Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
Still won't print, how do i clean the ports where the cartridges fit in to the machine? you said i can clean by hand. how?
    Genius:
  • 1,325 Answers
Hello
the manual says NOT TO REMOVE CARTRIDGE unless it is empty. the cartridge compartment does not rqeuire you to clean it, it cleans itelsef when you perform series of steps -- follow the manual instructions
basically , there are a few components to clean -- go to this link and download the manual
"how to clean ink catridge capartment, printehead and cartridge" are listed here . you have to read the section on maintainance . In most cases, the machine cleans itself by going through a series of steps . I am sure this will assist you
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_490CW_EN_1773.PDF
i hope this helps you
Posted on Nov 13, 2010
Fresh ink cartridges won't print at all.
First visit our Epson support page to ensure you covered : http://inkjet411.com/?page_id=1939
Since the Epson PRINTHEAD is not removable, then it is suggested you take a damp cloth and repeatedly blot/saturate the respective color ink port with water (distilled water is recommended):
1. Remove suspect ink cartridge (or cartridges).
2. Place a paper towel under the PRINTHEAD assembly.
3. You'll see a round mesh ink port where ink flows into the PRINTHEAD.
4. Thoroughly dampen the ink port with 0.5 to 1 teaspoon of distilled water (use an eye-dropper or similar, pour or drip directly into ink port).
5. Reinstall ink cartridge(s).
6. Activate the 'Clean Printhead' routine once or twice to see if the respective color(s) have recovered.
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Jun 12, 2013 | Epson Artisan 837
Installed new 28 and 29 cartridges in lexmark x2550 and it won't recognise the cartridge and won't print at all, very frustrating please help urgently
It could be that your cartridges need some cleaning. On your computer, launch the Lexmark Solution Center. Click Start menu > Programs or All Programs >Lexmark 2500 Series > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print again.
Jun 29, 2011 | Lexmark X2550 All-In-One Printer
The printer will not print. after i changed the cartridges. can not get it to copy, print. anything involving the ink.
Hello
While the Brother printers are simple to use, there are still a few mistakes that can be made or steps overlooked that might cause the printer to malfunction. If you've set up your printer and placed the ink cartridges into their proper place but the device won't operate, troubleshoot it yourself instead of taking it to a repair shop.
Check the ports and connections from your printer to your computer. Make sure all wires are properly plugged and all ports and jacks are free of dust and excess material that might interfere with the connections
Check that all drivers are up-to-date on your machine and that there have been no software errors that might keep your printer from running. This issue can usually be fixed by reinstalling software from the disc you received with your printer.
Look inside the printer to be sure that it is free of anything that might disrupt the moving of the internal mechanisms of the device. Clean your printer head. Most printers have a maintenance option that will do the task for you, but you can also clean your printer head by hand, should it be necessary
Check that you have removed the plastic tab that sticks to the ink cartridge before you try to print. Use the correct ink cartridge. Do not attempt to use a brand of cartridge that has not been specifically made for your machine, even if the cartridges look similar in size and shape.
Look to see that the lever that depresses the cartridge into the well has been returned to its original position after inserting the ink cartridge.
Nov 13, 2010 | Brother MFC 490cw Color Inkjet...
LEXMARK X2470 wont print in yellow with new cartridge,
try to clean the base of cartridge and clean surface of cartrage and the base where it fits in to clean it too.
Jul 23, 2010 | Lexmark X2470 All-In-One InkJet Printer
One of the 3 colors will not print
This problem may be due to blocked nozzles, faulty cartridges or a faulty print head or main board. The first thing to do is eliminate the cartridges. Do a proper cartridge change on both printers, but swap the yellow and cyan (blue) cartridges between printers rather than fit new ones. If either (or both) of the missing colours now appear, you know the problem is the cartridges; replace it (or them) with new ones.
For example, take printer A, with yellow missing. Do a cartridge change procedure on printer A, but instead of fitting a new yellow cartridge, put in the yellow cartridge from printer B (since you know this yellow cartridge works). If yellow now prints in printer A, you know the cartridge you took out is faulty - put a new yellow in printer B, and throw away the cartridge you removed from printer A. Repeat this process for printer B with the Cyan cartridge.
For one or both printers where the above does not solve the problem, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head across fully into its parking position on the right, so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean or two. If the missing colours now start to appear, try another clean or two. If still not perfect, leave for 24 hours and try again. If still nothing, report back.
Feb 08, 2009 | Epson Stylus C62 InkJet Printer
MFC 210c Unable to Print Use Troubleshouting and routine maintenance chapter in Users Manual
My color has not worked well in the past few months. Now I get the message Unable to Print, Use Troubleshooting and rountine maintenance chapter in user's manual. I've tried everything it told me. I've removed all ink cartridges and left them upright (they are ALL brand new) and cleaned all the ink ports. I've cleaned the machine several times. It's told me there's no ink cartrige, I've replaced them, turned the machine off and on, unlplugged, etc. Then go to print and I get the same message again and it won't print. The machine is almost 2 years old and has worked fine until about 6 months ago when the magenta stopped working all together. Now this. Any help? Thanks.
Nov 05, 2008 | Brother MFC 210C All-In-One InkJet Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
133 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
