Question about Philips DVDR3576H DVD Recorder
The cooling fan makes a terrible noice. With wich fan can I replace it.
  • Philips Master
  • 11,800 Answers
It's a standard 50mm 12v pc fan. You can find a similar one in almost every pc shop. It just plugs in.
Posted on Nov 13, 2010
I have a HPDV9000 Laptop and it is making a terrible loud noice, very annoying. Starts when turned on. What can it be. Thank you.
More than likely it's one of the cooling fans. They spin at relatively high RPM and if they're damaged they can emit a loud whirring or screeching noise. If it's a clicking noise then it could be your hard drive failing.
May 04, 2011 | Computers & Internet
Cooling fan will not shut off continued even after ignition key is off and removed, and small black box in front of battery keeps making a clicking noice
That would be the relay box, remove the lid and remove the relay that controls the cooling fan circuit. and that would be the one making the clicking noise. It will probably be very hot, If you have pulled the right one the cooling fan will turn off. Replace it with a new one. Should be fine now, however in the event that the problem does not go away then replace the engine coolant temperature sensor. Good Luck From Ernie @ RedDeer, Alberta, Canada.
Jan 14, 2011 | 2002 Saturn L-Series
I have a powersuppliefan that make a lot of noice. My question is: is it possible to replace the fan with a new and more quiet on? I have a zepto d47v
You can replace the fan. Most are 120mm at 120VAC. I would advise against it unless you know what you are doing. Power supplies can carry a charge even though they are disconnected. Better off replacing the power supply.
Oct 28, 2010 | Sharp Computers & Internet
Noisy AC fan in 240GL 1986 model sedan. Fan make a terrible noise when the AC switch is turned on. After about two minutes the noise disipate after the fan swich is put onto maximum power. However, the...
Hi; Sounds like a bearring is getting dry and sweaking. Sometimes You can acess the motor from under the hood very easy. If not please let a person with auto skills attempt this Weather its a friend or a professional...alpharome416
Feb 22, 2010 | Heating & Cooling
Terrible noice when I turn the steering wheel on my 2001 BMW 325i
Make sure you check your power steering fluid... if it's even low, it will make a terrible noise...run it on empty too long and your can ruin your power steering pump.
Dec 27, 2008 | 2001 BMW 325
Acer 5003 fan noice due to unknown reasons
your fan has worn bearings what I do in this case is remove the little sticker over centre of fan and just put a little drop of sewing machine oil on it replace sticker and check for noise
Jul 13, 2008 | HP (344872-001) Laptop Cooler, Cooling Fan
Noices
there are two fans the heatsink fan and an extractor fan, either of theses can be replaced, you buy the heatsink and fan together for the processor and a seperate case fan can be fitted easily by yourself
Nov 06, 2007 | HP Compaq Presario SR2150NX PC Desktop
Intel p4 3.0ghz with 800fsb fan makes more noice
Hello Prask, Cooling the Intel's LGA775 CPU presents quite a challenge due to it's high operating temperatures, and while the ideal solution would be to use water, not all of us are ready to make the jump. The best solution I found for an easy replacement of the stock cooler is nMEDIAPC ICECONE Pure Copper CPU Cooler. It is an easier install than Thermaltake, and is just as quiet. You can find it here for the best price: http://www.directron.com/icecone.html Let us know if you need any additional assistance. Best regards, nightdiver
Aug 16, 2006 | Intel Pentium 4 630, 3.0 GHz...
Philips DVDR3576H  DVD Recorder Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
