Question about Kodak ESP7 PP All-In-One Printer
Over a few weeks colour printing on my ESP7 has detriorated in quality. A few days ago it started to print only in yellow. Then it aasked me to insert a new colour cartridge, which I did. It again asked me to insert a new colour cartridge, which I did. The same mesage was repeated. I have no cartridghes left. What do I do now ?
    Guru:
  • 254 Answers
Hello user
try to remove all the cartridge and turn off the printer unplug the power from source power. clean the cartridge, try to wipe it with cotton and little bit warm water.
i try this problem before have the same problem and same unit.
inform me what will happen ill guide you thru the process.
thanks
Posted on Nov 13, 2010
Yellow not printing in Canon iP6600D printer
in the print out alone you can already know what print head is no working properly like missing color. if cleaning is not solving the issue this purging the print head. just read the user manual for the instruction
Apr 29, 2013 | Canon Pixma iP6600D InkJet Photo Printer
I have a problem with print quality of my Brother printer mFC-6490CW, I have run the ink management utility, the black, yellow and magenta printed to about 95% just one dotted line missing on the black,...
Well, this is a common problem with people who purchase Brother printers, but do not always use Brother Ink Cartridges. Brother has a cleaning agent in the print cartridge and the compatibles do not.
"If you have a lack of one (or more) color do the following:
Make sure all carts are full, placed well and are secured. Insert a new ORIGINAL BROTHER CART for the one that shows no color.
Press menu then start bk-copy then four times arrow up quick after another. machine will switch into maintenance mode and all lights will flash. Press 7 then 6 then 4 then start bk-copy. machine will initialize the carts and refresh ink within tubes and print head. After that it does some power cleaning. When finished press 7 then 6 then 3 then start bk-copy. machine will run a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a quality test print.
This should clean the lines out and clear up your issue.
Jun 20, 2011 | Brother MFC 6490CW InkJet Printer
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    Xerox Phaser 8550 is printing green and yellow with some gray color on all the print job, even after I replaced the ink loader, the black color came back but still getting only green and yellow. The ink...
    Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
    If you have loads of missing jets, run a couple of head cleans, if you see improvement, it is worth running some more, if not, try switching off overnight and rebooting next day. If it still won't clear, you may have a faulty printhead.
    If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
    Hope this helps.
    Dec 25, 2010 | Xerox Phaser 8500/DN Printer
    How do you go about cleaning printer head
    there is a cleaning utility "printhead clean" and printhead deep clean" under "maintenance" in the "printer properties". Try that first. If that doesn't help and there is definitely ink in the cartridge(s), you can remove the cartridges and soak the printheads in 5mm of hot water for 1/2 hour or so. DRY WELL then install back in printer and run "printhead deep clean".
    Another way is to isolate the colour that doesn't print properly and print few pages in that colour (eg if yellow is not printing right...set out a full page of yellow background and print on high quality setting until yellow starts to print ok). This wastes less ink than the cleaning utility.
    good luck with it
    LC1000
    www.inkbank.com.au
    Dec 02, 2010 | Canon PIXMA MP160 All-In-One InkJet...
    Hi there can you help with my HP2605? Since i replace a blue cartridge (a compatibal one. We have been using compatible cartridges for over year and so far so good.)3 weeks ago the printing is not week....
    click on the alignment button and have the machine automatically start the realignment process
    it is not color realignment but printer head alignment that is the problem
    May 04, 2017 | HP LaserJet 2605dn Printer
    HP color laser 2550l prints only yellow
    Are you sure that none of the other colours are empty? If they are then this could be the problem
    Jan 01, 2009 | HP Color LaserJet 2600n Printer
    Hp psc 1510 - only want black ink
    Hi Manavoc,
    I will explain you the cause for it.
    It prints in yellow first and then override with black for better quality. This is the reason your color ink gets empty.
    http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00308490&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
    Have a great day!
    Mar 20, 2008 | HP PSC 1510 All-In-One InkJet Printer
    Colour faded
    Hi Desperate for help I had a similar trouble with my printer it turned out that when I bought a replacement ink tank they gave me a photo quality cartridge and you can't mix them you need all photo quality or all plain cartridges check for that hope this helps
    Jan 12, 2007 | Canon PIXMA MP760 All-In-One InkJet...
    Kodak ESP7 PP All-In-One Printer Logo
    55 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
