if there is something i can do .
    The Intel® Server Board S875WP1-E supports both ECC and Non ECC Unbuffered PC2100 (266 MHz), PC2700 (333 MHz), or PC3200 (400 MHz) compliant Double Data Rate (DDR) memory modules. Dual channel memory functionality requires two DIMM modules installed into DIMM sockets 1A & 1B, and then DIMM sockets 2A & 2B. The DIMM module size, speed and vendor must be the same.
    You can install a single 128 MB memory module into DIMM socket 1A. The minimum supported memory size is 128 MB. The minimum main memory configuration is a single 128 MB memory module, and the maximum configurable memory size is 4GB. With only a single memory module installed, the system will only operate using a one memory channel.
    Third party memory vendors may use the same module part number with different
    DRAM vendors and die revisions. To insure proper system operation, verify that each DRAM
    vendor and die revision has been separately tested and qualified. Please notify CMTL if there is a discrepancy.
    Apr 10, 2011 | Intel Server Board S875WP1-E (S875WP1LX)...
    Upgrade to 400 mhz 2x1GB memory
    Hello, First thing I would try is to just install one of the new modules in the DDR1 slot and see if it boots. If it does, go into your BIOS (Use the key I believe.) and set the ?Max Memclock (Mhz)? field (Advanced Chipset Features submenu) of the BIOS to 200. Save & Exit and allow it to boot. Shut down the computer and install the second one. Again go into the BIOS and verify it is detecting both. A second thing to try if that does not work is to install the new modules, and before powering up, reset your CMOS using the jumper between the battery and the AGP slot. If the jumper is on the 1st and 2nd pin, put it on the 2nd and 3rd pin for 15 seconds. Then replace it to the original position. NOTE: Make sure the power is OFF and the power cord unplugged when you do this. You should also press and hold the Power button for 5 to 10 seconds to discharge the capacitors in the system. If this still fails to get you going, you may have high density modules which do not work in all motherboards. Did you get the modules from MS Memory Suppliers? When I did a search for your motherboard it only gave me DDR266 PC-2100 DIMMS as compatible. No DDR400 were listed even though they should be backward compatible. Hope this helps. Thanks for using Fixya. Comment back and let me know your results.
    Sep 30, 2009 | DFI K8M800-MLVF Motherboard
    I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
    Dear Sir,
    *********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
    good luck
    Aug 05, 2009 | ASUS K8V-MX Motherboard
    Memory upgrade, download upgrade to run 400
    According to the specs of this motherboard, it only supports 333, 266 and 200 MHz DDR SDRAM. It does not support 400 MHz DDR SDRAM.
    This motherboard has only 2 memory slots, each can accommodate a 1 GB memory module. Higher capacity memory modules are not supported by this motherboard.
    No BIOS upgrade is available to provide support for 400 MHz DDR SDRAM memory modules.
    Jun 04, 2009 | Intel D845GVSR Motherboard
    RAM cuantity
    The motherboard you mentioned supports DDR1 RAM.
    For windows xp and general application 512 MB is enough.
    But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
    Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
    Intel D865GBF Ram related questions
    here are the specifications of *********** board go through it...
    Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
    Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
    Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
    So it will support DDR2 and you can upgrade upto 4GB...
    Sep 28, 2008 | Intel D865GBF Motherboard
    Memory support confusion
    Hello gu11ddu,
    Here are the specifications concerning your question about your motherboard's RAM.
    Memory Type grayquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz Max Supported RAM grayquestion.gif 4 GB
    The key factors that are the most important when you select your ram is the MEMORY TYPE DDR SDRAM, 184 PIN DIMMs, and the SUPPORTED RAM SPEEDS 400 MHz and 333MHz. Your motherboard will support memory no more than 4 GB of memory, so yes you could use the 128mb modules, but you must make certain that they are DDR SDRAM types and 184 Pin DIMMs as this is what the manufacturer suggests is compatiable with your specific motherboard. The supported speed is also a suggestion, because this is the max speed that will work at it's optimal level. You can buy some ram modules that are higher, but they will clock down to the max speed allowed by your system. In other words, say for example you went to your local best buy or circuit city and bought the suggested memory type with the proper pin count and DIMM modules but they only had 500 MHz bus speed, then your system would clock the speed down to 400 MHz. With 4 128mb modules you are only going to get 512 mb max memory, because 4 x 128 mb = 512 mb so you will not be using all the available memory capacity that your motherboard can handle. If you wanted to maximize your memory usage you could buy 4 of the 1 GB memory modules or buy 2 of the 2 GB modules to obtain your max capacity. In your case buying 4 128 mb memory modules would not be worth it because you could buy 1 of the 2 GB modules and get better memory usage.
    Another important thing to remember is that you should always use the same type of memory modules and never mix and match them with different ones as this could cause system crashes and problems with lots of memory errors. When going to a local store and asking a sales rep for compatible ram they will ask you what is the make and model of your computer and what your processor speed is because your processor speed also determines your bus speed because your ram will not operate above that speed it will simply clock down (if it is rated higher than what your processor speed is), with this information they will look up any compatible ram they may have in stock. Hope this answers your question and if you need further assistance please let me know.
    p.s. your motherboard can support up to a pentium 4 class processor, but this may be different than what you have in your system.
    If you do not mind, please rate my help as I would greatly appreciate it. Thanks
    Sep 19, 2008 | Intel D915GAG Socket 775 Motherboard -...
    Biostar Mainboard M7VIGD-A02 VER:6.0 (BIOSTARM7VIGDA02VER60) Motherboard Logo
    178 people viewed this question
    Top Biostar Computers & Internet Experts
    Jayburt
    David
    David
    Jerry Umali
    Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
