Question about Canon EF 75-300mm Lens
Fungus (oil spray/mist?) on inner lens surfaces - how to disassemble and clean a Canon 75-300mm EF AF lens? A skeleton picture would also be helpful. Thanks, Tom.
  • kakima Nov 13, 2010
    Before you disassemble the lens, consider this. Do you have a lens collimator and other equipment necessary to ensure proper alignment when you reassemble the lens? If you don't, you may as well disassemble the lens with a sledgehammer: pictures you take afterward will be just as good.
  • tom_mille871 Nov 13, 2010
    I guess that is a pointer in the right direction. I take it from your comment, the guides and threads are not static and the groups may misalign. I got the lens in this condition for a song (5% of its new value) as a learning (to fix it) aid. Either I get it to work or I just have fun trying. Either way, I will have the knowledge to pass on or use, a pile of junk or a usable lens.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Okay. I just wanted to scare you away from ruining a perfectly good (or nearly so) lens, but a learning project is a different matter. And a lens collimator is not that hard to build. One source is the book "Camera Maintenance & Repair" by Thomas Tomosy. I'm sure a quick Google search would show even more.
I did the same thing myself decades ago, taking apart a damaged zoom lens. Unfortunately, I never got it working properly again :-( But it was an educational experience, even though I didn't have a lens collimator...
Posted on Nov 13, 2010
  • tom_mille871 Nov 14, 2010
    I am using a Promaster 75-300 lens. Saw this one and just want to play. If it works, I'll have an all Canon badged kit. Thanks for the info, I'll hunt the book down and see where it takes me. Main barriers so far are the AF connections won't let me remove the mount, and the front lens seems glued with its inner screws rotating and not comming out. Anyhow, got to go for now Cheers.
    I have mined into the centre of the lens, and found the "Fungus" is on the third lens from the front and its coating. This lens' mounting also carries the iris. Moisture from my breath and a lens cloth removed the mark and I am now putting the parts back together! Thanks for your help k_akima,
Fungus canon 75-300 ultrasonic rear lens
If the lens has fungus It'll need to be cleaned professionally.
Dec 27, 2013 | Canon EF 75-300mm f/4-5.6 II Lens
Canon efs 18-55mm lens will not take pictures with af on
Hi
this is because flex cable damage. Lens does not know exact position of focusing lens, so it fails to work in AF mode. Problem is fixable but not DIY. Should cost around 40USD (35Eur).
Regards
Dec 11, 2013 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Cannot auto focus
It sounds like the circuit board flex has gone bad, It folds back and forth when you zoom the lens, And needs to be replaced by a repair shop and readjusted. Tony
May 26, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
EF-S 17-85 AF jumping around causind err 99
The AF motor is hunting. Clean the contacts on the end of the lens and the camera body with a pencil eraser and try again.
Jan 20, 2010 | Canon Cameras
Hi, It appears there is a small amount of fungus inside my lens, and when taking a picture, it comes back very dark. What would a possible remedy be for this? Many thanks Jon
This is actually a very common situation for older lenses. You should take the lens to a trained technician and have them clean the inner elements of the lens. Often times they can, if the fungus isn't too bad. In extreme situations, they will need to replace the element itself.
Jul 05, 2009 | Sigma 24-70mm F3.5-5.6 AF Zoom Lens
Friction in zoom, Sigma AF 70-300mm for Canon-EOS
Its more like a distorted inner zoom barrel or sand and dirt inside  the inner barrel will need to be replaced or you need to dismantle and clean out
Nov 09, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Canon 17-85 Lens with Rebel XTI Camera
This is because the camera will not expose a picture until the auto focus is locked. If you are shooting in dimly lit conditions, the AF might have a hard time obtaining a lock. Using the flash as auto focus assistance many time helps in this condition.
Another reason might be that you try to focus on even surfaces with low contrast. The auto focus work by sensing contrast. Even surfaces, such as a white wall or the sky, have very little contrast, therefore the auto focus will not be able to obtain a lock. The solution here is to point the AF sensor at something with more contrast, such as an eye, a pole, or basicly anything that have edges/lines.
I hope this help you!
/Chris
Jul 09, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon EF 75-300mm Lens Logo
480 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
