Question about GPS
I have a motorhome on an Iveco Daily 50C 18 chassis 2006. The factory fitted trailer 13 pin socket is dead. I have checked all the fuses and cable, and even spoken to Iveco on the phone on what to check with no joy. The loom runs from the socket, forward to under the bonnet, where I suspect it goes into some sort of ECU. I am unable to find any wiring diagram, so don't know where or what I'm looking for. Any help would be much appreciated. Regards, John.
  • 807 Answers
That harness should originate from a plastic relay and fuse box, under the hood close to the battery. check every thing in that box. It should have the fuse layout printed on the cover to the box
Posted on Jun 18, 2017
  • Joe Stanton Jun 18, 2017
    Also do not mess with the ECU for that motor home. It is very expensive and rarely goes bad.
  • 32 Answers
SOURCE: 1996 Dodge Ram Factory Trailer Wiring Schematic
all you need is a cheap continuity tester, any one to help tap on the brakes..7pin is just like the 4 pin w/extra power wire for acc.lites,electric brakes.when you buy the 7pin rec.,comes w/wiring schematic standard to all trailer rec.- you can do it..kev-mn.
Posted on Dec 10, 2008
  • 65 Answers
SOURCE: Fitting a towbar for a caravan with 13pin europlug
black socket, black 7 core wire
pin 1 yellow left indicator
pin 2 blue, rear fog light
pin 3 white earth
pin 4 green right indicator
pin 5 brown right side/tail light
pin 6 red brake lights
pin 7 black left side/tail light
Grey socket grey 7 core wiring
pin 1 yellow, reverse
pin 2 blue, supplementary feed (ignition)
pin 3 white, earth
pin 4 green live feed (battery +)
pin 5 brown not connected
pin 6 red supplementary feed (ignition)
Pin 7 black earth
On the discovery there is a purpose made plug behind the panel on the drivers side rear, behind the rear lamp
i think the relay you have bought is for lamp failure you just need a normal 4 pin 30 amp relay.
Good luck Davelee
Posted on Mar 24, 2009
cornelm1976
  • 4 Answers
SOURCE: my tom tom one has no sound
Hi! Check your chosen voices and test it! Choose another voice and test it again, if still not working then is a hardware problem... My email is cornelm1976@gmail.com
Posted on Aug 15, 2009
michigan man
  • 3533 Answers
SOURCE: hi need to get hold of a diagram of fuse box with
try these websites www.alldatadiy.com and if you do not have an owner manual give this website a try to see if you can download one for your car its www.edmunds.com wish you the best of luck Michigan Man
Posted on Oct 11, 2009
  • 3 Answers
SOURCE: Tow bar trailer socket wiring connection point to car wiring?
The connectors for towing wire harnesses on foresters are generally on the passenger side, below the rear taillight inside the cargo space. some require pulling up the foam block that is between the spare tire compartment and the taillight. Check where you replace the tailights from inside the car, if there isn't a matching connector hanging out there, check around the spare tire compartment, see if you can remove the carpeted foam block next to the compartment and find the plug under there.
Posted on Mar 03, 2010
Dyson upright vacuum with kinked cord kept stopping. There was a loud bang and smoke and the vacuum stopped. Has the motor blown up, or can it be repaired?
This happens a lot the supply cable bending or damaged shorts out causing smoke and a bang if fitted with or backed up with a high amperage fuse .
check length of supply cable if you find damage/ burning smell,
either replace cable, or you could fit a inline rubber socket and plug by cutting out damaged part of cable and fitting female part of plug first into supply cable 1. then on the vacuum side of cable fit the male part of plug 2 . supply 1. -----o o----------2.--- vac
using insulation tape if you like you can tape plug and socket together to stop it pulling apart, normally cable damage will not damage the vacuum cleaner. and fit the correct fuse rating for the machine 1000 watts at 240v divide 240 into 1000 =4.166 amps
so with a 1000 w load you do not need a 13 a fuse fitted 6 amp fuse should be ok. or go online and see what is recommended re fuse size for appliance ,
Nov 12, 2016 | Dyson Vacuums
Trailer running lights Fuse
Go to Autozone.com and register your truck for FREE. Then you can get access to Chassis wiring diagrams and fusebox layouts. The plastic cover on your trailer plug will have the id for each pin in the plug.
The factory chassis diagram should show the fuse providing power to the individual post on the plug.
Feb 12, 2012 | 2002 Ford F350 Super Duty DRW Reg. Cab
After fitting a 13 Pin towing socket to my 06 Nissan X Trail adventura the reversing lights and the instruments are not working. But I cannot locate a fuse.
CHECK FOR BLOWED 15 AMP FUSE TO THE INSTRUMENT PANEL CONTROL OR YOU HAVE BAD CONNECTION AT THE 13 PIN SOCKET.COULD HAVE LOOSE OR BROKE WIRES GOING INTO THE 13 PIN SOCKET.
Aug 04, 2011 | 1992 Nissan NX
2006 GMC Sierra The trailer park lights won't come on
Suspect 7 pin connector problem , you should have power on the 8pm positioned and the centre pin position as you look into the socket (on vehicle. These pins are both male pins as you look at them . If ok check trailer wiring where it splits for either lamp assy ! Good luck
Mar 09, 2010 | 2006 GMC Sierra 2500HD 2WD
I have a 2008 Ford F 150 with factory installed trailer wiring. I bought a trailer plug tester. It shows the tail light function to be dead. Brake lights, turn signals all work. Any ideas?
The trailer tow adapter parking lamps is fuse #10 in the cab fuse panel. There is also a trailer tow parking lamp relay that powers them, which could have a problem as well.
Start with the fuse, and maybe check both the 7 pin and the 4 pin for the parking lamps, could be a corroded pin on one of them causing the tester to not see the power on the pin.
Dec 17, 2009 | 2008 Ford F 150 2WD
I'm just about to have a towbar fitted on a new car for a caravan. I am unsure whether to have a 13-pin socket fitted, as up till now our old caravan and car had just the 7-pin sort for the tailboard and...
Saves having to use a supplementary socket
01 Yellow Left Indicator
02 Blue Fog light
03 White Earth (35amp)
04 Green Right Indicator
05 Brown Right Side Light
06 Red Brake Lights
07 Black Left Side Light
08 Yellow Reversing Light
09 Green Permanent live
10 Blue Ignition live
11 Red Earth (35amp)
12 Black Coupled Trailers
13 White Earth (35 amp)
Aug 31, 2009 | 2007 Volkswagen Golf
Wiring diagram
If you are going from a 4 pin on your trailer to the 7 pin on the truck. You need to go to parts store or a department store (ex Wal Mart) and look in trailer section and find the adapter. Thats what I did. Also Remember if your lights don't work on trailer, check the plug to make sure its tight or check the fuse under your drivers side rear seat for that fuse box.
Apr 15, 2009 | 2006 Chevrolet Trailblazer
Wiring for a trailer
u must install the fuses for the system in he underhood heavy duty fuse box, it will be marked trailer tow
Mar 17, 2009 | 2006 Ford Escape
Volvo V70 2001.. Plugs For Towbar Electric's??
You can get an adapter that fits in to the 13 pin socket that give you a 12N socket, easily available on E-bay
http://cgi.ebay.co.uk/13-to-7-Pin-Adaptor-for-Euro-Style-Towbar-Electrics_W0QQitemZ110303426204QQihZ001QQcategoryZ36631QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I have one for my car and it does the trick
Sep 30, 2008 | 2001 Volvo V70
Back-up lights and trailer running lights
My 2004 f150 has the factory tow package. It has a fuse for the trailer running lights seperate from the truck running light fuse.
Check, you may have the same set up...
Jul 21, 2008 | 2004 Ford F150
GPS Logo
503 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
